I2C NCSW Use Case
I2C NCSW Use Case
I2C NCSW Use Case
The NCSW - NetComm Software - is a package to help speed development on Freescale PowerQUICC and QorIQ processor platforms. It contains NCDD - NetComm Device Drivers - and some other components. Here take P3041 I2C supported in version GA_4.7 as an example to analyze the NetComm Software structure and device driver usage. CW PA 10.3 is used to be compatible for the use case code.
添付
コメント
Hi are there anyone who use NCDD for P1022. Its vesion GA_4.4 and usecases for p1022 are for code warrior classic, while I import a usecase it gives several errors. Consol output is copied below. I only imported DiuUseCases at this project is it false.
**** Build of configuration DiuUseCases for project DiuUseCases ****
C:\Freescale\CW_PA_v10.5.1\gnu\bin\mingw32-make -j16 all
'Regenerating dependency file: UseCases/common/controller/DIU/uc_diu_valid_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/uc_diu_util_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/uc_diu_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/print_screen_1_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/print_screen_2_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/mode3_bmp_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/mode2_bmp_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/mode4_bmp_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/mode1_bmp_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/mode0_bmp_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/bmp_512_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/alpha3_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/alpha2_c.d'
'Regenerating dependency file: UseCases/common/controller/DIU/alpha1_c.d'
'Regenerating dependency file: UseCases/common/main_c.d'
'Regenerating dependency file: UseCases/integrations/P1022/DIU/diu_layout_c.d'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/integrations/P1022/DIU/diu_layout.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/usecases/common/main.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha1.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha2.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha3.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/bmp_512.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode0_bmp.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode1_bmp.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode2_bmp.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode3_bmp.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode4_bmp.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_1.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_2.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_util.c'
'Building file: C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_valid.c'
'Executing target #1 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/integrations/P1022/DIU/diu_layout.c'
'Executing target #2 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/usecases/common/main.c'
'Executing target #3 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha1.c'
'Executing target #4 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha2.c'
'Executing target #5 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha3.c'
'Executing target #6 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/bmp_512.c'
'Executing target #7 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode0_bmp.c'
'Executing target #8 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode1_bmp.c'
'Executing target #9 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode2_bmp.c'
'Executing target #10 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode3_bmp.c'
'Executing target #11 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode4_bmp.c'
'Executing target #12 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_1.c'
'Executing target #13 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_2.c'
'Executing target #14 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu.c'
'Executing target #15 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_util.c'
'Executing target #16 C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_valid.c'
'Invoking: PowerPC Compiler'
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/integrations/P1022/DIU/diu_layout.args" -o "UseCases/integrations/P1022/DIU/diu_layout_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/integrations/P1022/DIU/diu_layout.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/main.args" -o "UseCases/common/main_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/usecases/common/main.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/alpha1.args" -o "UseCases/common/controller/DIU/alpha1_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha1.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/alpha2.args" -o "UseCases/common/controller/DIU/alpha2_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha2.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/alpha3.args" -o "UseCases/common/controller/DIU/alpha3_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/alpha3.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/bmp_512.args" -o "UseCases/common/controller/DIU/bmp_512_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/bmp_512.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/mode0_bmp.args" -o "UseCases/common/controller/DIU/mode0_bmp_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode0_bmp.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/mode1_bmp.args" -o "UseCases/common/controller/DIU/mode1_bmp_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode1_bmp.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/mode2_bmp.args" -o "UseCases/common/controller/DIU/mode2_bmp_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode2_bmp.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/mode3_bmp.args" -o "UseCases/common/controller/DIU/mode3_bmp_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode3_bmp.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/mode4_bmp.args" -o "UseCases/common/controller/DIU/mode4_bmp_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/mode4_bmp.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/print_screen_1.args" -o "UseCases/common/controller/DIU/print_screen_1_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_1.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/print_screen_2.args" -o "UseCases/common/controller/DIU/print_screen_2_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/print_screen_2.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/uc_diu.args" -o "UseCases/common/controller/DIU/uc_diu_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/uc_diu_util.args" -o "UseCases/common/controller/DIU/uc_diu_util_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_util.c" -MD -gccdep
"C:/Freescale/CW_PA_v10.5.1/PA/PA_Tools/Command_Line_Tools/mwcceppc" @@"UseCases/common/controller/DIU/uc_diu_valid.args" -o "UseCases/common/controller/DIU/uc_diu_valid_c.obj" "C:/Program Files/Freescale/NetComm_Software/GA_4.4/NetCommSw/user/env/bare/UseCases/common/controller/DIU/uc_diu_valid.c" -MD -gccdep
..\..\..\..\..\GeneralBuildFlags\dflags.h:19: the file 'ansi_prefix.PPCEABI.bare.h' cannot be opened
