Hello, looking for a Wi-Fi + BT solution for NXPs i.MX RT 1060 evk. It does not seem to come with Wi-Fi/BT built-in? Any suggestions?
Romit Chatterjee
Solved! Go to Solution.
Hello Romit,
You can use Murata's M.2 module (i.e. Wi-Fi+BT combo solution) for the i.MX RT board. There are three M.2 modules i.e Type 1DX, Type 1LV and Type 1MW EVB which are compatible with NXP's i.MX RT 1060 EVK. Till now NXP SDK only includes support for 1DX and 1LV modules. Type 1MW is scheduled to be included in their upcoming release. Please refer to the links below to learn more about our M.2 modules:
https://wireless.murata.com/type-1dx.html
https://wireless.murata.com/type-1lv.html
https://wireless.murata.com/type-1mw.html
Also, here is the link to the quick start guide to get started with i.MX RT 1060 using M.2 modules:
https://wireless.murata.com/pub/RFM/data/murata_quick_start_guide_freertos.pdf
Puja
Thanks Tomohiro san, Puja and Markus! Much appreciated for your answers. These should be enough for now to get me started.
Best regadrs,
Romit
Hello Romit,
NXP is using “SX-ULPAN-2401-SHIELD” and “Murata 1DX M.2 module” in there SDK-Examples. Maybe this could be a good starting position.
Best Regards
Hello Romit,
Puja
Hi Romit,
The SDK 2.5.1 supports Murata Type1DX Wifi/Bluetooth combo module if you add additional components (basically 'select all' helps) when you download the SDK.
You can check our quick start guide to learn more about the details: https://wireless.murata.com/datasheet?/RFM/data/murata_quick_start_guide_freertos.pdf
Here is the adapter board information: https://wireless.murata.com/usd-m2
Here is the stock information for the adapter board: https://www.eciaauthorized.com/en/search/LBEE0ZZ1WE
Here is the stock information for the 1DX M.2 Module board: https://www.eciaauthorized.com/en/search/EAR00318
Tom Inoue
