Hi all
I have a question about pull-up resistor of CMD line.
Here is a comment about pull-up resistor of CMD line in P10 of SABRE-AI_DualLite_CPUcard/sch-27767_a_x3.pdf.
"SD, SDXC - Remove CMD pull-up resistor (default)"
Does it mean user can remove CMD pull-up resistor when use only SD,SDXC ?
Ko-hey
Solved! Go to Solution.
The pull-up on CMD is intended for eMMC, where it can be open-drain.
Yuri
Yuri
Hi Yuri Muhin
In my understanding, open-drain requires pull-up.
Since the internal pull-up of i.MX 6 can be used, it is not necessary to provide a pull-up resistor externally.
Am I correct ?
Ko-hey
internal resistor values of i.MX6 are relatively big (~100K):
strictly speaking such values may be not sufficient.
Yuri.
Yes - external resistor about 4.7K
~Yuri.
Hi Yuri Muhin
According to your answer, it seems preferable to pull up the external CLK and D0 to D3 lines other than CMD at 4.7k.
Am I correct ?
Ko-hey
Customers can just follow the reference design.
Yuri.
