hi all,
in my ucl2.xml:
Header 1 |
<LIST name="i.MX6SOLO-SABRESD-SD" desc="Choose SD as media"> <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6solo-sabresd.bin" >Loading U-boot</CMD> <CMD state="BootStrap" type="load" file="uImage" address="0x10800000" loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD> <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000" loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD> <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD> <CMD state="Updater" type="push" body="$ ls /dev/">ls -l /dev/</CMD> |
on terminal:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 15:02:51)CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 40 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 Using default environmentIn: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35-2666-gbdde708 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3165516 Bytes = 3 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 10c00000 ... Image Name: uboot initramfs rootfs Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4545326 Bytes = 4.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Kernel Image ... OK OKStarting kernel ...Uncompressing Linux... done, booting the kernel. Linux version 3.0.35-2666-gbdde708 (r65388@shlinux3) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09 :20) ) #1 SMP PREEMPT Fri Aug 16 14:34:30 CST 2013 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board Memory policy: ECC disabled, Data cache writealloc CPU identified as i.MX6DL/SOLO, silicon rev 1.1 PERCPU: Embedded 7 pages/cpu @8bc06000 s5184 r8192 d15296 u32768 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97280 Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 384MB = 384MB total Memory: 377924k/377924k available, 146364k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xa0800000 - 0xf2000000 (1304 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003a000 ( 200 kB) .text : 0x8003a000 - 0x805ada70 (5583 kB) .data : 0x805ae000 - 0x805fc880 ( 315 kB) .bss : 0x805fc8a4 - 0x806277f4 ( 172 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms Set periph_clk's parent to pll2_pfd_400M! arm_max_freq=800MHz MXC_Early serial console at MMIO 0x2020000 (options '115200') bootconsole [ttymxc0] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available Brought up 1 CPUs SMP: Total of 1 processors activated (1581.05 BogoMIPS). print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B bio: create slab <bio-0> at 0 mxs-dma mxs-dma-apbh: initialized print_constraints: SPKVDD: 4200 mV print_constraints: vmmc: 3300 mV SCSI subsystem initialized spi_imx imx6q-ecspi.0: probed usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb mc_pfuze 1-0008: recv failed!:-5,80 mc_pfuze: probe of 1-0008 failed with error -1 imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized max17135 2-0048: PMIC MAX17135 for eInk display i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 5, 196608 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Freeing initrd memory: 4436K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is disabled for i.MX6 cpaddr = a0820000 suspend_iram_base=a08b4000 PM driver module loaded IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 746 cryptodev: driver loaded. io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb _regulator_get: get() with no identifier imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) Console: switching to colour frame buffer device 128x48 mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Serial: IMX driver imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX console [ttymxc0] enabled, bootconsole disabled console [ttymxc0] enabled, bootconsole disabled loop: module loaded m25p80 spi0.0: unrecognized JEDEC id ffffff GPMI NAND driver registered. (IMX) vcan: Virtual CAN interface driver FEC Ethernet Driver fec_enet_mii_bus: probed Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. ARC USBOTG Device Controller driver (1 August 2005) add wake up source irq 75 g_file_storage gadget: controller 'fsl-usb2-udc' not recognized check_parameters:UTP settings are in place now, overriding defaults g_file_storage gadget: No serial-number string provided! g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010 g_file_storage gadget: Number of LUNs=1 fsl-usb2-udc: bind to driver g_file_storage mousedev: PS/2 mouse device common for all mice egalax_ts 1-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 1-0004 failed with error -5 egalax_ts 2-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 2-0004 failed with error -5 snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered usbcore: registered new interface driver usbhid usbhid: USB HID core driver Cirrus Logic CS42888 ALSA SoC Codec Driver i2c-core: driver [cs42888] using legacy suspend method i2c-core: driver [cs42888] using legacy resume method imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first. imx_3stack asoc driver ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 Bus freq driver module loaded Bus freq driver Enabled mxc_dvfs_core_probe DVFS driver module loaded regulator_init_complete: SPKVDD: incomplete constraints, leaving on snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) Freeing init memory: 200K Starting UTP ln: /etc/mtab: File exists disable turn off display Starting the hotplug events dispatcher udevd Synthesizing initial hotplug events udevd (2079): /proc/2079/oom_adj is deprecated, please use /proc/2079/oom_score_adj instead. g_file_storage gadget: high speed config #1 uuc 0.4 [built Aug 16 2013 01:24:08] UTP: Waiting for device to appear UTP: file/device node /dev/utp already exists cpu_id is 0 UTP: received command '$ ls /dev/' UTP: executing "ls /dev/" XOR ptyra tty25 ttyr0 apm_bios ptyrb tty26 ttyr1 console ptyrc tty27 ttyr2 cpu_dma_latency ptyrd tty28 ttyr3 crypto ptyre tty29 ttyr4 fb ptyrf tty3 ttyr5 fb0 ptys0 tty30 ttyr6 fb1 ptys1 tty31 ttyr7 fb2 ptys2 tty32 ttyr8 full ptys3 tty33 ttyr9 i2c-0 ptys4 tty34 ttyra i2c-1 ptys5 tty35 ttyrb i2c-2 ptys6 tty36 ttyrc i2c-3 ptys7 tty37 ttyrd input ptys8 tty38 ttyre kmem ptys9 tty39 ttyrf kmsg ptysa tty4 ttys0 loop0 ptysb tty40 ttys1 loop1 ptysc tty41 ttys2 loop2 ptysd tty42 ttys3 loop3 ptyse tty43 ttys4 loop4 ptysf tty44 ttys5 loop5 ptyt0 tty45 ttys6 loop6 ptyt1 tty46 ttys7 loop7 ptyt2 tty47 ttys8 mem ptyt3 tty48 ttys9 mxc_asrc ptyt4 tty49 ttysa mxc_hdmi ptyt5 tty5 ttysb mxc_ipu ptyt6 tty50 ttysc mxc_mem ptyt7 tty51 ttysd mxc_vpu ptyt8 tty52 ttyse mxs_viim ptyt9 tty53 ttysf network_latency ptyta tty54 ttyt0 network_throughput ptytb tty55 ttyt1 null ptytc tty56 ttyt2 psaux ptytd tty57 ttyt3 ptmx ptyte tty58 ttyt4 pts ptytf tty59 ttyt5 ptya0 ptyu0 tty6 ttyt6 ptya1 ptyu1 tty60 ttyt7 ptya2 ptyu2 tty61 ttyt8 ptya3 ptyu3 tty62 ttyt9 ptya4 ptyu4 tty63 ttyta ptya5 ptyu5 tty7 ttytb ptya6 ptyu6 tty8 ttytc ptya7 ptyu7 tty9 ttytd ptya8 ptyu8 ttya0 ttyte ptya9 ptyu9 ttya1 ttytf ptyaa ptyua ttya2 ttyu0 ptyab ptyub ttya3 ttyu1 ptyac ptyuc ttya4 ttyu2 ptyad ptyud ttya5 ttyu3 ptyae ptyue ttya6 ttyu4 ptyaf ptyuf ttya7 ttyu5 ptyb0 ptyv0 ttya8 ttyu6 ptyb1 ptyv1 ttya9 ttyu7 ptyb2 ptyv2 ttyaa ttyu8 ptyb3 ptyv3 ttyab ttyu9 ptyb4 ptyv4 ttyac ttyua ptyb5 ptyv5 ttyad ttyub ptyb6 ptyv6 ttyae ttyuc ptyb7 ptyv7 ttyaf ttyud ptyb8 ptyv8 ttyb0 ttyue ptyb9 ptyv9 ttyb1 ttyuf ptyba ptyva ttyb2 ttyv0 ptybb ptyvb ttyb3 ttyv1 ptybc ptyvc ttyb4 ttyv2 ptybd ptyvd ttyb5 ttyv3 ptybe ptyve ttyb6 ttyv4 ptybf ptyvf ttyb7 ttyv5 ptyc0 ptyw0 ttyb8 ttyv6 ptyc1 ptyw1 ttyb9 ttyv7 ptyc2 ptyw2 ttyba ttyv8 ptyc3 ptyw3 ttybb ttyv9 ptyc4 ptyw4 ttybc ttyva ptyc5 ptyw5 ttybd ttyvb ptyc6 ptyw6 ttybe ttyvc ptyc7 ptyw7 ttybf ttyvd ptyc8 ptyw8 ttyc0 ttyve ptyc9 ptyw9 ttyc1 ttyvf ptyca ptywa ttyc2 ttyw0 ptycb ptywb ttyc3 ttyw1 ptycc ptywc ttyc4 ttyw2 ptycd ptywd ttyc5 ttyw3 ptyce ptywe ttyc6 ttyw4 ptycf ptywf ttyc7 ttyw5 ptyd0 ptyx0 ttyc8 ttyw6 ptyd1 ptyx1 ttyc9 ttyw7 ptyd2 ptyx2 ttyca ttyw8 ptyd3 ptyx3 ttycb ttyw9 ptyd4 ptyx4 ttycc ttywa ptyd5 ptyx5 ttycd ttywb ptyd6 ptyx6 ttyce ttywc ptyd7 ptyx7 ttycf ttywd ptyd8 ptyx8 ttyd0 ttywe ptyd9 ptyx9 ttyd1 ttywf ptyda ptyxa ttyd2 ttyx0 ptydb ptyxb ttyd3 ttyx1 ptydc ptyxc ttyd4 ttyx2 ptydd ptyxd ttyd5 ttyx3 ptyde ptyxe ttyd6 ttyx4 ptydf ptyxf ttyd7 ttyx5 ptye0 ptyy0 ttyd8 ttyx6 ptye1 ptyy1 ttyd9 ttyx7 ptye2 ptyy2 ttyda ttyx8 ptye3 ptyy3 ttydb ttyx9 ptye4 ptyy4 ttydc ttyxa ptye5 ptyy5 ttydd ttyxb ptye6 ptyy6 ttyde ttyxc ptye7 ptyy7 ttydf ttyxd ptye8 ptyy8 ttye0 ttyxe ptye9 ptyy9 ttye1 ttyxf ptyea ptyya ttye2 ttyy0 ptyeb ptyyb ttye3 ttyy1 ptyec ptyyc ttye4 ttyy2 ptyed ptyyd ttye5 ttyy3 ptyee ptyye ttye6 ttyy4 ptyef ptyyf ttye7 ttyy5 ptyp0 ptyz0 ttye8 ttyy6 ptyp1 ptyz1 ttye9 ttyy7 ptyp2 ptyz2 ttyea ttyy8 ptyp3 ptyz3 ttyeb ttyy9 ptyp4 ptyz4 ttyec ttyya ptyp5 ptyz5 ttyed ttyyb ptyp6 ptyz6 ttyee ttyyc ptyp7 ptyz7 ttyef ttyyd ptyp8 ptyz8 ttymxc0 ttyye ptyputp_poll: pass returned. 9 ptyz9 ttymxc2 ttyyf ptypa ptyza ttyp0 ttyz0 ptypb ptyzb ttyp1 ttyz1 ptypc ptyzc ttyp2 ttyz2 ptypd ptyzd ttyp3 ttyz3 ptype ptyze ttyp4 ttyz4 ptypf ptyzf ttyp5 ttyz5 ptyq0 random ttyp6 ttyz6 ptyq1 rfkill ttyp7 ttyz7 ptyq2 rtc ttyp8 ttyz8 ptyq3 rtc0 ttyp9 ttyz9 ptyq4 shm ttypa ttyza ptyq5 snd ttypb ttyzb ptyq6 tracebuf ttypc ttyzc ptyq7 tty ttypd ttyzd ptyq8 tty0 ttype ttyze ptyq9 tty1 ttypf ttyzf ptyqa tty10 ttyq0 ubi_ctrl ptyqb tty11 ttyq1 urandom ptyqc tty12 ttyq2 utp ptyqd tty13 ttyq3 vcs ptyqe tty14 ttyq4 vcs1 ptyqf tty15 ttyq5 vcsa ptyr0 tty16 ttyq6 vcsa1 ptyr1 tty17 ttyq7 vhci ptyr2 tty18 ttyq8 video16 ptyr3 tty19 ttyq9 video17 ptyr4 tty2 ttyqa video18 ptyr5 tty20 ttyqb watchdog ptyr6 tty21 ttyqc zero ptyr7 tty22 ttyqd ptyr8 tty23 ttyqe ptyr9 tty24 ttyqf UTP: sending Success to kernel for command $ ls /dev/. |
thanks sincerely.
Message was edited by: Eddy Liu
Solved! Go to Solution.
Hi Eddy,
You need set boot parameters. Please reference 9.2 Running the Image from MMC/SD of i.MX_6Solo6DualLite_SABRE-AI_Linux_User's_Guide.pdf to set your boot command.
Grace
Your log shows your board has no eMMC device. During kernel boot, you should see eMMC device is scanned.
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.39 GiB
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
Grace
Hi Grace Si,
Thanks for your response. In my Log. No eMMC device is found. But I am wondering why eMMC device can not be found on my hardware board. On my hardware board eMMC device layout is same as SABRE-AI_DualLite_CPUcard which is EV kit of freescale:
On my hardware board:
On SABRE-AI_DualLite_CPUcard:
I can make sure eMMC device is working on my hardware board because QNX system can run my hardware board which use eMMC device as boot program storage space.
Hi Eddy,
Except pin CLK, CMD, DAT0-7, you need also check whether SD3_CD and SD3_WP are correctly muxed.
static iomux_v3_cfg_t mx6dl_sabreauto_pads[] = {
/* SD3 */
MX6DL_PAD_SD3_CLK__USDHC3_CLK_50MHZ,
MX6DL_PAD_SD3_CMD__USDHC3_CMD_50MHZ,
MX6DL_PAD_SD3_DAT0__USDHC3_DAT0_50MHZ,
MX6DL_PAD_SD3_DAT1__USDHC3_DAT1_50MHZ,
MX6DL_PAD_SD3_DAT2__USDHC3_DAT2_50MHZ,
MX6DL_PAD_SD3_DAT3__USDHC3_DAT3_50MHZ,
MX6DL_PAD_SD3_DAT4__USDHC3_DAT4_50MHZ,
MX6DL_PAD_SD3_DAT5__USDHC3_DAT5_50MHZ,
MX6DL_PAD_SD3_DAT6__USDHC3_DAT6_50MHZ,
MX6DL_PAD_SD3_DAT7__USDHC3_DAT7_50MHZ,
/* SD3 VSelect */
MX6DL_PAD_GPIO_18__USDHC3_VSELECT,
/* SD3_CD and SD3_WP */
MX6DL_PAD_NANDF_CS2__GPIO_6_15,
MX6DL_PAD_SD2_DAT2__GPIO_1_13,
Grace
Hi Grace Si,
Under your reminding. I checked pins between my hardware board and freescale board except pins CLK, CMD and DAT0-7. I am notified SD3_CD and SD3_WP is not existed on my hardware board, while RST pin is on my hardware board which is not existed on freescale board. What does this two pins do? Is it necessary for eMMC or eMMC has many different hardware interface?
