It seems that the following fuse is blown during manufacture. I just want to confirm that this is expected:
Fuse Address: 0x6D0[6]
Fuses Name: USB_VBUS_EVENT_HANDLER_EN
Number of fuses: 1
Fuses Function: Rom handle USB VBUSattach/detach event
Setting: 0 - ROM not handle USB VBUS attach/detach event
1 - ROM handle USB VBUS attach/detach event
Locked by: MISC_CONF_LOCK
Kind regards,
Ronnie
Solved! Go to Solution.
Hi @rshipman
I checked my MIMXRT1020-EVK board, the default fuse map:
You can find, your mentioned 0x6d0[6]=1, so it is factory blown.
Wish it helps you!
kerry
Hi @rshipman
Wish it helps you!
kerry
Thank you Kerry.
