Does RT 1050/1052 have the function of doing FIR/IIR filter function?
Our current project using the RT 1050/1052 to capture the ECG signal and process. The ECG data need be filtered with FIR multiband filter and 50/60 hz notch filter. I want to know if RT 1052/1050 hard ware support the filter in the hardware level. And if there is any sample code or library for this?
Regarding hardware implementation of digital filters, you could refer to CMSIS-DSP software library.
On the MCUXpresso SDK, there are included some CMSIS-related examples.
Regarding EKG implementation (with software FIR filters), you could take a look at the following links:
https://www.nxp.com/pages/electrocardiograph-development-kit-for-tower-system:MED-EKG
https://www.nxp.com/docs/en/application-note/AN4323.pdf
https://www.nxp.com/docs/en/application-note/AN4644.pdf
Hope this will be useful for you.
Best regards!
/Carlos