I check eMMC hardware interface on line which is same as my hardware board
Hi Eddy,
If your board is not same as FSL board, you need modify mx6q_sabreauto_sd3_data in
/arch/arm/mach-mx6/board-mx6q_sabreauto.c
original:
static const struct esdhc_platform_data mx6q_sabreauto_sd3_data __initconst = {
.cd_gpio = SABREAUTO_SD3_CD,
.wp_gpio = SABREAUTO_SD3_WP,
.keep_power_at_suspend = 1,
.support_18v = 1,
.support_8bit = 1,
.delay_line = 0,
.platform_pad_change = plt_sd_pad_change,
change to ->
.always_present = 1,
.support_8bit = 1,
.delay_line = 0,
.cd_type = ESDHC_CD_PERMANENT,
Grace
Hi Grace,
Maybe you are right, I need to modify my code for porting linux on my board. But first I do not understand the hardware design of FSL board. The only difference between my hardware board and FSL board is the RST pin and CD pin WP pin. Why does FSL board use CD pin and WP pin instead of RST pin. Can you tell me the function of CD pin and WP pin on FSL board? I do not think it is necessary for eMMC device.
Hi Eddy,
CD( card detect) pin and WP (write protect) pin are needed for removable SD card, but NOT needed for non-removable eMMC.
Grace
Hi Grace,
As you say, CD pin and WP pin is not needed for non-removable eMMC. So no difference in hardware between my hardware board and FSL board. Why eMMC device can not be found on my hardware board which can be found on FSL board? Does FSL board not support non-removable eMMC?
In FSL board, SD3 is configured for removable card, so CD pin and WP pin are defined in mx6q_sabreauto_sd3. If you use SD3 as non-removable, you must modify the structure of mx6q_sabreauto_sd3.
Grace
Hi Grace,
Thanks for your patient help. I have realized it is necessary to modify code to adapt for my hardware board. I modified structure of mx6q_sabreauto_sd3 and compiled linux code:
Header 1 |
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- distclean #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6s_defconfig #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- uImage |
I copied uImage to "Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\" and replaced the old uImage. ucl2.xml configration is as blow:
Header 1 |
When I downloaded uboot and uImage using MFGtools, error appeared:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 15:02:51) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 37 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 Using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35-2508-g54750ff Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3584948 Bytes = 3.4 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 10c00000 ... Image Name: uboot initramfs rootfs Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4545326 Bytes = 4.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 201 1/08/10 09:20) ) #1 PREEMPT Wed Apr 2 04:38:35 EDT 2014 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board Memory policy: ECC disabled, Data cache writeback CPU identified as i.MX6DL/SOLO, silicon rev 1.1 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97280 Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 384MB = 384MB total Memory: 373308k/373308k available, 150980k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xa0800000 - 0xf2000000 (1304 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x80036000 ( 184 kB) .text : 0x80036000 - 0x80a30cb8 (10220 kB) .data : 0x80a32000 - 0x80a86480 ( 338 kB) .bss : 0x80a864a4 - 0x80aab438 ( 148 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms Set periph_clk's parent to pll2_pfd_400M! arm_max_freq=800MHz MXC_Early serial console at MMIO 0x2020000 (options '115200') bootconsole [ttymxc0] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B bio: create slab <bio-0> at 0 print_constraints: SPKVDD: 4200 mV print_constraints: vmmc: 3300 mV SCSI subsystem initialized spi_imx imx6q-ecspi.0: probed usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Freescale USB OTG Driver loaded, $Revision: 1.55 $ mc_pfuze 1-0008: recv failed!:-5,80 mc_pfuze: probe of 1-0008 failed with error -1 mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a MIPI CSI2 driver module loaded Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized cfg80211: Calling CRDA to update world regulatory domain max17135 2-0048: PMIC MAX17135 for eInk display i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Initramfs unpacking failed: junk in compressed archive Freeing initrd memory: 4436K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is disabled for i.MX6 cpaddr = a0820000 suspend_iram_base=a087c000 PM driver module loaded IMX usb wakeup probe add wake up source irq 75 IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 737 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) i2c-core: driver [sii902x] using legacy suspend method i2c-core: driver [sii902x] using legacy resume method imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Serial: IMX driver imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX console [ttymxc0] enabled, bootconsole disabled console [ttymxc0] enabled, bootconsole disabled loop: module loaded m25p80 spi0.0: unrecognized JEDEC id ffffff vcan: Virtual CAN interface driver CAN device driver interface flexcan netdevice driver FEC Ethernet Driver fec_enet_mii_bus: probed ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected add wake up source irq 72 fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. ARC USBOTG Device Controller driver (1 August 2005) mousedev: PS/2 mouse device common for all mice input: gpio-keys as /devices/platform/gpio-keys/input/input0 egalax_ts 1-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 1-0004 failed with error -5 egalax_ts 2-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 2-0004 failed with error -5 elan - Read Hello Packet Failed elan-touch: probe of 2-0010 failed with error -22 i2c-core: driver [isl29023] using legacy suspend method i2c-core: driver [isl29023] using legacy resume method snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = 80004000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.0.35-2508-g54750ff #1) PC is at csi_mclk_enable+0x18/0x28 LR is at clk_enable+0x60/0xa0 pc : [<80344a88>] lr : [<8005caec>] psr: 60000013 sp : 94031ea8 ip : 00000000 fp : 00000000 r10: 9427d000 r9 : 8034758c r8 : 9427d020 r7 : 00000000 r6 : 9427d000 r5 : 00000001 r4 : 80aa2fbc r3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : 00000000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c53c7d Table: 10004059 DAC: 00000015 Process swapper (pid: 1, stack limit = 0x940302e8) Stack: (0x94031ea8 to 0x94032000) 1ea0: 00000001 80344ac8 8005a85c 80aa3028 80a48e34 80347714 1ec0: 00000000 00000000 9427d020 804f2778 804f2760 804f2778 9427d004 8031fbd0 1ee0: 9427d020 80aa0b88 9427d054 00000000 80a71d0c 00000000 80022f2c 80277f34 1f00: 9427d020 80a71d0c 9427d054 00000000 00000000 802780cc 80a71d0c 00000000 1f20: 80278040 80277154 940bcc38 94111c90 80a71d0c 80a6e6c0 9430e420 80277908 1f40: 809c58e0 80a71d0c 94030000 80a71d0c 94030000 8003c670 00000000 00000000 1f60: 80022f2c 802785ac 80a71ce4 94030000 8003c670 00000000 00000000 80321830 1f80: 00000000 80a864c0 94030000 80022f3c 80a864c0 8003635c 00000000 940564e0 1fa0: 8009e878 80022f2c 80a58078 8009e8a8 000001df 8003c670 00000013 37340000 1fc0: 00000039 8002b6f0 8002b84c 8003c670 00000013 00000000 00000000 00000000 1fe0: 00000000 800089b4 00000000 00000000 80008930 8003c670 6ebdf65b f33fd9dd [<80344a88>] (csi_mclk_enable+0x18/0x28) from [<80344ac8>] (csi_enable_mclk+0x14/0x54) [<80344ac8>] (csi_enable_mclk+0x14/0x54) from [<80347714>] (ov5640_probe+0x188/0x2f0) [<80347714>] (ov5640_probe+0x188/0x2f0) from [<8031fbd0>] (i2c_device_probe+0xc0/0xfc) [<8031fbd0>] (i2c_device_probe+0xc0/0xfc) from [<80277f34>] (driver_probe_device+0x90/0x19c) [<80277f34>] (driver_probe_device+0x90/0x19c) from [<802780cc>] (__driver_attach+0x8c/0x90) [<802780cc>] (__driver_attach+0x8c/0x90) from [<80277154>] (bus_for_each_dev+0x5c/0x88) [<80277154>] (bus_for_each_dev+0x5c/0x88) from [<80277908>] (bus_add_driver+0x17c/0x244) [<80277908>] (bus_add_driver+0x17c/0x244) from [<802785ac>] (driver_register+0x78/0x13c) [<802785ac>] (driver_register+0x78/0x13c) from [<80321830>] (i2c_register_driver+0x2c/0xb4) [<80321830>] (i2c_register_driver+0x2c/0xb4) from [<80022f3c>] (ov5640_init+0x10/0x40) [<80022f3c>] (ov5640_init+0x10/0x40) from [<8003635c>] (do_one_initcall+0x34/0x174) [<8003635c>] (do_one_initcall+0x34/0x174) from [<800089b4>] (kernel_init+0x84/0x124) [<800089b4>] (kernel_init+0x84/0x124) from [<8003c670>] (kernel_thread_exit+0x0/0x8) Code: e34840aa e2840008 ebf46001 e5943000 (e5932000) ---[ end trace c0aaf267c1d7dce3 ]--- Kernel panic - not syncing: Attempted to kill init! [<80041518>] (unwind_backtrace+0x0/0xf8) from [<804c1f04>] (panic+0x74/0x188) [<804c1f04>] (panic+0x74/0x188) from [<8006bca0>] (do_exit+0x668/0x6ec) [<8006bca0>] (do_exit+0x668/0x6ec) from [<8003f1ec>] (die+0x234/0x2a8) [<8003f1ec>] (die+0x234/0x2a8) from [<804c1e14>] (__do_kernel_fault.part.5+0x54/0x74) [<804c1e14>] (__do_kernel_fault.part.5+0x54/0x74) from [<80044f70>] (do_page_fault+0x2b4/0x31c) [<80044f70>] (do_page_fault+0x2b4/0x31c) from [<800361a0>] (do_DataAbort+0x34/0x9c) [<800361a0>] (do_DataAbort+0x34/0x9c) from [<8003b790>] (__dabt_svc+0x70/0xa0) Exception stack(0x94031e60 to 0x94031ea8) 1e60: 00000000 00000001 00000000 00000000 80aa2fbc 00000001 9427d000 00000000 1e80: 9427d020 8034758c 9427d000 00000000 00000000 94031ea8 8005caec 80344a88 1ea0: 60000013 ffffffff [<8003b790>] (__dabt_svc+0x70/0xa0) from [<80344a88>] (csi_mclk_enable+0x18/0x28) [<80344a88>] (csi_mclk_enable+0x18/0x28) from [<80344ac8>] (csi_enable_mclk+0x14/0x54) [<80344ac8>] (csi_enable_mclk+0x14/0x54) from [<80347714>] (ov5640_probe+0x188/0x2f0) [<80347714>] (ov5640_probe+0x188/0x2f0) from [<8031fbd0>] (i2c_device_probe+0xc0/0xfc) [<8031fbd0>] (i2c_device_probe+0xc0/0xfc) from [<80277f34>] (driver_probe_device+0x90/0x19c) [<80277f34>] (driver_probe_device+0x90/0x19c) from [<802780cc>] (__driver_attach+0x8c/0x90) [<802780cc>] (__driver_attach+0x8c/0x90) from [<80277154>] (bus_for_each_dev+0x5c/0x88) [<80277154>] (bus_for_each_dev+0x5c/0x88) from [<80277908>] (bus_add_driver+0x17c/0x244) [<80277908>] (bus_add_driver+0x17c/0x244) from [<802785ac>] (driver_register+0x78/0x13c) [<802785ac>] (driver_register+0x78/0x13c) from [<80321830>] (i2c_register_driver+0x2c/0xb4) [<80321830>] (i2c_register_driver+0x2c/0xb4) from [<80022f3c>] (ov5640_init+0x10/0x40) [<80022f3c>] (ov5640_init+0x10/0x40) from [<8003635c>] (do_one_initcall+0x34/0x174) [<8003635c>] (do_one_initcall+0x34/0x174) from [<800089b4>] (kernel_init+0x84/0x124) [<800089b4>] (kernel_init+0x84/0x124) from [<8003c670>] (kernel_thread_exit+0x0/0x8) |
imx6s_defconfig is for i.MX 6SoloLite.
export ARCH=arm
export CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-
make imx6_updater_defconfig // this is for MFG tool.
