Application of AIPS lite
Newton829
Hello All,
   The I.MXRT1176 has a chapter on AIPS-Lite
1.What is it significance?
2.How is it used in an embedded application?
Thank you,
Gavin_Jia
Hi @Newton829 ,
Thanks for your interest in NXP MIMXRT series. I'd like to provide service for you!
The Peripheral Bridge (AIPS-Lite) is used as a bus protocol converter between the Crossbar switch (AXBS-Lite) and the slave peripheral buses. the AIPS Lite converts the Crossbar switch interface into an interface that can access slave devices. It is used to connect different bus protocols.It can access most of the slave devices on the chip.
Gavin
