imx8dx scu can not start
songhongliang
HI I am using imx8dx and 8100cces pmic, Now sometimes when the power is on, VCC_CPU has no voltage. Cause the system to fail to run. How to deal with this phenomenon, can you give me some ideas. The power-on sequence has been checked. Thanks
songhongliang
HI,
I want to know what code is running before SCU, and is there any way to determine which step the code has run before scu and scu
songhongliang
HI
I have tried to recompile, and I measured the IIC of pmic (8100cces). When the VCC_CPU cannot be powered on, the IIC communication does not have it. In other words, there is no way to ensure that the code runs to SCFW. In this case How to deal with it, SCU does not have any log
on last suggested link (for Bootloader customization) one can find how
enable SCU serial port debugging information.
