running iMX6 at 1GHz
729 次查看
randyfung
Is it just drop in replacement and configure registered or is there any HW change to run @ 1Ghz?
Please advise.
Thanks.
Randy
633 次查看
randyfung
The P/N we used is MCIMX6U1AVM08ACR.
Randy
633 次查看
joanxie
refer to the data sheet as below, pls find the Table 1 and Figure 1, the part number you use is limited up to 800Mhz
https://www.nxp.com/docs/en/data-sheet/IMX6SDLCEC.pdf
633 次查看
joanxie
what i.mx6 part number do you use? differenct part number stands for different frequency.
