Example MPC5644A eQADC channel 146 conversion+calibration CW210
File uploaded by David Tosenovjan Employee on Aug 7, 2014Last modified by David Tosenovjan Employee on Feb 7, 2020
Version 3Show Document
  • View in full screen mode
* Detailed Description:
* Initializes eQADC module, performs calibration and converts channel 146
* (voltage level of VDD) to check core voltage level and displays it into
* terminal window. No external connection required excluding terminal via eSCI.
* Test HW:        XPC564AKIT208S and XPC564AKIT324S
* MCU:            SPC5644AMMG1,0M14X and SPC5644AMVZ1,0M14X
* Fsys:           150/132/120/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
Outcomes
