Example MPC5606B SIUL External interrupt CW210
* Detailed Description:
* Enable external interrupt on pin PA[3].
* If falling edge is detected, interrupt is triggered and LED1 on PE[4] is
* toggled.
* Connect external signal to PA[3] or connect push button by wire.
* Test HW:  TRK-MPC5606B, SPC5606B 0N32E
* Target :  internal_FLASH, RAM
* Fsys:     64 MHz PLL with 8 MHz crystal reference
%3CLINGO-SUB%20id%3D%22lingo-sub-1112333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5606B%20SIUL%20External%20interrupt%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Enable%20external%20interrupt%20on%20pin%20PA%5B3%5D.%3C%2FP%3E%3CP%3E*%20If%20falling%20edge%20is%20detected%2C%20interrupt%20is%20triggered%20and%20LED1%20on%20PE%5B4%5D%20is%3C%2FP%3E%3CP%3E*%20toggled.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Connect%20external%20signal%20to%20PA%5B3%5D%20or%20connect%20push%20button%20by%20wire.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20TRK-MPC5606B%2C%20SPC5606B%200N32E%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20internal_FLASH%2C%20RAM%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2064%20MHz%20PLL%20with%208%20MHz%20crystal%20reference%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1112333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Enable%20external%20interrupt%20on%20pin%20PA%5B3%5D.%3C%2FP%3E%3CP%3E*%20If%20falling%20edge%20is%20detected%2C%20interrupt%20is%20triggered%20and%20LED1%20on%20PE%5B4%5D%20is%3C%2FP%3E%3CP%3E*%20toggled.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Connect%20external%20signal%20to%20PA%5B3%5D%20or%20connect%20push%20button%20by%20wire.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20TRK-MPC5606B%2C%20SPC5606B%200N32E%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20internal_FLASH%2C%20RAM%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2064%20MHz%20PLL%20with%208%20MHz%20crystal%20reference%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1112333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎08-04-2014 02:17 AM
Updated by:
