Hi all,
I have a mx28 board with a NXP PCF85163 rtc chip using i2c bus.
Recently I found when set the time to the last minutes of the year(take 2016-12-31 23:59:00 as an example), and one minute later rtc time turn to 1970-1-1 00:00:00
Test for any time but other than the last day of a year is OK.
Is this the chip's problem? Any one came across similar problem ever?
Thanks in advance!
Solved! Go to Solution.
Hello hk,
The question is the same as that of a Chinese customer, I don't know whether you are same people, if you can understand Chinese, see the link, please!
rtc芯片设置时间后重新回到1970年-恩智浦MCU论坛论坛 - 21ic电子技术论坛
The chinese customer found and solved the issue, the root cause is : The valuse of register for Month starts from 1, but in kernel, 1 is taken from the value and access arry, so error will occur.
Weidong
Hello hk,
Weidong
是的,我就是那个Chinese customer.
Thanks!
