build error : cmsis_lpspi
758 次查看
hamatron
I tried to build by importing lpspi_cmsis but failed with the following error:
undefined reference to `LPSPI1_DeinitPins'
undefined reference to `LPSPI1_InitPins'
Should i define these in my code ?
714 次查看
victorjimenez
You need to have these two functions in the files pin_mux.c and pin_mux.h. Within the SDK for the RT1020-EVK, we provide an example that uses the lpspi_cmsis drivers, I highly recommend you to check this project to see the functions that you are missing.
TIC
