Hi all
On current git tree ,
In imx.c , when operate with tty .break_ctl
734 static void imx_break_ctl(struct uart_port *port, int break_state)
735 {
736 struct imx_port *sport = (struct imx_port *)port;
737 unsigned long flags, temp;
738
739 spin_lock_irqsave(&sport->port.lock, flags);
740
741 temp = readl(sport->port.membase + UCR1) & ~UCR1_SNDBRK;
742
743 if ( break_state != 0 )
744 temp |= UCR1_SNDBRK;
You miss the revert back the register of UCR1_SNDBRK
This should be a bug , here is the patch . please check and approve
Original Attachment has been moved to: tty_imx_brk.patch.zip
解決済! 解決策の投稿を見る。
Your patch :
--- a/drivers/tty/serial/imx.c
+++ b/drivers/tty/serial/imx.c
@@ -739,6 +739,8 @@ static void imx_break_ctl(struct uart_port *port, int break_state)
+ else
+ temp &= ~UCR1_SNDBRK;
But from original code :
Is that same as your change?
Hi Xiongwei, is Fushi's reply help your question? If yes, please close the DI, oherwise please keep working with him.
Yixing
Your patch :
+ else
