imx8mm cannot be awakened from sleep
yzg
Excuse me, have you tested keystroke wakeup on the 5.1 kernel again?I am currently using the gpio_keys.c driver which won't wake up the device, but it will work on the 4.1 kernel.Specific kernel version:Linux imx8mmevk 5.10.52-1.0,The following is the configuration of my device tree
    gpio_keys {
        compatible = "gpio-keys";
        #address-cells = <1>;
        #size-cells = <0>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_gpiokey>;
        key-1 { //power-button
            debounce_interval = <50>;
            wakeup-source;
            linux,code = <116>;
            label = "POWER";
            gpios = <&gpio2 15 GPIO_ACTIVE_LOW>;
        key-2 { //KEY_VOLUMEUP
            wakeup-source;
            linux,code = <115>;
            label = "VOLUMEUP";
            gpios = <&gpio2 20 GPIO_ACTIVE_LOW>;
        key-3 { //KEY_VOLUMEDOWN
            wakeup-source;
            linux,code = <114>;
            label = "VOLUMEDOWN";
            gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
        key-4 { //KEY_MICMUTE
            wakeup-source;
            linux,code = <248>;
            label = "MICMUTE";
            gpios = <&gpio2 19 GPIO_ACTIVE_LOW>;
Dhruvit
Hi @yzg,
Please try testing the GPIO wakeup with the latest kernel available!
Thanks & Regards,
Dhruvit.
yzg
I can confirm that my gpio is fine, I have tested the wake up function in 4.1 kernel and it works perfectly
Dhruvit
Thank you for your reply.
What I am asking is to test with the latest version i.e., linux-imx 5.15. As this has been resolved in that.
Thank you for understanding!
Dhruvit.
yzg
Thank you for your reply. At present, my kernel version is Linux imx8mmevk 5.10.52-1.0. Is there any patch available?
Dhruvit
Hi @yzg,
No currently, there are no patches available for Linux 5.10.
Dhruvit.