Grace
Hi Grace,
I have modified data struct mx6q_sabreauto_sd3_data in /arch/arm/mach-mx6/board-mx6q_sabreauto.c:
and compiled linux kernel using command below:
Header 1 |
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- distclean #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_updater_defconfig #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- uImage |
but still no eMMC device is found after uboot and uImage is downloaded by MFGtools:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 15:02:51) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 35 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 Using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35-2508-g54750ff Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3161456 Bytes = 3 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 10c00000 ... Image Name: uboot initramfs rootfs Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4545326 Bytes = 4.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 201 1/08/10 09:20) ) #1 SMP PREEMPT Thu Apr 3 01:56:31 EDT 2014 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board Memory policy: ECC disabled, Data cache writealloc CPU identified as i.MX6DL/SOLO, silicon rev 1.1 PERCPU: Embedded 7 pages/cpu @8bc06000 s5184 r8192 d15296 u32768 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 508996k/508996k available, 15292k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xa0800000 - 0xf2000000 (1304 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003a000 ( 200 kB) .text : 0x8003a000 - 0x805ac9f8 (5579 kB) .data : 0x805ae000 - 0x805fc520 ( 314 kB) .bss : 0x805fc544 - 0x80627494 ( 172 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms Set periph_clk's parent to pll2_pfd_400M! arm_max_freq=800MHz MXC_Early serial console at MMIO 0x2020000 (options '115200') bootconsole [ttymxc0] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available Brought up 1 CPUs SMP: Total of 1 processors activated (1581.05 BogoMIPS). print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B bio: create slab <bio-0> at 0 mxs-dma mxs-dma-apbh: initialized print_constraints: SPKVDD: 4200 mV print_constraints: vmmc: 3300 mV SCSI subsystem initialized spi_imx imx6q-ecspi.0: probed usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb mc_pfuze 1-0008: recv failed!:-5,80 mc_pfuze: probe of 1-0008 failed with error -1 imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized max17135 2-0048: PMIC MAX17135 for eInk display i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 5, 196608 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Freeing initrd memory: 4436K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is disabled for i.MX6 cpaddr = a0820000 suspend_iram_base=a08b4000 PM driver module loaded IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 1002 cryptodev: driver loaded. io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb _regulator_get: get() with no identifier imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) Console: switching to colour frame buffer device 128x48 mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Serial: IMX driver imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX console [ttymxc0] enabled, bootconsole disabled console [ttymxc0] enabled, bootconsole disabled loop: module loaded m25p80 spi0.0: unrecognized JEDEC id ffffff GPMI NAND driver registered. (IMX) vcan: Virtual CAN interface driver FEC Ethernet Driver fec_enet_mii_bus: probed Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. ARC USBOTG Device Controller driver (1 August 2005) add wake up source irq 75 g_file_storage gadget: controller 'fsl-usb2-udc' not recognized check_parameters:UTP settings are in place now, overriding defaults g_file_storage gadget: No serial-number string provided! g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010 g_file_storage gadget: Number of LUNs=1 fsl-usb2-udc: bind to driver g_file_storage mousedev: PS/2 mouse device common for all mice egalax_ts 1-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 1-0004 failed with error -5 egalax_ts 2-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 2-0004 failed with error -5 snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered usbcore: registered new interface driver usbhid usbhid: USB HID core driver Cirrus Logic CS42888 ALSA SoC Codec Driver i2c-core: driver [cs42888] using legacy suspend method i2c-core: driver [cs42888] using legacy resume method imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first. imx_3stack asoc driver ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 Bus freq driver module loaded Bus freq driver Enabled mxc_dvfs_core_probe DVFS driver module loaded regulator_init_complete: SPKVDD: incomplete constraints, leaving on snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) Freeing init memory: 200K Starting UTP ln: /etc/mtab: File exists disable turn off display Starting the hotplug events dispatcher udevd Synthesizing initial hotplug events udevd (2072): /proc/2072/oom_adj is deprecated, please use /proc/2072/oom_score_adj instead. g_file_storage gadget: high speed config #1 uuc 0.4 [built Aug 16 2013 01:24:08] UTP: Waiting for device to appear UTP: file/device node /dev/utp already exists cpu_id is 0 UTP: received command '$ ls /dev/' UTP: executing "ls /dev/" XOR ptyrb tty25 ttyqf apm_bios ptyrc tty26 ttyr0 console ptyrd tty27 ttyr1 cpu_dma_latency ptyre tty28 ttyr2 crypto ptyrf tty29 ttyr3 fb ptys0 tty3 ttyr4 fb0 ptys1 tty30 ttyr5 fb1 ptys2 tty31 ttyr6 fb2 ptys3 tty32 ttyr7 full ptys4 tty33 ttyr8 i2c-0 ptys5 tty34 ttyr9 i2c-1 ptys6 tty35 ttyra i2c-2 ptys7 tty36 ttyrb input ptys8 tty37 ttyrc kmem ptys9 tty38 ttyrd kmsg ptysa tty39 ttyre loop0 ptysb tty4 ttyrf loop1 ptysc tty40 ttys0 loop2 ptysd tty41 ttys1 loop3 ptyse tty42 ttys2 loop4 ptysf tty43 ttys3 loop5 ptyt0 tty44 ttys4 loop6 ptyt1 tty45 ttys5 loop7 ptyt2 tty46 ttys6 mem ptyt3 tty47 ttys7 mxc_asrc ptyt4 tty48 ttys8 mxc_ipu ptyt5 tty49 ttys9 mxc_mem ptyt6 tty5 ttysa mxc_vpu ptyt7 tty50 ttysb mxs_viim ptyt8 tty51 ttysc network_latency ptyt9 tty52 ttysd network_throughput ptyta tty53 ttyse null ptytb tty54 ttysf psaux ptytc tty55 ttyt0 ptmx ptytd tty56 ttyt1 pts ptyte tty57 ttyt2 ptya0 ptytf tty58 ttyt3 ptya1 ptyu0 tty59 ttyt4 ptya2 ptyu1 tty6 ttyt5 ptya3 ptyu2 tty60 ttyt6 ptya4 ptyu3 tty61 ttyt7 ptya5 ptyu4 tty62 ttyt8 ptya6 ptyu5 tty63 ttyt9 ptya7 ptyu6 tty7 ttyta ptya8 ptyu7 tty8 ttytb ptya9 ptyu8 tty9 ttytc ptyaa ptyu9 ttya0 ttytd ptyab ptyua ttya1 ttyte ptyac ptyub ttya2 ttytf ptyad ptyuc ttya3 ttyu0 ptyae ptyud ttya4 ttyu1 ptyaf ptyue ttya5 ttyu2 ptyb0 ptyuf ttya6 ttyu3 ptyb1 ptyv0 ttya7 ttyu4 ptyb2 ptyv1 ttya8 ttyu5 ptyb3 ptyv2 ttya9 ttyu6 ptyb4 ptyv3 ttyaa ttyu7 ptyb5 ptyv4 ttyab ttyu8 ptyb6 ptyv5 ttyac ttyu9 ptyb7 ptyv6 ttyad ttyua ptyb8 ptyv7 ttyae ttyub ptyb9 ptyv8 ttyaf ttyuc ptyba ptyv9 ttyb0 ttyud ptybb ptyva ttyb1 ttyue ptybc ptyvb ttyb2 ttyuf ptybd ptyvc ttyb3 ttyv0 ptybe ptyvd ttyb4 ttyv1 ptybf ptyve ttyb5 ttyv2 ptyc0 ptyvf ttyb6 ttyv3 ptyc1 ptyw0 ttyb7 ttyv4 ptyc2 ptyw1 ttyb8 ttyv5 ptyc3 ptyw2 ttyb9 ttyv6 ptyc4 ptyw3 ttyba ttyv7 ptyc5 ptyw4 ttybb ttyv8 ptyc6 ptyw5 ttybc ttyv9 ptyc7 ptyw6 ttybd ttyva ptyc8 ptyw7 ttybe ttyvb ptyc9 ptyw8 ttybf ttyvc ptyca ptyw9 ttyc0 ttyvd ptycb ptywa ttyc1 ttyve ptycc ptywb ttyc2 ttyvf ptycd ptywc ttyc3 ttyw0 ptyce ptywd ttyc4 ttyw1 ptycf ptywe ttyc5 ttyw2 ptyd0 ptywf ttyc6 ttyw3 ptyd1 ptyx0 ttyc7 ttyw4 ptyd2 ptyx1 ttyc8 ttyw5 ptyd3 ptyx2 ttyc9 ttyw6 ptyd4 ptyx3 ttyca ttyw7 ptyd5 ptyx4 ttycb ttyw8 ptyd6 ptyx5 ttycc ttyw9 ptyd7 ptyx6 ttycd ttywa ptyd8 ptyx7 ttyce ttywb ptyd9 ptyx8 ttycf ttywc ptyda ptyx9 ttyd0 ttywd ptydb ptyxa ttyd1 ttywe ptydc ptyxb ttyd2 ttywf ptydd ptyxc ttyd3 ttyx0 ptyde ptyxd ttyd4 ttyx1 ptydf ptyxe ttyd5 ttyx2 ptye0 ptyxf ttyd6 ttyx3 ptye1 ptyy0 ttyd7 ttyx4 ptye2 ptyy1 ttyd8 ttyx5 ptye3 ptyy2 ttyd9 ttyx6 ptye4 ptyy3 ttyda ttyx7 ptye5 ptyy4 ttydb ttyx8 ptye6 ptyy5 ttydc ttyx9 ptye7 ptyy6 ttydd ttyxa ptye8 ptyy7 ttyde ttyxb ptye9 ptyy8 ttydf ttyxc ptyea ptyy9 ttye0 ttyxd ptyeb ptyya ttye1 ttyxe ptyec ptyyb ttye2 ttyxf ptyed ptyyc ttye3 ttyy0 ptyee ptyyd ttye4 ttyy1 ptyef ptyye ttye5 ttyy2 ptyp0 ptyyf ttye6 ttyy3 ptyp1 ptyz0 ttye7 ttyy4 ptyp2 ptyz1 ttye8 ttyy5 ptyp3 ptyz2 ttye9 ttyy6 ptyp4 ptyz3 ttyea ttyy7 ptyp5 ptyz4 ttyeb ttyy8 ptyp6 ptyz5 ttyec ttyy9 ptyp7 ptyz6 ttyed ttyya ptyp8 ptyz7 ttyee ttyyb ptyp9 ptyz8 ttyef ttyyc ptypa ptyz9 ttymxc0 ttyyd utp_poll: pass returned. ptypb ptyza ttymxc2 ttyye ptypc ptyzb ttyp0 ttyyf ptypd ptyzc ttyp1 ttyz0 ptype ptyzd ttyp2 ttyz1 ptypf ptyze ttyp3 ttyz2 ptyq0 ptyzf ttyp4 ttyz3 ptyq1 random ttyp5 ttyz4 ptyq2 rfkill ttyp6 ttyz5 ptyq3 rtc ttyp7 ttyz6 ptyq4 rtc0 ttyp8 ttyz7 ptyq5 shm ttyp9 ttyz8 ptyq6 snd ttypa ttyz9 ptyq7 tracebuf ttypb ttyza ptyq8 tty ttypc ttyzb ptyq9 tty0 ttypd ttyzc ptyqa tty1 ttype ttyzd ptyqb tty10 ttypf ttyze ptyqc tty11 ttyq0 ttyzf ptyqd tty12 ttyq1 ubi_ctrl ptyqe tty13 ttyq2 urandom ptyqf tty14 ttyq3 utp ptyr0 tty15 ttyq4 vcs ptyr1 tty16 ttyq5 vcs1 ptyr2 tty17 ttyq6 vcsa ptyr3 tty18 ttyq7 vcsa1 ptyr4 tty19 ttyq8 vhci ptyr5 tty2 ttyq9 video16 ptyr6 tty20 ttyqa video17 ptyr7 tty21 ttyqb video18 ptyr8 tty22 ttyqc watchdog ptyr9 tty23 ttyqd zero ptyra tty24 ttyqe UTP: sending Success to kernel for command $ ls /dev/. |
If you use 6DL SarbeSD, you should modify /arch/arm/mach-mx6/board-mx6q_sabresd.c. In your post, you said you compared SABRE-AI_DualLite_CPUcard, If you use SarbeSD config, you should compare SarbeSD reference design.
Grace
Hi Grace,
Can you give more feedback about this issue?
Hi Eddy,
Grace
Hi Grace,
Now my hardware board can run uboot uImage and fs from Freescale LTIB. Thanks for your patient help. Best wishes for you.
Hi Grace,
With your patiently direction, I modified file board-mx6_sabresd.c. Now eMMC device can be found:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 15:02:51) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 35 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 Using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35-2508-g54750ff Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3161712 Bytes = 3 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 10c00000 ... Image Name: uboot initramfs rootfs Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4545326 Bytes = 4.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 201 1/08/10 09:20) ) #1 SMP PREEMPT Fri Apr 4 01:20:23 EDT 2014 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board Memory policy: ECC disabled, Data cache writealloc CPU identified as i.MX6DL/SOLO, silicon rev 1.1 PERCPU: Embedded 7 pages/cpu @8bc06000 s5184 r8192 d15296 u32768 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 508996k/508996k available, 15292k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xa0800000 - 0xf2000000 (1304 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003a000 ( 200 kB) .text : 0x8003a000 - 0x805aca0c (5579 kB) .data : 0x805ae000 - 0x805fc700 ( 314 kB) .bss : 0x805fc724 - 0x80627674 ( 172 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms Set periph_clk's parent to pll2_pfd_400M! arm_max_freq=800MHz MXC_Early serial console at MMIO 0x2020000 (options '115200') bootconsole [ttymxc0] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available Brought up 1 CPUs SMP: Total of 1 processors activated (1581.05 BogoMIPS). print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B bio: create slab <bio-0> at 0 mxs-dma mxs-dma-apbh: initialized print_constraints: SPKVDD: 4200 mV print_constraints: vmmc: 3300 mV SCSI subsystem initialized spi_imx imx6q-ecspi.0: probed usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb mc_pfuze 1-0008: recv failed!:-5,80 mc_pfuze: probe of 1-0008 failed with error -1 imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized max17135 2-0048: PMIC MAX17135 for eInk display i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 5, 196608 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Freeing initrd memory: 4436K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is disabled for i.MX6 cpaddr = a0820000 suspend_iram_base=a08b4000 PM driver module loaded IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 1002 cryptodev: driver loaded. io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb _regulator_get: get() with no identifier imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) Console: switching to colour frame buffer device 128x48 mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Serial: IMX driver imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX console [ttymxc0] enabled, bootconsole disabled console [ttymxc0] enabled, bootconsole disabled loop: module loaded m25p80 spi0.0: unrecognized JEDEC id ffffff GPMI NAND driver registered. (IMX) vcan: Virtual CAN interface driver FEC Ethernet Driver fec_enet_mii_bus: probed Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. ARC USBOTG Device Controller driver (1 August 2005) add wake up source irq 75 g_file_storage gadget: controller 'fsl-usb2-udc' not recognized check_parameters:UTP settings are in place now, overriding defaults g_file_storage gadget: No serial-number string provided! g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010 