Hey people,
i have an RT1050-EVKB board and want to run code from the QSPI memory.
I can configure read/write/erase it via mcuexpresso but when trying to debug there is a hardfault.
Also the flash downloadspeed is reported as 1000KB/s which cannot be.
I'm using the MIMXRT1050-EVK_IS25WP064A.cfx driver.
Is there a step-by-step guide on how to configure a project to run from the QSPI?
I'm also confused about the function of the xip folder that is generated with my project. There is a "hyperflash_config" structure, but i cannot find "qspi_config" one.
Thank you!
Solved! Go to Solution.
Found a solution, did what was said in this thread:
