We're using RT1051 chip with newlib-nano library, for some reason we need to rebuild the library to help investigate a context switching issue, I've downloaded the source code, but I don't know the parameters and commands to run the build, can someone help to provide some guidance? thanks.
Thanks @CarlosGarabito, but the page you mentioned seems not existing anymore, can you please double check? thanks.
Hi @mark_li , you can see an excellent blog where can learn a lot of things https://mcuoneclipse.com/tag/newlib/read through each of the topics and immerse yourself in knowledge
Have a good day