g_file_storage gadget: Number of LUNs=1 fsl-usb2-udc: bind to driver g_file_storage mousedev: PS/2 mouse device common for all mice egalax_ts 1-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 1-0004 failed with error -5 egalax_ts 2-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 2-0004 failed with error -5 snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered usbcore: registered new interface driver usbhid usbhid: USB HID core driver Cirrus Logic CS42888 ALSA SoC Codec Driver i2c-core: driver [cs42888] using legacy suspend method i2c-core: driver [cs42888] using legacy resume method imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first. imx_3stack asoc driver ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 Bus freq driver module loaded Bus freq driver Enabled mxc_dvfs_core_probe DVFS driver module loaded regulator_init_complete: SPKVDD: incomplete constraints, leaving on snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) Freeing init memory: 200K Starting UTP ln: /etc/mtab: File exists disable turn off display Starting the hotplug events dispatcher udevd Synthesizing initial hotplug events udevd (2072): /proc/2072/oom_adj is deprecated, please use /proc/2072/oom_score_adj instead. mmc2: new high speed DDR MMC card at address 0001 mmcblk0: mmc2:0001 MMC08G 7.32 GiB mmcblk0boot0: mmc2:0001 MMC08G partition 1 2.00 MiB mmcblk0boot1: mmc2:0001 MMC08G partition 2 2.00 MiB mmcblk0: p1 p2 mmcblk0boot1: unknown partition table g_file_storage gadget: high speed config #1 mmcblk0boot0: unknown partition table uuc 0.4 [built Aug 16 2013 01:24:08] UTP: Waiting for device to appear UTP: file/device node /dev/utp already exists cpu_id is 0 UTP: received command '$ ls /dev/' UTP: executing "ls /dev/" XOR ptyr7 tty23 ttyqf apm_bios ptyr8 tty24 ttyr0 console ptyr9 tty25 ttyr1 cpu_dma_latency ptyra tty26 ttyr2 crypto ptyrb tty27 ttyr3 disk ptyrc tty28 ttyr4 fb ptyrd tty29 ttyr5 fb0 ptyre tty3 ttyr6 fb1 ptyrf tty30 ttyr7 fb2 ptys0 tty31 ttyr8 full ptys1 tty32 ttyr9 i2c-0 ptys2 tty33 ttyra i2c-1 ptys3 tty34 ttyrb i2c-2 ptys4 tty35 ttyrc input ptys5 tty36 ttyrd kmem ptys6 tty37 ttyre kmsg ptys7 tty38 ttyrf loop0 ptys8 tty39 ttys0 loop1 ptys9 tty4 ttys1 loop2 ptysa tty40 ttys2 loop3 ptysb tty41 ttys3 loop4 ptysc tty42 ttys4 loop5 ptysd tty43 ttys5 loop6 ptyse tty44 ttys6 loop7 ptysf tty45 ttys7 mem ptyt0 tty46 ttys8 mmcblk0 ptyt1 tty47 ttys9 mmcblk0boot0 ptyt2 tty48 ttysa mmcblk0boot1 ptyt3 tty49 ttysb mmcblk0p1 ptyt4 tty5 ttysc mmcblk0p2 ptyt5 tty50 ttysd mxc_asrc ptyt6 tty51 ttyse mxc_ipu ptyt7 tty52 ttysf mxc_mem ptyt8 tty53 ttyt0 mxc_vpu ptyt9 tty54 ttyt1 mxs_viim ptyta tty55 ttyt2 network_latency ptytb tty56 ttyt3 network_throughput ptytc tty57 ttyt4 null ptytd tty58 ttyt5 psaux ptyte tty59 ttyt6 ptmx ptytf tty6 ttyt7 pts ptyu0 tty60 ttyt8 ptya0 ptyu1 tty61 ttyt9 ptya1 ptyu2 tty62 ttyta ptya2 ptyu3 tty63 ttytb ptya3 ptyu4 tty7 ttytc ptya4 ptyu5 tty8 ttytd ptya5 ptyu6 tty9 ttyte ptya6 ptyu7 ttya0 ttytf ptya7 ptyu8 ttya1 ttyu0 ptya8 ptyu9 ttya2 ttyu1 ptya9 ptyua ttya3 ttyu2 ptyaa ptyub ttya4 ttyu3 ptyab ptyuc ttya5 ttyu4 ptyac ptyud ttya6 ttyu5 ptyad ptyue ttya7 ttyu6 ptyae ptyuf ttya8 ttyu7 ptyaf ptyv0 ttya9 ttyu8 ptyb0 ptyv1 ttyaa ttyu9 ptyb1 ptyv2 ttyab ttyua ptyb2 ptyv3 ttyac ttyub ptyb3 ptyv4 ttyad ttyuc ptyb4 ptyv5 ttyae ttyud ptyb5 ptyv6 ttyaf ttyue ptyb6 ptyv7 ttyb0 ttyuf ptyb7 ptyv8 ttyb1 ttyv0 ptyb8 ptyv9 ttyb2 ttyv1 ptyb9 ptyva ttyb3 ttyv2 ptyba ptyvb ttyb4 ttyv3 ptybb ptyvc ttyb5 ttyv4 ptybc ptyvd ttyb6 ttyv5 ptybd ptyve ttyb7 ttyv6 ptybe ptyvf ttyb8 ttyv7 ptybf ptyw0 ttyb9 ttyv8 ptyc0 ptyw1 ttyba ttyv9 ptyc1 ptyw2 ttybb ttyva ptyc2 ptyw3 ttybc ttyvb ptyc3 ptyw4 ttybd ttyvc ptyc4 ptyw5 ttybe ttyvd ptyc5 ptyw6 ttybf ttyve ptyc6 ptyw7 ttyc0 ttyvf ptyc7 ptyw8 ttyc1 ttyw0 ptyc8 ptyw9 ttyc2 ttyw1 ptyc9 ptywa ttyc3 ttyw2 ptyca ptywb ttyc4 ttyw3 ptycb ptywc ttyc5 ttyw4 ptycc ptywd ttyc6 ttyw5 ptycd ptywe ttyc7 ttyw6 ptyce ptywf ttyc8 ttyw7 ptycf ptyx0 ttyc9 ttyw8 ptyd0 ptyx1 ttyca ttyw9 ptyd1 ptyx2 ttycb ttywa ptyd2 ptyx3 ttycc ttywb ptyd3 ptyx4 ttycd ttywc ptyd4 ptyx5 ttyce ttywd ptyd5 ptyx6 ttycf ttywe ptyd6 ptyx7 ttyd0 ttywf ptyd7 ptyx8 ttyd1 ttyx0 ptyd8 ptyx9 ttyd2 ttyx1 ptyd9 ptyxa ttyd3 ttyx2 ptyda ptyxb ttyd4 ttyx3 ptydb ptyxc ttyd5 ttyx4 ptydc ptyxd ttyd6 ttyx5 ptydd ptyxe ttyd7 ttyx6 ptyde ptyxf ttyd8 ttyx7 ptydf ptyy0 ttyd9 ttyx8 ptye0 ptyy1 ttyda ttyx9 ptye1 ptyy2 ttydb ttyxa ptye2 ptyy3 ttydc ttyxb ptye3 ptyy4 ttydd ttyxc ptye4 ptyy5 ttyde ttyxd ptye5 ptyy6 ttydf ttyxe ptye6 ptyy7 ttye0 ttyxf ptye7 ptyy8 ttye1 ttyy0 ptye8 ptyy9 ttye2 ttyy1 ptye9 ptyya ttye3 ttyy2 ptyea ptyyb ttye4 ttyy3 ptyeb ptyyc ttye5 ttyy4 ptyec ptyyd ttye6 ttyy5 ptyed ptyye ttye7 ttyy6 ptyee ptyyf ttye8 ttyy7 ptyef ptyz0 ttye9 ttyy8 ptyp0 ptyz1 ttyea ttyy9 ptyp1 ptyz2 ttyeb ttyya ptyp2 ptyz3 ttyec ttyyb ptyp3 ptyz4 ttyed ttyyc ptyp4 ptyz5 ttyee ttyyd utp_poll: pass returned. ptyp5 ptyz6 ttyef ttyye ptyp6 ptyz7 ttymxc0 ttyyf ptyp7 ptyz8 ttymxc2 ttyz0 ptyp8 ptyz9 ttyp0 ttyz1 ptyp9 ptyza ttyp1 ttyz2 ptypa ptyzb ttyp2 ttyz3 ptypb ptyzc ttyp3 ttyz4 ptypc ptyzd ttyp4 ttyz5 ptypd ptyze ttyp5 ttyz6 ptype ptyzf ttyp6 ttyz7 ptypf random ttyp7 ttyz8 ptyq0 rfkill ttyp8 ttyz9 ptyq1 rtc ttyp9 ttyza ptyq2 rtc0 ttypa ttyzb ptyq3 shm ttypb ttyzc ptyq4 snd ttypc ttyzd ptyq5 tracebuf ttypd ttyze ptyq6 tty ttype ttyzf ptyq7 tty0 ttypf ubi_ctrl ptyq8 tty1 ttyq0 urandom ptyq9 tty10 ttyq1 utp ptyqa tty11 ttyq2 vcs ptyqb tty12 ttyq3 vcs1 ptyqc tty13 ttyq4 vcsa ptyqd tty14 ttyq5 vcsa1 ptyqe tty15 ttyq6 vhci ptyqf tty16 ttyq7 video16 ptyr0 tty17 ttyq8 video17 ptyr1 tty18 ttyq9 video18 ptyr2 tty19 ttyqa watchdog ptyr3 tty2 ttyqb zero ptyr4 tty20 ttyqc ptyr5 tty21 ttyqd ptyr6 tty22 ttyqe |
Then I rebuilt linux kernel for eMMC with commands below:
Header 1 |
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- distclean #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_defconfig #make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- uImage |
and copied new generated uImage to directory "Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\files\" replacing the old uImage.
ucl2.xml configration is as below:
Header 1 |
<LIST name="i.MX6SOLO-SABRESD-SD" desc="Choose SD as media"> <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6solo-sabresd.bin" >Loading U-boot</CMD> <CMD state="BootStrap" type="load" file="uImage" address="0x10800000" loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD> <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000" loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD> <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
<CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD> <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD> <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD> <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6solo-sabresd.bin">Sending u-boot.bin</CMD> <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync">write u-boot.bin to sd card</CMD> <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD> <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
<CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD> <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/> <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/> <CMD state="Updater" type="push" body="pipe tar -jxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.bz2">Sending and writting rootfs</CMD> <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD> <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD> <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD> <!-- The below commands will trigger reboot <CMD type="push" body="!3">Done</CMD> --> </LIST> |
Downloading uboot and uImage process is as below:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 15:02:51) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 43 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 Using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35-2508-g54750ff Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3161712 Bytes = 3 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 10c00000 ... Image Name: uboot initramfs rootfs Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 4545326 Bytes = 4.3 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Fri Apr 4 01:20:23 EDT 2014 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board Memory policy: ECC disabled, Data cache writealloc CPU identified as i.MX6DL/SOLO, silicon rev 1.1 PERCPU: Embedded 7 pages/cpu @8bc06000 s5184 r8192 d15296 u32768 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048 Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 512MB = 512MB total Memory: 508996k/508996k available, 15292k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xf4600000 - 0xffe00000 ( 184 MB) vmalloc : 0xa0800000 - 0xf2000000 (1304 MB) lowmem : 0x80000000 - 0xa0000000 ( 512 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003a000 ( 200 kB) .text : 0x8003a000 - 0x805aca0c (5579 kB) .data : 0x805ae000 - 0x805fc700 ( 314 kB) .bss : 0x805fc724 - 0x80627674 ( 172 kB) SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms Set periph_clk's parent to pll2_pfd_400M! arm_max_freq=800MHz MXC_Early serial console at MMIO 0x2020000 (options '115200') bootconsole [ttymxc0] enabled Console: colour dummy device 80x30 Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available Brought up 1 CPUs SMP: Total of 1 processors activated (1581.05 BogoMIPS). print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B bio: create slab <bio-0> at 0 mxs-dma mxs-dma-apbh: initialized print_constraints: SPKVDD: 4200 mV print_constraints: vmmc: 3300 mV SCSI subsystem initialized spi_imx imx6q-ecspi.0: probed usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb mc_pfuze 1-0008: recv failed!:-5,80 mc_pfuze: probe of 1-0008 failed with error -1 imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized max17135 2-0048: PMIC MAX17135 for eInk display i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 5, 196608 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Freeing initrd memory: 4436K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is disabled for i.MX6 cpaddr = a0820000 suspend_iram_base=a08b4000 PM driver module loaded IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. msgmni has been set to 1002 cryptodev: driver loaded. io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb _regulator_get: get() with no identifier imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) Console: switching to colour frame buffer device 128x48 mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized Serial: IMX driver imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX console [ttymxc0] enabled, bootconsole disabled console [ttymxc0] enabled, bootconsole disabled loop: module loaded m25p80 spi0.0: unrecognized JEDEC id ffffff GPMI NAND driver registered. (IMX) vcan: Virtual CAN interface driver FEC Ethernet Driver fec_enet_mii_bus: probed Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. ARC USBOTG Device Controller driver (1 August 2005) add wake up source irq 75 g_file_storage gadget: controller 'fsl-usb2-udc' not recognized check_parameters:UTP settings are in place now, overriding defaults g_file_storage gadget: No serial-number string provided! g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010 g_file_storage gadget: Number of LUNs=1 fsl-usb2-udc: bind to driver g_file_storage mousedev: PS/2 mouse device common for all mice egalax_ts 1-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 1-0004 failed with error -5 egalax_ts 2-0004: egalax_ts: failed to read firmware version egalax_ts: probe of 2-0004 failed with error -5 snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered usbcore: registered new interface driver usbhid usbhid: USB HID core driver Cirrus Logic CS42888 ALSA SoC Codec Driver i2c-core: driver [cs42888] using legacy suspend method i2c-core: driver [cs42888] using legacy resume method imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first. imx_3stack asoc driver ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) Bluetooth: RFCOMM TTY layer initialized Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 Bus freq driver module loaded Bus freq driver Enabled mxc_dvfs_core_probe DVFS driver module loaded regulator_init_complete: SPKVDD: incomplete constraints, leaving on snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0) Freeing init memory: 200K Starting UTP ln: /etc/mtab: File exists disable turn off display Starting the hotplug events dispatcher udevd Synthesizing initial hotplug events udevd (2072): /proc/2072/oom_adj is deprecated, please use /proc/2072/oom_score_adj instead. g_file_storage gadget: high speed config #1 mmc2: new high speed DDR MMC card at address 0001 mmcblk0: mmc2:0001 MMC08G 7.32 GiB mmcblk0boot0: mmc2:0001 MMC08G partition 1 2.00 MiB mmcblk0boot1: mmc2:0001 MMC08G partition 2 2.00 MiB mmcblk0: p1 mmcblk0boot1: unknown partition table mmcblk0boot0: unknown partition table uuc 0.4 [built Aug 16 2013 01:24:08] UTP: Waiting for device to appear UTP: file/device node /dev/utp already exists cpu_id is 0 UTP: received command 