..\..\..\..\..\GeneralBuildFlags\dflags.h:19: (included from:
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\build\bare_1022_cw_build\UseCases\controller\DIU\DiuUseCases.prefix:4
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   (command-line defines):1
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   (C-C++ Preprocessor Panel):1
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:1)
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303: undefined identifier 'uintptr_t'
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303: (included from:
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\inc\integrations\part_ext.h:23
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\inc\xx_ext.h:23
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\inc\system\sys_ext.h:16
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:14)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\usecases\common\main.c:1)
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\usecases\common\main.c:14)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\mode1_bmp.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\bmp_512.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\mode2_bmp.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\mode3_bmp.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\alpha3.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\alpha1.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\mode0_bmp.c:1)
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\inc\error_ext.h:22
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:16)
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.h:16
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:17)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\print_screen_2.c:1)
..\..\..\..\..\..\..\inc\integrations\P1022\part_integration_ext.h:303:         C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.c:17)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\alpha2.c:1)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321: illegal function definition
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325: declaration syntax error
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326: declaration syntax error
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329: declaration syntax error
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\print_screen_1.c:1)
..\..\..\..\..\GeneralBuildFlags\dflags.h:19:   C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\mode4_bmp.c:1)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321: (included from:
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.h:21
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.h:24
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:18)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325: (included from:
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.h:21
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.h:24
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:18)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326: (included from:
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.h:21
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.h:24
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:18)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329: (included from:
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu.h:21
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.h:24
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\common\controller\DIU\uc_diu_valid.c:18)
..\..\..\..\..\..\..\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:52: undefined identifier 'intptr_t'
..\..\..\..\..\..\..\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:56: undefined identifier 'args'
..\..\..\..\..\..\..\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:59: undefined identifier 'args'
..\..\..\..\..\..\..\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:67: illegal implicit conversion from 'int[5]' to
..\..\..\..\..\..\..\user\env\bare\UseCases\common\controller\DIU\uc_diu_util.c:67: 'int'
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\platform_settings.h:22
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:321:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:19)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\platform_settings.h:22
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:325:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:19)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\platform_settings.h:22
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:326:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:19)
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\platform_settings.h:22
..\..\..\..\..\..\..\user\env\bare\inc\services\ioctl_ext.h:329:        C:\Program Files\Freescale\NetComm_Software\GA_4.4\NetCommSw\user\env\bare\UseCases\integrations\P1022\DIU\diu_layout.c:19)
Errors caused tool to abort.
mingw32-make: *** [UseCases/common/controller/DIU/mode1_bmp_c.obj] Error 1
mingw32-make: *** Waiting for unfinished jobs....
mingw32-make: *** [UseCases/common/controller/DIU/bmp_512_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/mode2_bmp_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/mode3_bmp_c.obj] Error 1
mingw32-make: *** [UseCases/common/main_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/mode0_bmp_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/uc_diu_valid_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/uc_diu_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/uc_diu_util_c.obj] Error 1
mingw32-make: *** [UseCases/integrations/P1022/DIU/diu_layout_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/alpha3_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/alpha1_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/mode4_bmp_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/print_screen_2_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/alpha2_c.obj] Error 1
mingw32-make: *** [UseCases/common/controller/DIU/print_screen_1_c.obj] Error 1
%3CLINGO-SUB%20id%3D%22lingo-sub-1108212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI2C%20NCSW%E3%81%AE%E4%BD%BF%E7%94%A8%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ENCSW(NetComm%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2)%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEPowerQUICC%E3%81%8A%E3%82%88%E3%81%B3QorIQ%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%83%BB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AE%E9%96%8B%E7%99%BA%E3%82%92%E8%BF%85%E9%80%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81NCDD(NetComm%20Device%20Drivers)%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3GA_4.7%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BP3041%20I2C%E3%82%92%E4%BE%8B%E3%81%AB%E3%81%A8%E3%82%8A%E3%80%81NetComm%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%A7%8B%E9%80%A0%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BD%BF%E7%94%A8%E7%8A%B6%E6%B3%81%E3%82%92%E5%88%86%E6%9E%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CW%20PA%2010.3%20%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%82%92%E6%8C%81%E3%81%A4%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎12-21-2014 11:11 PM
更新者:
