DAC on MIMXRT1064
DAC on MIMXRT1064
1,356 次查看
markus_winkhoef
Hello NXP Community,
does the RT1064 controller contains a DAC output with which i can provide an analog voltage to a Pin on the microcontroller?
Markus
1,271 次查看
mjbcswitzerland
Specialist V
Hi Markus
The RT1064 doesn't have a DAC for external use but DACs can be made with a PWM output and an RC filter, which may be a suitable solution for your case.
Mark
[uTasker project developer for Kinetis and i.MX RT]
1,272 次查看
mjbcswitzerland
Specialist V
Hi Markus
Mark
