I implemented the USB MSC for RT1062 from the example in my firmware, everything is working right on windows PC, but if I connect a MAC the computer doesn't recognize the disk, ask for mount device as a disk, and also if I proceed it can't mount the disk and fail.
What we can check? Is there someone who has already worked with this on MacOsX?
The Mac is running the last version (Monterey)
Thank in advance
Alessio
Try some uTasker 1062 USB binaries at https://www.utasker.com/iMX/RT1060.html
These include various classes and composites - including MSD to SD card or internal flash file system.
These work on Windows, Linux and MAC (at least when they were last tested) and it represents an industrial proven, turn-key solution for quality products.
Documented and supported by professionals for professionals.
Mark
https://www.utasker.com/iMX/developers.html
is there a way to change usb descriptor? is there some documentation about it?