'send' UTP: sending Success to kernel for command send. UTP: received command '$ tar xf $FILE ' UTP: executing "tar xf $FILE " UTP: sending Success to kernel for command $ tar xf $FILE . utp_poll: pass returned. UTP: received command '$ sh mksdcard.sh /dev/mmcblk0' UTP: executing "sh mksdcard.sh /dev/mmcblk0" 1+0 records in 1+0 records out 1024 bytes (1.0KB) copied, 0.031571 seconds, 31.7KB/s Checking that no-one is using this disk right now ... mmcblk0: unknown partition table OK Disk /dev/mmcblk0: 240128 cylinders, 4 heads, 16 sectors/track sfdisk: ERROR: sector 0 does not have an msdos signature /dev/mmcblk0: unrecognized partition table type Old situation: No partitions found New situation: Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End MiB #blocks Id System /dev/mmcblk0p1 10 7503 7494 7673856 83 Linux /dev/mmcblk0p2 0 - 0 0 0 Empty /dev/mmcblk0p3 0 - 0 0 0 Empty /dev/mmcblk0p4 0 - 0 0 0 Empty Warning: no primary partition is marked bootable (active) This does not matter for LILO, but the DOS MBR will not boot this disk. Successfully wrote the new partition table Re-reading the partition table ... mmcblk0: p1 If you created or changed a DOS partition, /dev/foo7, say, then use dd(1) to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1 (See fdisk(8).) UTP: sending Success to kernel for command $ sh mksdcard.sh /dev/mmcblk0. utp_poll: pass returned. UTP: received command 'send' UTP: sending Success to kernel for command send. UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync' UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync" 420+1 records in 420+1 records out 430248 bytes (420.2KB) copied, 1.197707 seconds, 350.8KB/s UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync. utp_poll: pass returned. UTP: received command 'send' UTP: sending Success to kernel for command send. UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync' UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync" 3+1 records in 3+1 records out 3860944 bytes (3.7MB) copied, 1.452290 seconds, 2.5MB/s UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync. utp_poll: pass returned. UTP: received command '$ mkfs.ext3 -j /dev/mmcblk0p1' UTP: executing "mkfs.ext3 -j /dev/mmcblk0p1" mke2fs 1.41.4 (27-Jan-2009) Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) 480496 inodes, 1918464 blocks 95923 blocks (5.00%) reserved for the super user First data block=0 Maximum filesystem blocks=1967128576 59 block groups 32768 blocks per group, 32768 fragments per group 8144 inodes per group Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632 Writing inode tables: 0/59 1/59 2/59 3/59 4/59 5/59 6/59 7/59 8/59 9/59 10/59 11/59 12/59 13/59 14/59 15/59 16/59 17/59 18/59 19/59 20/59 21/59 22/59 23/59 24/59 25/59 26/59 27/59 28/59 29/59 30/59 31/59 32/59 33/59 34/59 35/59 36/59 37/59 38/59 39/59 40/59 41/59 42/59 43/59 44/59 45/59 46/59 47/59 48/59 49/59 50/59 51/59 52/59 53/59 54/59 55/59 56/59 57/59 58/59 done Creating journal (32768 blocks): done Writing superblocks and filesystem accounting information: done This filesystem will be automatically checked every 39 mounts or 180 days, whichever comes first. Use tune2fs -c or -i to override. UTP: sending Success to kernel for command $ mkfs.ext3 -j /dev/mmcblk0p1. utp_poll: pass returned. UTP: received command '$ mkdir -p /mnt/mmcblk0p1' UTP: executing "mkdir -p /mnt/mmcblk0p1" UTP: sending Success to kernel for command $ mkdir -p /mnt/mmcblk0p1. utp_poll: pass returned. UTP: received command '$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1' UTP: executing "mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1" EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p1): using internal journal EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode UTP: sending Success to kernel for command $ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1. utp_poll: pass returned. UTP: received command 'pipe tar -jxv -C /mnt/mmcblk0p1' pid is 3106, UTP: executing "tar -jxv -C /mnt/mmcblk0p1" UTP: sending Success to kernel for command pipe tar -jxv -C /mnt/mmcblk0p1. bin/ bin/realpath bin/mount bin/dmesg bin/rev bin/traceroute bin/login bin/iprule bin/lspci bin/mesg bin/iptunnel bin/dumpleases bin/delgroup bin/ping bin/fgrep bin/vlock bin/head bin/diff bin/catv bin/whoami bin/md5sum bin/install bin/zcat bin/fgconsole bin/smemcap bin/uptime bin/passwd bin/taskset bin/gzip bin/mpstat bin/more bin/unix2dos bin/env bin/cut bin/cp bin/bzcat bin/egrep bin/top bin/test bin/sort bin/find bin/yes bin/date bin/tee bin/unxz bin/busybox bin/chgrp bin/bunzip2 bin/dnsdomainname bin/rx bin/stty bin/iplink bin/nc bin/grep bin/kill bin/powertop bin/true bin/sha1sum bin/false bin/uname bin/rmdir bin/seq bin/mktemp bin/pmap bin/clear bin/resize bin/dumpkmap bin/deluser bin/time bin/getopt bin/[ bin/dc bin/which bin/cksum bin/su bin/killall bin/wget bin/dirname bin/xzcat bin/tail bin/tar bin/nice bin/gunzip bin/ipaddr bin/who bin/expr bin/unzip bin/logger bin/chmod bin/tr bin/df bin/ftpput bin/mkdir bin/renice bin/dd bin/cat bin/hostname bin/adduser bin/mknod bin/sh bin/length bin/dos2unix bin/patch bin/iproute bin/cmp bin/openvt bin/sleep bin/hexdump bin/uniq bin/flock bin/telnet bin/ls bin/rm bin/ftpget bin/od bin/ps bin/ln bin/addgroup bin/cal bin/iostat bin/bashbug bin/base64 bin/chown bin/run-parts bin/hostid bin/id bin/[[ bin/usleep bin/sync bin/free bin/reset bin/pwd bin/tftp bin/lsusb bin/netstat bin/wc bin/wall bin/touch bin/bash bin/logname bin/printf bin/ash bin/tty bin/vi bin/awk bin/nslookup bin/xargs bin/umount bin/basename bin/mkfifo bin/xz bin/deallocvt bin/readlink bin/echo bin/mv bin/less bin/sed bin/chvt bin/du dev/ dev/null dev/console dev/mtab dev/tty etc/ etc/hosts.deny etc/inputrc etc/issue.net etc/shadow etc/profile etc/passwd etc/rc.d/ etc/rc.d/rc.serial etc/rc.d/rc.modules etc/rc.d/rcS etc/rc.d/rc_mxc.S etc/rc.d/init.d/ etc/rc.d/init.d/filesystems etc/rc.d/init.d/udev etc/rc.d/init.d/smb etc/rc.d/init.d/mdev etc/rc.d/init.d/modules etc/rc.d/init.d/inetd etc/rc.d/init.d/mount-proc-sys etc/rc.d/init.d/portmap etc/rc.d/init.d/dhcp etc/rc.d/init.d/hostname etc/rc.d/init.d/dropbear etc/rc.d/init.d/syslog etc/rc.d/init.d/settime etc/rc.d/init.d/devfsd etc/rc.d/init.d/network etc/rc.d/init.d/hotplug etc/rc.d/init.d/sshd etc/rc.d/init.d/dhcpd etc/rc.d/init.d/depmod etc/rc.d/init.d/boa etc/rc.d/rc.local etc/rc.d/rc.conf etc/printcap etc/inittab etc/udev/ etc/udev/udev.conf etc/udev/rules.d/ etc/udev/rules.d/10-imx.rules etc/udev/rules.d/60-persistent-storage.rules etc/udev/rules.d/80-drivers.rules etc/udev/rules.d/95-udev-late.rules etc/udev/rules.d/60-persistent-input.rules etc/udev/rules.d/60-persistent-storage-tape.rules etc/udev/rules.d/05-udev-early.rules etc/udev/rules.d/40-alsa.rules etc/udev/rules.d/50-udev-default.rules etc/hosts.allow etc/resolv.conf etc/protocols etc/host.conf etc/modprobe.conf etc/devfsd.conf etc/mime.types etc/securetty.orig etc/issue etc/mdev.conf etc/inetd.conf etc/busybox.conf etc/securetty etc/fstab etc/udhcpd.conf etc/services etc/hotplug/ etc/hotplug/pci/ etc/hotplug/hotplug.functions etc/hotplug/dasd.agent etc/hotplug/usb.handmap etc/hotplug/tape.agent etc/hotplug/usb/ etc/hotplug/input.rc etc/hotplug/input.agent etc/hotplug/usb.usermap etc/hotplug/usb.rc etc/hotplug/usb.agent etc/hotplug/scsi.agent etc/hotplug/ieee1394.agent etc/hotplug/net.agent etc/hotplug/pci.rc etc/hotplug/firmware.agent etc/hotplug/pci.agent etc/hotplug/blacklist etc/hotplug/usb.distmap etc/exports etc/group etc/sysctl.conf etc/ltib-release etc/nsswitch.conf etc/hosts etc/profile.orig etc/shells etc/hotplug.d/ etc/hotplug.d/default/ etc/hotplug.d/default/default.hotplug home/ home/user/ home/user/.rhosts lib/ lib/libnss_dns.so.2 lib/libanl-2.11.1.so lib/libutil.so.1 lib/libnss_nis.so.2 lib/libvolume_id.so.0 lib/libtermcap.so.2 lib/libutil-2.11.1.so lib/ld-2.11.1.so lib/libstdc++.so.6 lib/udev/ lib/udev/vol_id lib/udev/path_id lib/udev/firmware.sh lib/udev/usb_id lib/libnss_nisplus.so.2 lib/libBrokenLocale-2.11.1.so lib/libdl-2.11.1.so lib/libnss_hesiod-2.11.1.so lib/libc-2.11.1.so lib/libnss_hesiod.so.2 lib/libcrypt-2.11.1.so lib/librt-2.11.1.so lib/libc.so.6 lib/libgcc_s.so lib/libtermcap.so.2.0.8 lib/modules/ lib/modules/2.6.38-1096-gc49343d/ lib/modules/2.6.38-1096-gc49343d/modules.order lib/modules/2.6.38-1096-gc49343d/build lib/modules/2.6.38-1096-gc49343d/modules.builtin lib/modules/2.6.38-1096-gc49343d/source lib/modules/2.6.38-1096-gc49343d/test/ lib/modules/2.6.38-1096-gc49343d/modules.dep lib/modules/2.6.38-1096-gc49343d/kernel/ lib/modules/2.6.38-1096-gc49343d/kernel/crypto/ lib/modules/2.6.38-1096-gc49343d/kernel/crypto/tcrypt.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/scsi/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/scsi/scsi_wait_scan.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_serial.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_ether.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_file_storage.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_audio.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/misc/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/misc/mxs-perfmon.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-cypress.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-a4tech.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-sunplus.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-petalynx.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-pl.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-sony.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-ezkey.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-monterey.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-belkin.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-samsung.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-gyration.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-microsoft.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-apple.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-cherry.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-chicony.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-logitech.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/gpu-viv/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/gpu-viv/galcore.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/mlb/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/mlb/mxc_mlb150.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/gspca/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/gspca/gspca_main.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/uvc/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/uvc/uvcvideo.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5642_camera.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/adv7180_tvin.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_enc.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5640_camera_mipi.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_csi_enc.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/mxc_v4l2_capture.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_still.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov3640_camera.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov8820_camera_mipi.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_vf_sdc.