mx53_smd VGA Display
2,193件の閲覧回数
Danial
if I use the mx53_smd BSP, I can't use VGA Display,
but when I use mx53_loco BSP, it work. Why? There are
some differeces between mx53_smd and mx53_loco?
Thanks!
1,988件の閲覧回数
Danial
Thankyou, in mx53_smd.c files,
change:
static struct tve_platform_data tve_data = {
  .dac_reg = "DA9052_LDO7",
static struct ldb_platform_data ldb_data = {
  .ext_ref = 1,
  .boot_enable = MXC_LDBDI1,
to
  .boot_enable = MXC_TVE_VGA,//2012-12-28 by add zhoudan
  .ext_ref = 1,
  //.boot_enable = MXC_LDBDI1,
and it work.
1,988件の閲覧回数
4guin4g4
The LVDS is the default display for the SMD. Have you tried changing the bootargs?
What board are you using? is this a custom board?
1,989件の閲覧回数
Danial
change:
  .ext_ref = 1,
to
  .ext_ref = 1,
and it work.
