tflite_runtime + NNAPI stops working when a computational heavy thread is started
1,418 次查看
FSet89
I am working on a script that is deployed on a IMX8MP with NPU and NNAPI. The script makes inferences using the tflite_runtime library. If a thread is started producing a high cpu usage, tflite stops working, producing always the same result regardless of the input. I provided a minimum working example on github. The problem is not encountered on my PC. Is it related to NNAPI?
8 回复数
1,398 次查看
Zhiming_Liu
Hi @FSet89
Can you share your test script ,model and steps?
1,370 次查看
FSet89
Hi, I tried to share the code but my reply keeps getting deleted. However you can find the code in the linked github issue. I cannot share the model but you can try with any quantized tflite model.
1,312 次查看
Zhiming_Liu
Please try the vx_delegate not NNAPI. The NNAPI is not maintained by NXP
 delegate = tflite.load_delegate('/usr/lib/libvx_delegate.so')
 self.interpreter = tflite.Interpreter(model_path=path, experimental_delegates=[delegate])
1,293 次查看
FSet89
Thank you for your suggestion. I don't have the vx_delegate in my Yocto system. Can you provide me some reference about how to add it to Yocto?
1,270 次查看
Zhiming_Liu
Hi @FSet89
You can refer the i.MX Yocto Project User’s Guide​ to dowlnad i.MX yocto project from this website https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
Then copy the layer /sources/meta-imx/meta-ml/ to your Yocto project.
898 次查看
FSet89
Hi @Zhiming_Liu , I already have this layer but I don't have /usr/lib/libvx_delegate.so in my compiled system. Should I edit my recipe?
1,359 次查看
FSet89
Hi @Zhiming_Liu , here is the code. I cannot share the model but you can try with any quantized tflite model:
import multiprocessing
from multiprocessing import Queue, Process
import numpy as np
from threading import Thread
from random import random, randint
import tflite_runtime.interpreter as tflite
import time
import cv2
import os
import sys
import psutil
class ClassificationModel(object):
	def __init__(self, path, mask_path=None):
		self.interpreter = tflite.Interpreter(model_path=path)
		self.interpreter.allocate_tensors()
		self.input_details = self.interpreter.get_input_details()
		self.output_details = self.interpreter.get_output_details()
		self.input_shape = self.input_details[0]['shape']
	def predict(self, img, resize=True):
		if resize:
			img = cv2.resize(img, (self.input_shape[2], self.input_shape[1]))
		img = (img/255.0).astype(np.float32)
		img = np.expand_dims(img, 0)
		self.interpreter.set_tensor(self.input_details[0]['index'], img)
		self.interpreter.invoke()
		output = self.interpreter.get_tensor(self.output_details[0]['index'])
		output = np.squeeze(output)
		return output
def my_thread_1():
	print("Start threaded task 1")
	simulate_cpu_load()
	print("Task 1 completed")
def worker():
	while True:
		pass
def simulate_cpu_load():
	num_cores = multiprocessing.cpu_count()
	processes = []
	for _ in range(num_cores):
		p = multiprocessing.Process(target=worker)
		p.start()
		processes.append(p)
	time.sleep(3)
	for p in processes:
		p.terminate()
if __name__ == '__main__':
	classifier_1 = ClassificationModel('mymodel.tflite)
	cap = cv2.VideoCapture()
	for i in range(5):
		cap.open(i)
		if cap.isOpened():
			break
	if not cap.isOpened():
		print("Could not open camera")
		exit()
	try:
		while True:
			# get image
			ret, img = cap.read()
			# predict
			p1 = classifier_1.predict(img)
			print(p1)
			# threaded task
			if random() < 0.1:
				t = Thread(target=my_thread_1)
				t.start()
	except(KeyboardInterrupt):
		exit()
1,238 次查看
FSet89
Hi, here is the code. I cannot share the model but you can try with any quantized tflite model.
import numpy as np
import time
import cv2
import os
import sys
import psutil
		if resize:
		return output
def my_thread_1():
	simulate_cpu_load()
def worker():
	while True:
		pass
	processes = []
		p.start()
		processes.append(p)
	time.sleep(3)
	for p in processes:
		p.terminate()
	for i in range(5):
		cap.open(i)
		if cap.isOpened():
			break
		exit()
	try:
		while True:
			# get image
			# predict
			print(p1)
			# threaded task
			if random() < 0.1:
				t.start()
		exit()