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.ko lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5640_camera.ko lib/modules/2.6.38-1096-gc49343d/kernel/lib/ lib/modules/2.6.38-1096-gc49343d/kernel/lib/crc-ccitt.ko lib/modules/2.6.38-1096-gc49343d/kernel/fs/ lib/modules/2.6.38-1096-gc49343d/kernel/fs/autofs4/ lib/modules/2.6.38-1096-gc49343d/kernel/fs/autofs4/autofs4.ko lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/ lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/nls_ascii.ko lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/nls_utf8.ko lib/libssp.so.0 lib/ld-linux.so.3 lib/libanl.so.1 lib/libvolume_id.so.0.81.0 lib/libnss_compat.so.2 lib/libSegFault.so lib/libthread_db-1.0.so lib/libnss_files-2.11.1.so lib/libnss_files.so.2 lib/libthread_db.so.1 lib/libresolv.so.2 lib/libnss_dns-2.11.1.so lib/librt.so.1 lib/libnss_compat-2.11.1.so lib/libnsl-2.11.1.so lib/libpcprofile.so lib/libtermcap.so lib/libnss_nisplus-2.11.1.so lib/libnsl.so.1 lib/libgcc_s.so.1 lib/libresolv-2.11.1.so lib/libstdc++.so.6.0.13 lib/libmemusage.so lib/libm.so.6 lib/libm-2.11.1.so lib/libpthread.so.0 lib/libcrypt.so.1 lib/libnss_nis-2.11.1.so lib/firmware/ lib/firmware/LICENCE.atheros_firmware lib/firmware/sdma/ lib/firmware/sdma/sdma-imx35-to1.bin lib/firmware/sdma/sdma-imx31-to2.bin lib/firmware/sdma/sdma-imx51-to3.bin lib/firmware/sdma/sdma-imx31-to1.bin lib/firmware/sdma/sdma-imx35-to2.bin lib/firmware/sdma/sdma-imx53-to1.bin lib/firmware/sdma/sdma-imx25-to1.bin lib/firmware/vpu/ lib/firmware/vpu/vpu_fw_imx6d.bin lib/firmware/vpu/vpu_fw_imx51.bin lib/firmware/vpu/vpu_fw_imx6q.bin lib/firmware/vpu/vpu_fw_imx27_TO2.bin lib/firmware/vpu/Android.mk lib/firmware/vpu/vpu_fw_imx53.bin lib/firmware/vpu/vpu_fw_imx27_TO1.bin lib/firmware/ar3k/ lib/firmware/ar3k/Android.mk lib/firmware/ar3k/30101/ lib/firmware/ar3k/30101/PS_ASIC.pst lib/firmware/ar3k/30101/ar3kbdaddr.pst lib/firmware/ar3k/30101/RamPatch.txt lib/firmware/ar3k/30101/Readme.txt lib/firmware/Android.mk lib/firmware/README lib/firmware/ath6k/ lib/firmware/ath6k/Android.mk lib/firmware/ath6k/AR6102/ lib/firmware/ath6k/AR6102/eeprom.bin lib/firmware/ath6k/AR6102/data.patch.hw2_0.bin lib/firmware/ath6k/AR6102/calData_ar6102_15dBm.bin lib/firmware/ath6k/AR6102/eeprom.data lib/firmware/ath6k/AR6102/athwlan.bin.z77 lib/firmware/ath6k/AR6102/README.txt lib/firmware/ath6k/AR6003/ lib/firmware/ath6k/AR6003/hw1.0/ lib/firmware/ath6k/AR6003/hw1.0/otp.bin.z77 lib/firmware/ath6k/AR6003/hw1.0/bdata.SD32.bin lib/firmware/ath6k/AR6003/hw1.0/athwlan.bin.z77 lib/firmware/ath6k/AR6003/hw1.0/bdata.WB31.bin lib/firmware/ath6k/AR6003/hw1.0/data.patch.bin lib/firmware/ath6k/AR6003/hw1.0/bdata.SD31.bin lib/firmware/ath6k/AR6003/PS_ASIC.pst lib/firmware/ath6k/AR6003/PS_ASIC_aclLowPri.pst lib/firmware/ath6k/AR6003/hw2.0/ lib/firmware/ath6k/AR6003/hw2.0/otp.bin.z77 lib/firmware/ath6k/AR6003/hw2.0/data.rom.bin lib/firmware/ath6k/AR6003/hw2.0/regTest.bin lib/firmware/ath6k/AR6003/hw2.0/perfcnt.bin lib/firmware/ath6k/AR6003/hw2.0/bdata.SD32.bin lib/firmware/ath6k/AR6003/hw2.0/memtest.bin lib/firmware/ath6k/AR6003/hw2.0/data.patch.hw2_0.bin lib/firmware/ath6k/AR6003/hw2.0/athwlan.bin lib/firmware/ath6k/AR6003/hw2.0/otp_test.bin lib/firmware/ath6k/AR6003/hw2.0/utf.bin lib/firmware/ath6k/AR6003/hw2.0/fakeBoardData_AR6003_v2_0.bin lib/firmware/ath6k/AR6003/hw2.0/apidemo.bin lib/firmware/ath6k/AR6003/hw2.0/otp.bin lib/firmware/ath6k/AR6003/hw2.0/regulatoryData_AG.bin lib/firmware/ath6k/AR6003/hw2.0/endpointping.bin lib/firmware/ath6k/AR6003/hw2.0/athwlan.bin.z77 lib/firmware/ath6k/AR6003/hw2.0/serialport.bin lib/firmware/ath6k/AR6003/hw2.0/device.bin lib/firmware/ath6k/AR6003/hw2.0/whaltest.bin lib/firmware/ath6k/AR6003/hw2.0/bdata.WB31.bin lib/firmware/ath6k/AR6003/hw2.0/athtcmd_ram.bin lib/firmware/ath6k/AR6003/hw2.0/data.patch.bin lib/firmware/ath6k/AR6003/hw2.0/bdata.SD31.bin lib/firmware/ath6k/AR6003/RamPatch.txt lib/firmware/ath6k/AR6003/hw2.1.1/ lib/firmware/ath6k/AR6003/hw2.1.1/athwlan.bin lib/firmware/ath6k/AR6003/hw2.1.1/otp.bin lib/firmware/ath6k/AR6003/hw2.1.1/data.patch.bin lib/firmware/ath6k/AR6003/hw2.1.1/bdata.SD31.bin lib/libBrokenLocale.so.1 lib/libssp.so.0.0.0 lib/libdl.so.2 lib/libpthread-2.11.1.so lost+found/ mnt/ mnt/floppy/ mnt/rwfs/ mnt/src/ mnt/cdrom/ mnt/nfs/ opt/ proc/ root/ root/.kobs rootfs.tar.bz2 sbin/ sbin/udevcontrol sbin/halt sbin/insmod sbin/ifdown sbin/telnetd sbin/syslogd sbin/chroot sbin/dhcprelay sbin/lsmod sbin/udevsettle sbin/udevadm sbin/klogd sbin/blockdev sbin/ubidetach sbin/ubiattach sbin/rmmod sbin/modinfo sbin/modprobe sbin/nbd-client sbin/rdate sbin/inetd sbin/ifconfig sbin/udevtrigger sbin/hwclock sbin/udevd sbin/loadkmap sbin/ip sbin/fdisk sbin/losetup sbin/fsck.minix sbin/adjtimex sbin/logread sbin/setlogcons sbin/mkfs.minix sbin/loadfont sbin/fbset sbin/swapoff sbin/init sbin/pivot_root sbin/udhcpd sbin/mke2fs sbin/mkfs.ext2 sbin/httpd sbin/sysctl sbin/hotplug sbin/watchdog sbin/udhcpc sbin/bootchartd sbin/ntpd sbin/mkswap sbin/poweroff sbin/reboot sbin/ifup sbin/arp sbin/route sbin/swapon sbin/getty sys/ tmp/ tmp/ltib/ unit_tests/ unit_tests/mxc_iim_test.out unit_tests/autorun-mxc_uart.sh unit_tests/scc_test unit_tests/autorun-wdog.sh unit_tests/config_encdec unit_tests/mxc_v4l2_overlay.out unit_tests/rtctest.out unit_tests/mxc_keyb_test.sh unit_tests/autorun-usb-gadget.sh unit_tests/check_ioctls.out unit_tests/autorun-scc2.sh unit_tests/audio8k16S.wav unit_tests/check_2w1r.out unit_tests/ar3k-bt-start.sh unit_tests/autorun-vpu.sh unit_tests/check_recording.out unit_tests/mxc_vpu_test.out unit_tests/autorun-suite.txt unit_tests/mxc_spi_test1.out unit_tests/memtool unit_tests/autorun-mmc.sh unit_tests/autorun-owire.sh unit_tests/mxc_v4l2_capture.out unit_tests/autorun-rtc.sh unit_tests/mxc_i2c_test_samsung_cam.out unit_tests/mxc_uart_test.out unit_tests/autorun-usb-host.sh unit_tests/mxc_pf_test.out unit_tests/encrypt_decrypt_tests.sh unit_tests/autorun-v4l2.sh unit_tests/fail_mode_tests.sh unit_tests/mxc_l2switch_test.out unit_tests/config_enc unit_tests/wdt_driver_test.out unit_tests/autorun-pf.sh unit_tests/autorun-asrc.sh unit_tests/check_mixer.out unit_tests/mxc_tve_test.sh unit_tests/mxc_sdma_test.out unit_tests/key_slot_tests.sh unit_tests/autorun-ata.sh unit_tests/config_net unit_tests/mxc_isl29023.out unit_tests/check_synchronization.out unit_tests/config_dec unit_tests/autorun.sh unit_tests/mxc_asrc_test.out unit_tests/autorun-oprofile.sh unit_tests/mxc_i2c_test.out unit_tests/autorun-firi.sh unit_tests/autorun-fb.sh unit_tests/rtc_timesetnotification_test.out unit_tests/autorun-scc.sh unit_tests/ipudev_config_file unit_tests/mxc_v4l2_tvin.out unit_tests/hciattach-ar3k.bin unit_tests/autorun-keypad.sh unit_tests/mxc_irlan_test.sh unit_tests/mxc_v4l2_still.out unit_tests/rtcwakeup.out unit_tests/check_volume2.out unit_tests/dryice.sh unit_tests/partition_tests.sh unit_tests/mxc_v4l2_output.out unit_tests/autorun-sound.sh unit_tests/stefan_interlaced_320x240_5frames.yv12 unit_tests/check_audio.out unit_tests/mxc_i2c_test_usb.out unit_tests/test-utils.sh unit_tests/mxc_fb_test.out unit_tests/test_subs.sh unit_tests/mxc_i2c_test_magna_cam.out unit_tests/mxc_uart_xmit_test.out unit_tests/scc2_test.out unit_tests/check_minor_open.out unit_tests/scc_setup.sh unit_tests/mxc_ipudev_test.out unit_tests/akiyo.mp4 unit_tests/scc2_setup.sh unit_tests/mxc_i2c_slave_test.out unit_tests/mxc_mlb_test.out unit_tests/autorun-ipu.sh usr/ usr/include/ usr/include/ipu.h usr/include/termcap.h usr/include/libvolume_id.h usr/include/pxp_lib.h usr/include/mxc_ipu_hl_lib.h usr/include/vpu_io.h usr/include/vpu_lib.h usr/share/ usr/share/doc/ usr/share/doc/linux-firmware/ usr/share/doc/linux-firmware/licenses/ usr/share/doc/linux-firmware/licenses/vpu/ usr/share/doc/linux-firmware/licenses/vpu/EULA usr/share/doc/linux-firmware/licenses/ar3k/ usr/share/doc/linux-firmware/licenses/ar3k/30101/ usr/share/doc/linux-firmware/licenses/ar3k/30101/LICENSE_Apache.txt usr/share/doc/linux-firmware/licenses/COPYING usr/share/doc/linux-firmware/licenses/ath6k/ usr/share/doc/linux-firmware/licenses/ath6k/AR6102/ usr/share/doc/linux-firmware/licenses/ath6k/AR6102/License.txt usr/share/doc/linux-firmware/licenses/ath6k/AR6003/ usr/share/doc/linux-firmware/licenses/ath6k/AR6003/README.chromium usr/share/doc/linux-firmware/licenses/ath6k/AR6003/License.txt usr/share/udhcpc/ usr/share/udhcpc/default.script usr/bin/ usr/bin/startx usr/bin/kobs-ng usr/bin/udevtest usr/bin/udevinfo usr/src/ usr/src/linux/ usr/src/linux/include/ usr/src/linux/include/scsi/ usr/src/linux/include/scsi/scsi_bsg_fc.h usr/src/linux/include/scsi/.install usr/src/linux/include/scsi/scsi_netlink.h usr/src/linux/include/scsi/fc/ usr/src/linux/include/scsi/fc/fc_gs.h usr/src/linux/include/scsi/fc/.install usr/src/linux/include/scsi/fc/fc_fs.h usr/src/linux/include/scsi/fc/fc_ns.h usr/src/linux/include/scsi/fc/fc_els.h usr/src/linux/include/scsi/fc/..install.cmd usr/src/linux/include/scsi/..install.cmd usr/src/linux/include/scsi/scsi_netlink_fc.h usr/src/linux/include/video/ usr/src/linux/include/video/.install usr/src/linux/include/video/edid.h usr/src/linux/include/video/sisfb.h usr/src/linux/include/video/..install.cmd usr/src/linux/include/video/uvesafb.h usr/src/linux/include/.install usr/src/linux/include/xen/ usr/src/linux/include/xen/privcmd.h usr/src/linux/include/xen/.install usr/src/linux/include/xen/..install.cmd usr/src/linux/include/xen/evtchn.h usr/src/linux/include/asm-generic/ usr/src/linux/include/asm-generic/stat.h usr/src/linux/include/asm-generic/posix_types.h usr/src/linux/include/asm-generic/errno.h usr/src/linux/include/asm-generic/fcntl.h usr/src/linux/include/asm-generic/bitsperlong.h usr/src/linux/include/asm-generic/auxvec.h usr/src/linux/include/asm-generic/siginfo.h usr/src/linux/include/asm-generic/setup.h usr/src/linux/include/asm-generic/sockios.h usr/src/linux/include/asm-generic/ipcbuf.h usr/src/linux/include/asm-generic/.install usr/src/linux/include/asm-generic/shmparam.h usr/src/linux/include/asm-generic/ucontext.h usr/src/linux/include/asm-generic/unistd.h usr/src/linux/include/asm-generic/ioctls.h usr/src/linux/include/asm-generic/swab.h usr/src/linux/include/asm-generic/poll.h usr/src/linux/include/asm-generic/resource.h usr/src/linux/include/asm-generic/socket.h usr/src/linux/include/asm-generic/mman.h usr/src/linux/include/asm-generic/int-l64.h usr/src/linux/include/asm-generic/types.h usr/src/linux/include/asm-generic/ioctl.h usr/src/linux/include/asm-generic/termbits.h usr/src/linux/include/asm-generic/signal.h usr/src/linux/include/asm-generic/msgbuf.h usr/src/linux/include/asm-generic/errno-base.h usr/src/linux/include/asm-generic/mman-common.h usr/src/linux/include/asm-generic/param.h usr/src/linux/include/asm-generic/statfs.h usr/src/linux/include/asm-generic/termios.h usr/src/linux/include/asm-generic/..install.cmd usr/src/linux/include/asm-generic/shmbuf.h usr/src/linux/include/asm-generic/sembuf.h usr/src/linux/include/asm-generic/int-ll64.h usr/src/linux/include/asm-generic/signal-defs.h usr/src/linux/include/sound/ usr/src/linux/include/sound/hdspm.h usr/src/linux/include/sound/asequencer.h usr/src/linux/include/sound/hdsp.h usr/src/linux/include/sound/asound_fm.h usr/src/linux/include/sound/.install usr/src/linux/include/sound/asound.h usr/src/linux/include/sound/sfnt_info.h usr/src/linux/include/sound/..install.cmd usr/src/linux/include/sound/emu10k1.h usr/src/linux/include/sound/sb16_csp.h usr/src/linux/include/..install.cmd usr/src/linux/include/mtd/ usr/src/linux/include/mtd/mtd-abi.h usr/src/linux/include/mtd/.install usr/src/linux/include/mtd/nftl-user.h usr/src/linux/include/mtd/mtd-user.h usr/src/linux/include/mtd/ubi-user.h usr/src/linux/include/mtd/inftl-user.h usr/src/linux/include/mtd/..install.cmd usr/src/linux/include/linux/ usr/src/linux/include/linux/hid.h usr/src/linux/include/linux/pps.h usr/src/linux/include/linux/i2c.h usr/src/linux/include/linux/connector.h usr/src/linux/include/linux/ipu.h usr/src/linux/include/linux/auto_fs4.h usr/src/linux/include/linux/romfs_fs.h usr/src/linux/include/linux/nubus.h usr/src/linux/include/linux/cyclades.h usr/src/linux/include/linux/ext2_fs.h usr/src/linux/include/linux/can/ usr/src/linux/include/linux/can/.install usr/src/linux/include/linux/can/netlink.h usr/src/linux/include/linux/can/error.h usr/src/linux/include/linux/can/raw.h usr/src/linux/include/linux/can/bcm.h usr/src/linux/include/linux/can/..install.cmd usr/src/linux/include/linux/in6.h usr/src/linux/include/linux/ip.h usr/src/linux/include/linux/virtio_rng.h usr/src/linux/include/linux/wait.h usr/src/linux/include/linux/wimax.h usr/src/linux/include/linux/stat.h usr/src/linux/include/linux/rtc.h usr/src/linux/include/linux/ipc.h usr/src/linux/include/linux/pg.h usr/src/linux/include/linux/quota.h usr/src/linux/include/linux/dn.h usr/src/linux/include/linux/posix_types.h usr/src/linux/include/linux/dlm_device.h usr/src/linux/include/linux/fib_rules.h usr/src/linux/include/linux/keyboard.h usr/src/linux/include/linux/tipc.h usr/src/linux/include/linux/utsname.h usr/src/linux/include/linux/atm_he.h usr/src/linux/include/linux/virtio_net.h usr/src/linux/include/linux/errno.h usr/src/linux/include/linux/falloc.h usr/src/linux/include/linux/arcfb.h usr/src/linux/include/linux/dcbnl.h usr/src/linux/include/linux/dlm.h usr/src/linux/include/linux/fcntl.h usr/src/linux/include/linux/tipc_config.h usr/src/linux/include/linux/rose.h usr/src/linux/include/linux/mempolicy.h usr/src/linux/include/linux/efs_fs_sb.h usr/src/linux/include/linux/major.h usr/src/linux/include/linux/dvb/ usr/src/linux/include/linux/dvb/video.h usr/src/linux/include/linux/dvb/version.h usr/src/linux/include/linux/dvb/.install usr/src/linux/include/linux/dvb/net.h usr/src/linux/include/linux/dvb/frontend.h usr/src/linux/include/linux/dvb/dmx.h usr/src/linux/include/linux/dvb/osd.h usr/src/linux/include/linux/dvb/ca.h usr/src/linux/include/linux/dvb/..install.cmd usr/src/linux/include/linux/dvb/audio.h usr/src/linux/include/linux/nfs.h usr/src/linux/include/linux/coda_psdev.h usr/src/linux/include/linux/fiemap.h usr/src/linux/include/linux/videodev2.h usr/src/linux/include/linux/map_to_7segment.h usr/src/linux/include/linux/errqueue.h usr/src/linux/include/linux/virtio_blk.h usr/src/linux/include/linux/xattr.h usr/src/linux/include/linux/pktcdvd.h usr/src/linux/include/linux/netfilter_ipv4.h usr/src/linux/include/linux/chio.h usr/src/linux/include/linux/bpqether.h usr/src/linux/include/linux/auxvec.h usr/src/linux/include/linux/nvram.h usr/src/linux/include/linux/utime.h usr/src/linux/include/linux/nfs2.h usr/src/linux/include/linux/atmppp.h usr/src/linux/include/linux/atm_tcp.h usr/src/linux/include/linux/fd.h usr/src/linux/include/linux/hiddev.h usr/src/linux/include/linux/const.h usr/src/linux/include/linux/omapfb.h usr/src/linux/include/linux/rfkill.h usr/src/linux/include/linux/fanotify.h usr/src/linux/include/linux/ivtvfb.h usr/src/linux/include/linux/icmp.h