imx6Q “RCU_preempt detected stalls...” problem
411 次查看
zhn
The device runs kernel 4.14.98. After the device runs for a period of time, the network system of the device breaks down. You cannot log in to the device through ssh and connect to it through the debug serial port.
After verifying that the printing as wifi driver has been modified, the following printing has been reproduced, but the system does not break down at this time. Could you please help to see what causes the device to break down
396 次查看
jimmychan
It is hard to tell why "RCU_preempt detected stalls...” to occur. You may need to do more test to narrow down the issue first.
