I'm exploring the option of using the SNVS real time counter as a polled PIT. The SDK demo projects don't use the counter that way. I'm wondering how do I determine the period of the counter programmatically?
Ellen
Hi Ellen Stacey,
I'm not very clear with your question, whether you can want to implement the periodic Interrupt feature of the RTC, if yes, please refer to snvs_hp_rtc demo in the SDK library.
TIC
Hi Ellen Stacey,
Thank you for your clarification。
It means that you want to monitor the counter value to evaluate the elapsed time, and it needs to modify the rtc demo in the SDK library by yourself to implement that.
TIC
Hi Ellen Stacey,
Thanks for your reply.
The RTC clock source is from either Internal ring oscillator or RTC_XTAL (external crystal), in general, the internal oscillator is not precise relative to a crystal and RTC oscillators are either implemented with 32 kHz or 32.768 kHz crystals.
The RTC clock period won't change via the software code once the clock source has been selected.
TIC