usr/src/linux/include/linux/atmclip.h usr/src/linux/include/linux/cn_proc.h usr/src/linux/include/linux/coff.h usr/src/linux/include/linux/hdlcdrv.h usr/src/linux/include/linux/if_fc.h usr/src/linux/include/linux/atmioc.h usr/src/linux/include/linux/selinux_netlink.h usr/src/linux/include/linux/cdrom.h usr/src/linux/include/linux/veth.h usr/src/linux/include/linux/udp.h usr/src/linux/include/linux/gameport.h usr/src/linux/include/linux/securebits.h usr/src/linux/include/linux/times.h usr/src/linux/include/linux/atmdev.h usr/src/linux/include/linux/patchkey.h usr/src/linux/include/linux/if_strip.h usr/src/linux/include/linux/acct.h usr/src/linux/include/linux/timex.h usr/src/linux/include/linux/if_vlan.h usr/src/linux/include/linux/random.h usr/src/linux/include/linux/serial_core.h usr/src/linux/include/linux/if_tr.h usr/src/linux/include/linux/if_cablemodem.h usr/src/linux/include/linux/stddef.h usr/src/linux/include/linux/if_eql.h usr/src/linux/include/linux/ncp_fs.h usr/src/linux/include/linux/isdn_ppp.h usr/src/linux/include/linux/elf-em.h usr/src/linux/include/linux/sockios.h usr/src/linux/include/linux/netfilter_decnet.h usr/src/linux/include/linux/nfs_idmap.h usr/src/linux/include/linux/jffs2.h usr/src/linux/include/linux/ppp-comp.h usr/src/linux/include/linux/blktrace_api.h usr/src/linux/include/linux/telephony.h usr/src/linux/include/linux/pkt_cls.h usr/src/linux/include/linux/perf_event.h usr/src/linux/include/linux/version.h usr/src/linux/include/linux/usbdevice_fs.h usr/src/linux/include/linux/pci.h usr/src/linux/include/linux/if_frad.h usr/src/linux/include/linux/if_fddi.h usr/src/linux/include/linux/atalk.h usr/src/linux/include/linux/hpet.h usr/src/linux/include/linux/netfilter_bridge/ usr/src/linux/include/linux/netfilter_bridge/ebt_arp.h usr/src/linux/include/linux/netfilter_bridge/ebt_limit.h usr/src/linux/include/linux/netfilter_bridge/ebt_ulog.h usr/src/linux/include/linux/netfilter_bridge/.install usr/src/linux/include/linux/netfilter_bridge/ebt_802_3.h usr/src/linux/include/linux/netfilter_bridge/ebt_vlan.h usr/src/linux/include/linux/netfilter_bridge/ebt_pkttype.h usr/src/linux/include/linux/netfilter_bridge/ebt_nflog.h usr/src/linux/include/linux/netfilter_bridge/ebt_log.h usr/src/linux/include/linux/netfilter_bridge/ebt_mark_m.h usr/src/linux/include/linux/netfilter_bridge/ebt_among.h usr/src/linux/include/linux/netfilter_bridge/ebtables.h usr/src/linux/include/linux/netfilter_bridge/ebt_arpreply.h usr/src/linux/include/linux/netfilter_bridge/ebt_mark_t.h usr/src/linux/include/linux/netfilter_bridge/ebt_stp.h usr/src/linux/include/linux/netfilter_bridge/ebt_ip6.h usr/src/linux/include/linux/netfilter_bridge/..install.cmd usr/src/linux/include/linux/netfilter_bridge/ebt_nat.h usr/src/linux/include/linux/netfilter_bridge/ebt_ip.h usr/src/linux/include/linux/netfilter_bridge/ebt_redirect.h usr/src/linux/include/linux/mxc_sahara.h usr/src/linux/include/linux/usb/ usr/src/linux/include/linux/usb/g_printer.h usr/src/linux/include/linux/usb/.install usr/src/linux/include/linux/usb/gadgetfs.h usr/src/linux/include/linux/usb/ch9.h usr/src/linux/include/linux/usb/midi.h usr/src/linux/include/linux/usb/cdc.h usr/src/linux/include/linux/usb/tmc.h usr/src/linux/include/linux/usb/..install.cmd usr/src/linux/include/linux/usb/audio.h usr/src/linux/include/linux/usb/ch11.h usr/src/linux/include/linux/tty.h usr/src/linux/include/linux/synclink.h usr/src/linux/include/linux/uio.h usr/src/linux/include/linux/.install usr/src/linux/include/linux/can.h usr/src/linux/include/linux/ivtv.h usr/src/linux/include/linux/mii.h usr/src/linux/include/linux/prctl.h usr/src/linux/include/linux/ipx.h usr/src/linux/include/linux/nfs4.h usr/src/linux/include/linux/virtio_pci.h usr/src/linux/include/linux/atmsvc.h usr/src/linux/include/linux/a.out.h usr/src/linux/include/linux/kd.h usr/src/linux/include/linux/personality.h usr/src/linux/include/linux/fb.h usr/src/linux/include/linux/serio.h usr/src/linux/include/linux/tc_act/ usr/src/linux/include/linux/tc_act/tc_csum.h usr/src/linux/include/linux/tc_act/tc_ipt.h usr/src/linux/include/linux/tc_act/.install usr/src/linux/include/linux/tc_act/tc_pedit.h usr/src/linux/include/linux/tc_act/tc_skbedit.h usr/src/linux/include/linux/tc_act/tc_nat.h usr/src/linux/include/linux/tc_act/tc_mirred.h usr/src/linux/include/linux/tc_act/..install.cmd usr/src/linux/include/linux/tc_act/tc_gact.h usr/src/linux/include/linux/nfs3.h usr/src/linux/include/linux/keyctl.h usr/src/linux/include/linux/tiocl.h usr/src/linux/include/linux/scc.h usr/src/linux/include/linux/isl29023.h usr/src/linux/include/linux/sonet.h usr/src/linux/include/linux/agpgart.h usr/src/linux/include/linux/mxc_pf.h usr/src/linux/include/linux/time.h usr/src/linux/include/linux/sched.h usr/src/linux/include/linux/if_alg.h usr/src/linux/include/linux/wimax/ usr/src/linux/include/linux/wimax/i2400m.h usr/src/linux/include/linux/wimax/.install usr/src/linux/include/linux/wimax/..install.cmd usr/src/linux/include/linux/aio_abi.h usr/src/linux/include/linux/ultrasound.h usr/src/linux/include/linux/netlink.h usr/src/linux/include/linux/tcp.h usr/src/linux/include/linux/un.h usr/src/linux/include/linux/elf-fdpic.h usr/src/linux/include/linux/parport.h usr/src/linux/include/linux/ncp_no.h usr/src/linux/include/linux/bsg.h usr/src/linux/include/linux/in_route.h usr/src/linux/include/linux/qnx4_fs.h usr/src/linux/include/linux/sound.h usr/src/linux/include/linux/pci_regs.h usr/src/linux/include/linux/atm_nicstar.h usr/src/linux/include/linux/blk_types.h usr/src/linux/include/linux/mroute6.h usr/src/linux/include/linux/i2o-dev.h usr/src/linux/include/linux/unistd.h usr/src/linux/include/linux/binfmts.h usr/src/linux/include/linux/affs_hardblocks.h usr/src/linux/include/linux/lp.h usr/src/linux/include/linux/fs.h usr/src/linux/include/linux/pmic_external.h usr/src/linux/include/linux/pxp_dma.h usr/src/linux/include/linux/net_dropmon.h usr/src/linux/include/linux/genetlink.h usr/src/linux/include/linux/elf.h usr/src/linux/include/linux/qnxtypes.h usr/src/linux/include/linux/meye.h usr/src/linux/include/linux/hdreg.h usr/src/linux/include/linux/mxc_scc_driver.h usr/src/linux/include/linux/pmic_adc.h usr/src/linux/include/linux/neighbour.h usr/src/linux/include/linux/sysctl.h usr/src/linux/include/linux/swab.h usr/src/linux/include/linux/poll.h usr/src/linux/include/linux/netfilter_arp.h usr/src/linux/include/linux/x25.h usr/src/linux/include/linux/loop.h usr/src/linux/include/linux/sem.h usr/src/linux/include/linux/if_plip.h usr/src/linux/include/linux/uinput.h usr/src/linux/include/linux/ethtool.h usr/src/linux/include/linux/resource.h usr/src/linux/include/linux/net.h usr/src/linux/include/linux/hidraw.h usr/src/linux/include/linux/atmarp.h usr/src/linux/include/linux/i8k.h usr/src/linux/include/linux/mqueue.h usr/src/linux/include/linux/gigaset_dev.h usr/src/linux/include/linux/pmic_battery.h usr/src/linux/include/linux/phantom.h usr/src/linux/include/linux/virtio_console.h usr/src/linux/include/linux/mroute.h usr/src/linux/include/linux/ncp.h usr/src/linux/include/linux/virtio_9p.h usr/src/linux/include/linux/signalfd.h usr/src/linux/include/linux/mxc_v4l2.h usr/src/linux/include/linux/in.h usr/src/linux/include/linux/nfsacl.h usr/src/linux/include/linux/socket.h usr/src/linux/include/linux/taskstats.h usr/src/linux/include/linux/igmp.h usr/src/linux/include/linux/netfilter_bridge.h usr/src/linux/include/linux/icmpv6.h usr/src/linux/include/linux/atm_idt77105.h usr/src/linux/include/linux/sunrpc/ usr/src/linux/include/linux/sunrpc/.install usr/src/linux/include/linux/sunrpc/debug.h usr/src/linux/include/linux/sunrpc/..install.cmd usr/src/linux/include/linux/cdk.h usr/src/linux/include/linux/mman.h usr/src/linux/include/linux/eventpoll.h usr/src/linux/include/linux/pfkeyv2.h usr/src/linux/include/linux/nfs_fs.h usr/src/linux/include/linux/netfilter_ipv6.h usr/src/linux/include/linux/atmsap.h usr/src/linux/include/linux/dlm_netlink.h usr/src/linux/include/linux/phonet.h usr/src/linux/include/linux/raid/ usr/src/linux/include/linux/raid/.install usr/src/linux/include/linux/raid/md_p.h usr/src/linux/include/linux/raid/md_u.h usr/src/linux/include/linux/raid/..install.cmd usr/src/linux/include/linux/msg.h usr/src/linux/include/linux/vhost.h usr/src/linux/include/linux/reiserfs_xattr.h usr/src/linux/include/linux/dccp.h usr/src/linux/include/linux/vt.h usr/src/linux/include/linux/nbd.h usr/src/linux/include/linux/reiserfs_fs.h usr/src/linux/include/linux/if.h usr/src/linux/include/linux/ncp_mount.h usr/src/linux/include/linux/serial.h usr/src/linux/include/linux/if_infiniband.h usr/src/linux/include/linux/toshiba.h usr/src/linux/include/linux/if_ltalk.h usr/src/linux/include/linux/netfilter_ipv4/ usr/src/linux/include/linux/netfilter_ipv4/ipt_REJECT.h usr/src/linux/include/linux/netfilter_ipv4/ip_tables.h usr/src/linux/include/linux/netfilter_ipv4/ipt_realm.h usr/src/linux/include/linux/netfilter_ipv4/.install usr/src/linux/include/linux/netfilter_ipv4/ipt_ECN.h usr/src/linux/include/linux/netfilter_ipv4/ipt_ttl.h usr/src/linux/include/linux/netfilter_ipv4/ipt_CLUSTERIP.h usr/src/linux/include/linux/netfilter_ipv4/ipt_addrtype.h usr/src/linux/include/linux/netfilter_ipv4/ipt_ULOG.h usr/src/linux/include/linux/netfilter_ipv4/ipt_TTL.h usr/src/linux/include/linux/netfilter_ipv4/ipt_SAME.h usr/src/linux/include/linux/netfilter_ipv4/ipt_LOG.h usr/src/linux/include/linux/netfilter_ipv4/ipt_ah.h usr/src/linux/include/linux/netfilter_ipv4/..install.cmd usr/src/linux/include/linux/netfilter_ipv4/ip_queue.h usr/src/linux/include/linux/netfilter_ipv4/ipt_ecn.h usr/src/linux/include/linux/mxcfb.h usr/src/linux/include/linux/flat.h usr/src/linux/include/linux/joystick.h usr/src/linux/include/linux/byteorder/ usr/src/linux/include/linux/byteorder/little_endian.h usr/src/linux/include/linux/byteorder/.install usr/src/linux/include/linux/byteorder/big_endian.h usr/src/linux/include/linux/byteorder/..install.cmd usr/src/linux/include/linux/firewire-cdev.h usr/src/linux/include/linux/apm_bios.h usr/src/linux/include/linux/kernel.h usr/src/linux/include/linux/futex.h usr/src/linux/include/linux/if_tun.h usr/src/linux/include/linux/if_tunnel.h usr/src/linux/include/linux/limits.h usr/src/linux/include/linux/raw.h usr/src/linux/include/linux/generic_serial.h usr/src/linux/include/linux/filter.h usr/src/linux/include/linux/som.h usr/src/linux/include/linux/capi.h usr/src/linux/include/linux/cramfs_fs.h usr/src/linux/include/linux/tc_ematch/ usr/src/linux/include/linux/tc_ematch/tc_em_cmp.h usr/src/linux/include/linux/tc_ematch/tc_em_nbyte.h usr/src/linux/include/linux/tc_ematch/.install usr/src/linux/include/linux/tc_ematch/tc_em_meta.h usr/src/linux/include/linux/tc_ematch/..install.cmd usr/src/linux/include/linux/tc_ematch/tc_em_text.h usr/src/linux/include/linux/dm-ioctl.h usr/src/linux/include/linux/bfs_fs.h usr/src/linux/include/linux/blkpg.h usr/src/linux/include/linux/types.h usr/src/linux/include/linux/i2c-dev.h usr/src/linux/include/linux/ixjuser.h usr/src/linux/include/linux/if_addrlabel.h usr/src/linux/include/linux/l2tp.h usr/src/linux/include/linux/nfs_mount.h usr/src/linux/include/linux/if_arcnet.h usr/src/linux/include/linux/atmbr2684.h usr/src/linux/include/linux/ipv6_route.h usr/src/linux/include/linux/virtio_ring.h usr/src/linux/include/linux/if_addr.h usr/src/linux/include/linux/if_bridge.h usr/src/linux/include/linux/fdreg.h usr/src/linux/include/linux/ioctl.h usr/src/linux/include/linux/ipmi_msgdefs.h usr/src/linux/include/linux/adb.h usr/src/linux/include/linux/if_slip.h usr/src/linux/include/linux/mxc_asrc.h usr/src/linux/include/linux/suspend_ioctls.h usr/src/linux/include/linux/if_pppol2tp.h usr/src/linux/include/linux/net_tstamp.h usr/src/linux/include/linux/shm.h usr/src/linux/include/linux/cciss_ioctl.h usr/src/linux/include/linux/atm_eni.h usr/src/linux/include/linux/rds.h usr/src/linux/include/linux/hdlc/ usr/src/linux/include/linux/hdlc/.install usr/src/linux/include/linux/hdlc/ioctl.h usr/src/linux/include/linux/hdlc/..install.cmd usr/src/linux/include/linux/pmic_rtc.h usr/src/linux/include/linux/mtio.h usr/src/linux/include/linux/ip_vs.h usr/src/linux/include/linux/signal.h usr/src/linux/include/linux/nl80211.h usr/src/linux/include/linux/minix_fs.h usr/src/linux/include/linux/netfilter.h usr/src/linux/include/linux/elfcore.h usr/src/linux/include/linux/if_pppox.h usr/src/linux/include/linux/ip6_tunnel.h usr/src/linux/include/linux/gen_stats.h usr/src/linux/include/linux/nfsd/ usr/src/linux/include/linux/nfsd/syscall.h usr/src/linux/include/linux/nfsd/stats.h usr/src/linux/include/linux/nfsd/const.h usr/src/linux/include/linux/nfsd/.install usr/src/linux/include/linux/nfsd/debug.h usr/src/linux/include/linux/nfsd/..install.cmd usr/src/linux/include/linux/nfsd/nfsfh.h usr/src/linux/include/linux/nfsd/export.h usr/src/linux/include/linux/isdn_divertif.h usr/src/linux/include/linux/ipv6.h usr/src/linux/include/linux/magic.h usr/src/linux/include/linux/netrom.h usr/src/linux/include/linux/oom.h usr/src/linux/include/linux/fsl_devices.h usr/src/linux/include/linux/pmu.h usr/src/linux/include/linux/udf_fs_i.h usr/src/linux/include/linux/n_r3964.h usr/src/linux/include/linux/param.h usr/src/linux/include/linux/mxc_si4702.h usr/src/linux/include/linux/if_arp.h usr/src/linux/include/linux/ptrace.h usr/src/linux/include/linux/if_hippi.h usr/src/linux/include/linux/iso_fs.h usr/src/linux/include/linux/reboot.h usr/src/linux/include/linux/if_packet.h usr/src/linux/include/linux/if_bonding.h usr/src/linux/include/linux/cgroupstats.h usr/src/linux/include/linux/termios.h usr/src/linux/include/linux/imx_adc.h usr/src/linux/include/linux/cciss_defs.h usr/src/linux/include/linux/kdev_t.h usr/src/linux/include/linux/gfs2_ondisk.h usr/src/linux/include/linux/ppp_defs.h usr/src/linux/include/linux/netfilter_ipv6/ usr/src/linux/include/linux/netfilter_ipv6/ip6t_mh.