Example MPC5744P FCCU fault injection GHS614
File uploaded by Peter Vlna Employee on Feb 3, 2015Last modified by Peter Vlna Employee on Apr 10, 2017
Version 2Show Document
  • View in full screen mode
* Detailed Description:
* This example shows how to use FCCU module for fake fault injection in order to test FCCU functionality.
* For closer details on how FCCU works I suggest you to check reference manual as this module is quite complex.
* This example sets system clock for 200MHz running from PLL0 module.
* The FCCU_Fake_fault_inject function is setting and injecting FCCU fault NCF[7] - STCU2 fault condition.
* Short reset is triggered as soon as FCCU registers injected fault.
* Test HW:  MPC57xx Motherboard + MPC5744PE257DC minimodule, MPC5744P,
* silicon mask set 1N65H
* Target :  internal_FLASH*
