Tire Pressure Monitoring System (TPMS) - FXTH87
Demo Owner Mike Stanley
Tire Pressure Monitoring Systems (TPMS) help drivers with precise direct tire pressure measurement by providing individual tire readings – including the spare. NXP's world’s smallest, lowest-power, with highest memory for customer use TPMS is highly integrated with a pressure sensor, temperature sensor, accelerometer, MCU and a transmitter. Watch Mike Stanley explain the pressure sensor readings, temperature sensor display and the accelerometer/motion readings. These readings are time based periodic measurements where the data is given as an output to the driver.
Features
  • Simulation that portraits the TPMS as if it were inside the vehicles tires and sending reports to the vehicle's display unit about tire pressure
  • Module has the following: Pressure sensor, accelerometer, temperature sensor, low-frequency radio, Microcontroller
Featured NXP Products
Links
コメント
I can not find the demo ,how Can I get it?
How I can get Development kit or Reference design information of FXTH87 based TPMS? Thank you!
評価なし
バージョン履歴
最終更新日:
2 週間前
更新者:
