Hi,all
ov5640 i2c is ok, and i can see the clock and data wave, i want to get a picture with v4l2 ,and have this problem, why?
Thanks for your help.
已解决! 转到解答。
Hi,all
thanks for all of your help,i have solved the problem,it’s the camera work wrong~~
Hi Richard,
I have the same output i.e
cat /dev/video0
ERROR: v4l2 capture: mxc_v4l_read timeout counter 0
imx-ipuv3 2400000.ipu: Not a CSI channel
Could you explain what you mean by "i have solved the problem,it’s the camera work wrong" as it may help myself and others? Thankyou.
Hi Richard,
I have the output i.e
cat /dev/video0
cat /dev/video0 > test.mpg
ov540 mode detected
master writing
master writing
master writing
master writing
master writing
master writing
master writing
master writing
master writing
master writing
master writing
master writing
cat: /dev/video0: Timer expired
could you explain how to solve this problem
Thankyou.
Hi,jimmy chan
the kernel is v3.10.17 ,
the device tree:
&mipi_csi {
status = "okay";
ipu_id = <0>;
csi_id = <1>;
v_channel = <0>;
lanes = <2>;
v4l2_cap_1 {
compatible = "fsl,imx6q-v4l2-capture";
ipu_id = <0>;
csi_id = <1>;
mclk_source = <0>;
status = "okay";
&i2c2 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c2_2>;
status = "okay";
ov5640_mipi: ov5640_mipi@3c { /* i2c2 driver */
compatible = "ovti,ov5640_mipi";
reg = <0x3c>;
clocks = <&clks 201>;
clock-names = "csi_mclk";
DOVDD-supply = <&vgen4_reg>; /* 1.8v */
AVDD-supply = <&vgen3_reg>; /* 2.8v, rev C board is VGEN3
rev B board is VGEN5 */
DVDD-supply = <&vgen2_reg>; /* 1.5v*/
pwn-gpios = <&gpio1 19 1>; /* active low: SD1_CLK */
rst-gpios = <&gpio1 20 0>; /* active high: SD1_DAT2 */
csi_id = <1>;
mclk = <24000000>;
mclk_source = <0>;
so,it's right?
HI,angelo dureghello
root@imx6qdlsolo:~# ls /dev/video*
/dev/video0 /dev/video16 /dev/video18 /dev/video20
/dev/video1 /dev/video17 /dev/video19
root@imx6qdlsolo:~# cat /dev/video16
cat: read error: Invalid argument
root@imx6qdlsolo:~# cat /dev/video17
root@imx6qdlsolo:~#
Hi,angelo dureghello
root@imx6qdlsolo:~# cat /dev/video1 > test.mpg
cat: read error: Timer expired
