U-Boot Secondary Program Loader Authentication Vulnerability - CVE-2023-39902
Overview
A software vulnerability - CVE-2023-39902 has been identified in the U-Boot Secondary Program Loader (SPL) prior to version 2023.07 on select i.MX 8M family processors. Under certain conditions, a crafted Flattened Image Tree (FIT) Format structure can be used to overwrite SPL memory, allowing unauthenticated software to execute on the target leading to a privilege escalation.
Impacted devices
NXP Devices
Impacted Silicon Revisions
i.MX 8M
All
i.MX 8M Nano
All
i.MX 8M Mini
All
i.MX 8M Plus
All
Mitigation
This section will cover possible mitigations identified by NXP and recommends users review this vulnerability against their specific use cases.  These mitigations may have varying applicability based on the customer’s designs and should be reviewed based on the established security policy that defines the security goals of the end product. It is up to the user to determine the impact (if any) to their products and take any necessary mitigation actions.
U-Boot software patches to address this vulnerability(CVE-2023-39902) were incorporated in the NXP BSP GA Release  LF6.1.36_2.1.0 available for download on nxp.com. All subsequent NXP BSP GA software releases will incorporate the mitigations.
To support the default hash and optional FDT signature solutions - four patches for u-boot (one patch only required for Android and one for a document update),  and two patches for imx-mkimage have been developed. Only one mitigation solution needs to be adopted if impacted.
Mitigation Patches
Comments
U-Boot
0746cfd LFU-573-1 imx8m: hab:Verify hash of FIT FDT structure
Default Hash solution
07b6882 LFU-573-2 imx8m: hab:Verify optional FIT FDT signature
Optional FIT DT signature solution
0001-MA-21597 check spl fit pointer before parsing it
Only Required for Android
25fdc42 LFU-573-3 doc: imx8m:
Update iMX8M secure boot and encrypted boot doc
Documentation update
imx-mkimage
2f2d426 LFU-573-1 imx8m:
Generate hash of FIT FDT structure to SPL image
5a0faef LFU-573-2 imx8m:
Reserve new IVT+CSF for FIT FDT signature
Additional Information
Customers authenticating additional software images from a bootloader not provided by an NXP BSP, should ensure correct authentication is being performed.
For additional information, please contact your NXP Account Manager or Field Representative. You can also enter a technical support ticket and an NXP support engineer will contact you.
Acknowledgment
NXP would like to thank  Marek Vasut of DENX Software Engineering GmbH for the responsible disclosure.
_____________________________________________________________________________
Please note this information is preliminary and subject to change. To the best of NXP's knowledge, the information contained herein is accurate and reliable as of the date of publication; however, NXP does not assume any liability for the accuracy and completeness of the information
100% helpful (1/1)
Version history
Last update:
‎10-17-2023 06:52 AM
Updated by:
