Could you please inform me if there is a 3.5 inch LCD screen compatible with mimxrt1170-evkb card
Solved! Go to Solution.
We do not have specific LCD parts that we can recommend beyond those mentioned above. Since they are the only ones for which we have demos.
What you need to focus on is choosing MIPI DSI-compliant LCDs to take advantage of the RT1170's dedicated graphics features.
Thanks for contacting our technical support.
The LCDs that we have drivers and SDK examples for the RT1170 are:
5.5" LCD Panel RK055HDMIPI4MA0
Hope it helps you.
Have a nice day!
Thank you for your answer. I now own a 5.5-inch screen, but is there a 3.5-inch screen compatible with that board? I need it for a project.
Or what would you recommend using to fulfill my needs?
