Example XPC564AKIT324S External SRAM test CW210
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* initializes interrupts, blinking one LED by interrupt, second LED by software
* loop, initializes and display notice via UART terminal and then terminal ECHO.
* The example configures the device for maximum performance (OPTIMIZATIONS_ON).
* IT INITIALIZES EBI FOR EXTERNAL SRAM CONNECTED TO XPC564AKIT324S AND TEST IT.
* Test HW:        XPC564AKIT324S
* MCU:            SPC5644AMVZ1 0M14X QAK1235G
* Fsys:           150/132/120/12 MHz
* Debugger:       Lauterbach Trace32
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
%3CLINGO-SUB%20id%3D%22lingo-sub-1118699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20XPC564AKIT324S%20External%20SRAM%20test%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20initializes%20interrupts%2C%20blinking%20one%20LED%20by%20interrupt%2C%20second%20LED%20by%20software%3C%2FP%3E%3CP%3E*%20loop%2C%20initializes%20and%20display%20notice%20via%20UART%20terminal%20and%20then%20terminal%20ECHO.%3C%2FP%3E%3CP%3E*%20The%20example%20configures%20the%20device%20for%20maximum%20performance%20(OPTIMIZATIONS_ON).%3C%2FP%3E%3CP%3E*%20IT%20INITIALIZES%20EBI%20FOR%20EXTERNAL%20SRAM%20CONNECTED%20TO%20XPC564AKIT324S%20AND%20TEST%20IT.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SPC5644AMVZ1%200M14X%20QAK1235G%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%20default%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1118699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%20freq.%2C%3C%2FP%3E%3CP%3E*%20initializes%20interrupts%2C%20blinking%20one%20LED%20by%20interrupt%2C%20second%20LED%20by%20software%3C%2FP%3E%3CP%3E*%20loop%2C%20initializes%20and%20display%20notice%20via%20UART%20terminal%20and%20then%20terminal%20ECHO.%3C%2FP%3E%3CP%3E*%20The%20example%20configures%20the%20device%20for%20maximum%20performance%20(OPTIMIZATIONS_ON).%3C%2FP%3E%3CP%3E*%20IT%20INITIALIZES%20EBI%20FOR%20EXTERNAL%20SRAM%20CONNECTED%20TO%20XPC564AKIT324S%20AND%20TEST%20IT.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SPC5644AMVZ1%200M14X%20QAK1235G%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%20default%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎07-07-2014 12:21 AM
Updated by:
