usb code run on sdram failed in rt1170
1,098 次查看
jingyangxie
Contributor V
I have a imxrt1170 board, want to run code on sdram, when I debug with iar 9.30,the usb does not work correctly , but when I debug the code on ram , it works fine. the two link files are attachments
4 回复数
1,087 次查看
jingyangxie
Contributor V
I've follow these posts, and add definition DATA_SECTION_IS_CACHEABLE=1,  and the link file set the noncache region:
after these ,the usb code debug on sdram still can not work
1,084 次查看
jingpan
Hi @jingyangxie ,
Most of these kinds of problem is caused by cache. Please check carefully if the buffers used by both CPU and USB DMA are allocated in noncacheable area. I also suggest to put heap and stack in noncacheable area too.
jing
1,077 次查看
jingyangxie
Contributor V
ok, I will check it carefully.thanks
