We want to use Winbond QSPI Flash with the iMXRT685. (FlexSPI)
Is the above flash part W25X40CLSNIG compatible for iMXRT685 FlexSPI flashing?
RT685: MIMXRT685SFVKB
SPI-NORFlash:W25X40CLSNIG(Winbond)
Please let us know. Any support on the above query will be really helpful
Thanks and Best Regards,
Satoshi Kawasaki
Dear @satoshikawasaki
Thanks a lot for reaching our technical support.
Regarding the flash memory part you mentioned, it is not listed on our Secure Provisioning Tool, but if you click on edit button, you may modify some parameters so can have compatibility with it.
Please see the next picture from SPTool:
Hope this tool can help you to configure it, otherwise, you may try to use another useful tool from a teammate JayHeng to find the memory you want to use.
BR.
Pablo Avalos.
