RT1051 IDCODE mismatch
974 次查看
Alcor
with MIMXRT1050-EVK, I get IDCODE 0x0BA02477.
The bsdl file provided by the website shows IDCODE 0x088C301D.
And IMXRT1050RM has jtag ID 188C_301Dh.
Do you know why it is different when read on MIMXRT1050-EVK board?
Thanks for the help.
Best Regards
963 次查看
Alcor
Solution found.
JTAG_MOD has a pulldown, Remove it to read the right IDCODE on Eval board.
Follow this application note which it explains:
https://www.nxp.com/docs/en/application-note/AN12919.pdf
what you have on BSDL is 088C_301Dh, modify  it to 188C_301Dh to have same IDCODE.
Best regards.
964 次查看
Alcor
Solution found.
Best regards.
