ov5640 - Is it possible to capture 1080p and 720p resolution in OV5640 (MIPI interface ) ?
663件の閲覧回数
nadimfnadaf
I am using imx6 dual and want to capture with 1080p and 720p resolution at 30fps and 60fps respectively(using mipi interface). Is it possible to capture at 720p as well as 1080p resolution ?
If yes, how we can do the same?
imx6 dual
mipi interface
1080p and 720p
2 返答(返信)
645件の閲覧回数
Bio_TICFSL
If you have enough RAM and with i.MX6D you will be able to capture image at 1080p with 30fps with MIPI, but you are going to display at 720p maximum.
638件の閲覧回数
nadimfnadaf
We have 2GB DRAM here, whether it is sufficient for capturing with 1080p at 30fps?
May I know the reason behind why we can display only at 720p maximum? Can I get references regarding this?
Thank you!
