Hi all,
I use iMX6Q-SDP and have some problem with keyboard.After linux bootup,I get some error:
matchbox: keyboard does not appear to have a c=close
I know it's not the final solution,my keboard can work but the 3 indicators failed to light.
Who can give me some advice?
Xiaoqiang
Hi Xiaoqiang,
Which version linux BSP are you using?
Best Regards
Dan
I am using L3.0.35_4.1.0_130816.And the rootfs is built using 'FSL gnome package'.
Hi Xiaoqiang,
When you board boot up ,can you attach the log file? As you build BSP, have you changed some options? It's hard to find the problem in the information you gave.
Best Regards
Dan
Hi Xiaoqiang,
I will see it and try to find the problem, then I will give you response. Please wait with patience~~
Best Regards
Dan
I am seeing the same issue. Can you tell me how and if this issue was resolved?
