where to find i.MX MCU Manufacturing User's Guide
998件の閲覧回数
mastupristi
Senior Contributor I
I was looking for information on CSF layout, and syntax + reference of .sb files relative to RT117x.
I searched on NXP search engine for the keyword `SEC_CSF_INSTALL_SRK` (for example) and found nothing. I googled the same thing and found this (IMXMCUMFUUG, rev 0, 10/2017).
This file, though, was missing the description of some keywords that I had in one of my .sb file instead. So I searched both `MCU Manufacturing User's Guide` and `IMXMCUMFUUG` on NXP search engine, but found nothing.
So again I googled for one of the missing keywords and found this (IMXMCUMFUUG, rev 1, 01/2018).
Does it seem normal to you that these documents, which I think are very useful and important, are not properly indexed by NXP while you have to google to find them in your community?
Does it seem normal to you that such useful and important documents do not have dedicated pages that are easy to find?
Does it seem normal to you that I do not know how to search if there are new revisions of this document?
Where can I find links to these files in your community?
best regards
Max
903件の閲覧回数
DanielRuvalcaba
Rev. 1 , 01/2018 is the one available in the Flash bootloader. This should be the latest one.
Daniel.
3 返答(返信)
935件の閲覧回数
DanielRuvalcaba
The documents you mention are based on the RT1050-EVK. You can find the latest version of this document in the Flash bootloader for i.MX RT1050 bundle (this is also described in AN12238). If you download the previous bundle from the Software option on the RT1050 webpage, you will be able to see the document in the doc directory. This is why you couldn't find it in the community search engine.
Nevertheless, I will report this to the corresponding team.
Daniel.
911件の閲覧回数
mastupristi
What is the latest revision of this document?
904件の閲覧回数
DanielRuvalcaba
Daniel.
