Hi all,
I find the default semc clock frequency is around 163Mhz in evkbmimxrt1060_semc sample code.
And the clock frequency is changed to about 109Mhz when I set the value of kCLOCK_SemcDiv to 2.
However, I want to change the clock frequecny to 133Mhz.
So how could I reduce the semc clock to 133Mhz?
Doris
Solved! Go to Solution.
You can achieve 132MHz SEMC_CLK_ROOT by removing the line CLOCK_InitSys_Pdf() [this leaves PLL2-PDF2 at its default value of 396MHz] or setting it to CLOCK_InitSys_Pdf(24).
and setting CLOCK_SetDiv(KClock_SemcDiv, 2).
For the explications see pages 20 and 5 of https://www.utasker.com/docs/iMX/i.MX_RT_1021_uTasker.pdf
Mark
For i.MX and Kinetis stock availability see https://www.utasker.com/Shop/semi.html
Mark