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_LOG.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_hl.h usr/src/linux/include/linux/netfilter_ipv6/ip6_tables.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_HL.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_ipv6header.h usr/src/linux/include/linux/netfilter_ipv6/.install usr/src/linux/include/linux/netfilter_ipv6/ip6t_rt.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_opts.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_REJECT.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_ah.h usr/src/linux/include/linux/netfilter_ipv6/ip6t_frag.h usr/src/linux/include/linux/netfilter_ipv6/..install.cmd usr/src/linux/include/linux/..install.cmd usr/src/linux/include/linux/irqnr.h usr/src/linux/include/linux/snmp.h usr/src/linux/include/linux/sonypi.h usr/src/linux/include/linux/cm4000_cs.h usr/src/linux/include/linux/mxc_srtc.h usr/src/linux/include/linux/ppdev.h usr/src/linux/include/linux/virtio_ids.h usr/src/linux/include/linux/wanrouter.h usr/src/linux/include/linux/if_ec.h usr/src/linux/include/linux/inet_diag.h usr/src/linux/include/linux/isdn/ usr/src/linux/include/linux/isdn/capicmd.h usr/src/linux/include/linux/isdn/.install usr/src/linux/include/linux/isdn/..install.cmd usr/src/linux/include/linux/virtio_balloon.h usr/src/linux/include/linux/mmtimer.h usr/src/linux/include/linux/wireless.h usr/src/linux/include/linux/capability.h usr/src/linux/include/linux/atm.h usr/src/linux/include/linux/msdos_fs.h usr/src/linux/include/linux/fadvise.h usr/src/linux/include/linux/mxc_mlb.h usr/src/linux/include/linux/pmic_status.h usr/src/linux/include/linux/cryptodev.h usr/src/linux/include/linux/ipsec.h usr/src/linux/include/linux/rtnetlink.h usr/src/linux/include/linux/netfilter_arp/ usr/src/linux/include/linux/netfilter_arp/arp_tables.h usr/src/linux/include/linux/netfilter_arp/.install usr/src/linux/include/linux/netfilter_arp/..install.cmd usr/src/linux/include/linux/netfilter_arp/arpt_mangle.h usr/src/linux/include/linux/watchdog.h usr/src/linux/include/linux/sdla.h usr/src/linux/include/linux/radeonfb.h usr/src/linux/include/linux/isdnif.h usr/src/linux/include/linux/baycom.h usr/src/linux/include/linux/dlm_plock.h usr/src/linux/include/linux/coda.h usr/src/linux/include/linux/hysdn_if.h usr/src/linux/include/linux/screen_info.h usr/src/linux/include/linux/xfrm.h usr/src/linux/include/linux/soundcard.h usr/src/linux/include/linux/auto_fs.h usr/src/linux/include/linux/virtio_config.h usr/src/linux/include/linux/kernelcapi.h usr/src/linux/include/linux/mxc_scc2_driver.h usr/src/linux/include/linux/irda.h usr/src/linux/include/linux/if_ppp.h usr/src/linux/include/linux/if_phonet.h usr/src/linux/include/linux/pmic_light.h usr/src/linux/include/linux/matroxfb.h usr/src/linux/include/linux/if_x25.h usr/src/linux/include/linux/b1lli.h usr/src/linux/include/linux/ax25.h usr/src/linux/include/linux/isdn.h usr/src/linux/include/linux/string.h usr/src/linux/include/linux/comstats.h usr/src/linux/include/linux/atmlec.h usr/src/linux/include/linux/dlmconstants.h usr/src/linux/include/linux/input.h usr/src/linux/include/linux/atmapi.h usr/src/linux/include/linux/spi/ usr/src/linux/include/linux/spi/spidev.h usr/src/linux/include/linux/spi/.install usr/src/linux/include/linux/spi/..install.cmd usr/src/linux/include/linux/adfs_fs.h usr/src/linux/include/linux/dm-log-userspace.h usr/src/linux/include/linux/cycx_cfm.h usr/src/linux/include/linux/route.h usr/src/linux/include/linux/fuse.h usr/src/linux/include/linux/llc.h usr/src/linux/include/linux/caif/ usr/src/linux/include/linux/caif/.install usr/src/linux/include/linux/caif/caif_socket.h usr/src/linux/include/linux/caif/if_caif.h usr/src/linux/include/linux/caif/..install.cmd usr/src/linux/include/linux/inotify.h usr/src/linux/include/linux/if_ether.h usr/src/linux/include/linux/serial_reg.h usr/src/linux/include/linux/atm_zatm.h usr/src/linux/include/linux/audit.h usr/src/linux/include/linux/nfs4_mount.h usr/src/linux/include/linux/cuda.h usr/src/linux/include/linux/dqblk_xfs.h usr/src/linux/include/linux/mxc_sim_interface.h usr/src/linux/include/linux/hdlc.h usr/src/linux/include/linux/ipmi.h usr/src/linux/include/linux/netfilter/ usr/src/linux/include/linux/netfilter/nf_conntrack_tuple_common.h usr/src/linux/include/linux/netfilter/xt_dscp.h usr/src/linux/include/linux/netfilter/xt_esp.h usr/src/linux/include/linux/netfilter/xt_physdev.h usr/src/linux/include/linux/netfilter/xt_pkttype.h usr/src/linux/include/linux/netfilter/nfnetlink_compat.h usr/src/linux/include/linux/netfilter/xt_CT.h usr/src/linux/include/linux/netfilter/xt_LED.h usr/src/linux/include/linux/netfilter/xt_u32.h usr/src/linux/include/linux/netfilter/xt_quota.h usr/src/linux/include/linux/netfilter/x_tables.h usr/src/linux/include/linux/netfilter/xt_string.h usr/src/linux/include/linux/netfilter/xt_realm.h usr/src/linux/include/linux/netfilter/xt_connmark.h usr/src/linux/include/linux/netfilter/xt_limit.h usr/src/linux/include/linux/netfilter/xt_tcpudp.h usr/src/linux/include/linux/netfilter/xt_NFLOG.h usr/src/linux/include/linux/netfilter/xt_DSCP.h usr/src/linux/include/linux/netfilter/xt_CONNMARK.h usr/src/linux/include/linux/netfilter/.install usr/src/linux/include/linux/netfilter/nfnetlink_log.h usr/src/linux/include/linux/netfilter/xt_cpu.h usr/src/linux/include/linux/netfilter/nfnetlink.h usr/src/linux/include/linux/netfilter/xt_tcpmss.h usr/src/linux/include/linux/netfilter/xt_state.h usr/src/linux/include/linux/netfilter/xt_mac.h usr/src/linux/include/linux/netfilter/xt_NFQUEUE.h usr/src/linux/include/linux/netfilter/xt_sctp.h usr/src/linux/include/linux/netfilter/xt_IDLETIMER.h usr/src/linux/include/linux/netfilter/xt_conntrack.h usr/src/linux/include/linux/netfilter/xt_recent.h usr/src/linux/include/linux/netfilter/xt_rateest.h usr/src/linux/include/linux/netfilter/xt_TCPOPTSTRIP.h usr/src/linux/include/linux/netfilter/nf_conntrack_sctp.h usr/src/linux/include/linux/netfilter/xt_connlimit.h usr/src/linux/include/linux/netfilter/xt_ipvs.h usr/src/linux/include/linux/netfilter/xt_connbytes.h usr/src/linux/include/linux/netfilter/xt_RATEEST.h usr/src/linux/include/linux/netfilter/xt_comment.h usr/src/linux/include/linux/netfilter/nf_conntrack_tcp.h usr/src/linux/include/linux/netfilter/nfnetlink_conntrack.h usr/src/linux/include/linux/netfilter/xt_mark.h usr/src/linux/include/linux/netfilter/xt_multiport.h usr/src/linux/include/linux/netfilter/xt_policy.h usr/src/linux/include/linux/netfilter/xt_CHECKSUM.h usr/src/linux/include/linux/netfilter/xt_TEE.h usr/src/linux/include/linux/netfilter/xt_helper.h usr/src/linux/include/linux/netfilter/xt_owner.h usr/src/linux/include/linux/netfilter/xt_TCPMSS.h usr/src/linux/include/linux/netfilter/xt_iprange.h usr/src/linux/include/linux/netfilter/xt_statistic.h usr/src/linux/include/linux/netfilter/xt_hashlimit.h usr/src/linux/include/linux/netfilter/..install.cmd usr/src/linux/include/linux/netfilter/xt_osf.h usr/src/linux/include/linux/netfilter/xt_SECMARK.h UTP: received command 'frf' usr/src/linux/include/linux/netfilter/xt_cluster.h usr/src/linux/include/linux/netfilter/xt_time.h usr/src/linux/include/linux/netfilter/xt_TPROXY.h usr/src/linux/include/linux/netfilter/nfnetlink_queue.h usr/src/linux/include/linux/netfilter/xt_dccp.h usr/src/linux/include/linux/netfilter/xt_CONNSECMARK.h usr/src/linux/include/linux/netfilter/nf_conntrack_ftp.h usr/src/linux/include/linux/netfilter/xt_MARK.h usr/src/linux/include/linux/netfilter/xt_length.h usr/src/linux/include/linux/netfilter/xt_CLASSIFY.h usr/src/linux/include/linux/netfilter/nf_conntrack_common.h usr/src/linux/include/linux/pkt_sched.h usr/src/linux/include/linux/firewire-constants.h usr/src/linux/include/linux/netdevice.h usr/src/linux/include/linux/if_link.h usr/src/linux/include/linux/edd.h usr/src/linux/include/linux/atmmpc.h usr/src/linux/include/drm/ usr/src/linux/include/drm/sis_drm.h usr/src/linux/include/drm/radeon_drm.h usr/src/linux/include/drm/r128_drm.h usr/src/linux/include/drm/drm_sarea.h usr/src/linux/include/drm/i830_drm.h usr/src/linux/include/drm/.install usr/src/linux/include/drm/nouveau_drm.h usr/src/linux/include/drm/via_drm.h usr/src/linux/include/drm/mga_drm.h usr/src/linux/include/drm/i915_drm.h usr/src/linux/include/drm/..install.cmd usr/src/linux/include/drm/drm_mode.h usr/src/linux/include/drm/i810_drm.h usr/src/linux/include/drm/vmwgfx_drm.h usr/src/linux/include/drm/drm.h usr/src/linux/include/drm/savage_drm.h usr/src/linux/include/asm/ usr/src/linux/include/asm/stat.h usr/src/linux/include/asm/posix_types.h usr/src/linux/include/asm/errno.h usr/src/linux/include/asm/fcntl.h usr/src/linux/include/asm/sigcontext.h usr/src/linux/include/asm/bitsperlong.h usr/src/linux/include/asm/auxvec.h usr/src/linux/include/asm/siginfo.h usr/src/linux/include/asm/setup.h usr/src/linux/include/asm/sockios.h usr/src/linux/include/asm/ipcbuf.h usr/src/linux/include/asm/hwcap.h usr/src/linux/include/asm/.install usr/src/linux/include/asm/a.out.h usr/src/linux/include/asm/unistd.h usr/src/linux/include/asm/ioctls.h usr/src/linux/include/asm/swab.h usr/src/linux/include/asm/poll.h usr/src/linux/include/asm/resource.h usr/src/linux/include/asm/socket.h usr/src/linux/include/asm/mman.h usr/src/linux/include/asm/types.h usr/src/linux/include/asm/ioctl.h usr/src/linux/include/asm/termbits.h usr/src/linux/include/asm/signal.h usr/src/linux/include/asm/msgbuf.h usr/src/linux/include/asm/param.h usr/src/linux/include/asm/ptrace.h usr/src/linux/include/asm/statfs.h usr/src/linux/include/asm/termios.h usr/src/linux/include/asm/..install.cmd usr/src/linux/include/asm/shmbuf.h usr/src/linux/include/asm/sembuf.h usr/src/linux/include/asm/byteorder.h usr/src/linux/include/rdma/ usr/src/linux/include/rdma/ib_user_mad.h usr/src/linux/include/rdma/.install usr/src/linux/include/rdma/..install.cmd usr/sbin/ usr/sbin/udevmonitor usr/local/ usr/lib/ usr/lib/libfsl_shw.so.0 usr/lib/libthread_db.so usr/lib/libpthread.so.bak usr/lib/libpthread.so usr/lib/libnss_compat.so usr/lib/libnss_nis.so usr/lib/libcrypt.so usr/lib/libpxp.so.0 usr/lib/libc.so.bak usr/lib/libBrokenLocale.so usr/lib/libvpu.so.4 usr/lib/libutil.so usr/lib/libipu.so.0 usr/lib/libnsl.so usr/lib/libm.so usr/lib/libnss_hesiod.so usr/lib/libpxp.so usr/lib/libipu.so usr/lib/libstdc++.so usr/lib/libc.so usr/lib/libtermcap.so usr/lib/librt.so usr/lib/libssp.so usr/lib/libvolume_id.so usr/lib/libnss_nisplus.so usr/lib/pkgconfig/ usr/lib/pkgconfig/libvolume_id.pc usr/lib/libfsl_shw.so usr/lib/libvpu.so usr/lib/libnss_files.so usr/lib/libresolv.so usr/lib/libanl.so usr/lib/libdl.so usr/lib/libnss_dns.so var/ var/lock/ var/spool/ var/spool/lpd/ var/spool/mail/ var/tmp/ var/log/ var/log/wtmp var/log/hotplug/ var/log/lastlog var/www/ var/www/icons/ var/www/cgi-bin/ var/www/cgi-bin/test_cgi var/www/html/ var/www/html/index.html var/lib/ var/ftp/ var/ftp/etc/ var/ftp/pub/ var/ftp/bin/ var/ftp/lib/ var/run/ var/run/utmputp_poll: pass returned. var/run/usb/ var/mail/ UTP: closing the file UTP: sending Success to kernel for command frf. UTP: received command '$ umount /mnt/mmcblk0p1' UTP: executing "umount /mnt/mmcblk0p1" UTP: sending Success to kernel for command $ umount /mnt/mmcblk0p1. utp_poll: pass returned. UTP: received command '$ echo Update Complete!' UTP: executing "echo Update Complete!" Update Complete! UTP: sending Success to kernel for command $ echo Update Complete!. utp_poll: pass returned. |
But after hardware board reset, uboot can not load linux kernel correctly:
Header 1 |
U-Boot 2009.08 (Aug 16 2013 - 12:53:32) CPU: Freescale i.MX6 family TO1.1 at 792 MHz Thermal sensor with ratio = 188 Temperature: 42 C, calibration data 0x5a34e87d mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 198000000Hz emi_slow clock: 99000000Hz ddr clock : 396000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ] Boot Device: MMC I2C: ready DRAM: 512 MB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 *** Warning - bad CRC or MMC, using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:00:00:00:00:00 FEC0 [PRIME] Hit any key to stop autoboot: 0 FEC: Link is down 0 *** ERROR: `ethaddr' not set FEC: Link is down 0 Wrong Image Format for bootm command ERROR: can't get kernel image! MX6Solo SABRESD U-Boot > |
uboot can not load uImage. I guess I need to modify uboot code as linux code, but where should I begin to deal with ?
