Could let me know what is minimum delay times between VDD_SNVS_IN and VDD_HIGH_IN and DCDC_IN?
According to datasheet, reference manual and hardware development guide, "VDD_SNVS_IN supply must be turned on before any other power supply or be connected (shorted) with VDD_HIGH_IN supply", but it has not description between VDD_HIGH_IN and DCDC_IN, and if we use different power source between VDD_SNVS_IN and DCDC_IN.
Please let me know each of the minimum delay times.
Deega
解決済! 解決策の投稿を見る。
Hi @deega_jung ,
There isn't minimum delay requirement between VDD_HIGH_IN and DCDC_IN. In some simplified design, the power pin can be connected together.
PSWITCH is the most important. Please refer to the hardware development guide, MIMXRT105060HDUG.pdf.
Jing
Hi @deega_jung ,
Jing
Hi Jing,
how does this simplified design meet the conditions for DCDC_PSWITCH?
Is the simplified design also useable if SNVS_IN is additional powered by a battery?
Thomas
Hi Jing,
Thank you for your reply. It helped me a lot.
Deega
