iMXQ-SDB - Add QtMultimedia to fsl-image-multimedia-full
3,238 次查看
raz3l
Hi guys
We are trying to add QtMultimedia libraries to the fsl-image-multimedia-full, but we are getting an error when running the QT application (./qtappl -platform eglfs):
defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer"
The branch that we are using is dizzy, but we already tried with jethro too. Our local.conf looks like this:
MACHINE ??= 'imx6qsabresd'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
    STOPTASKS,${TMPDIR},1G,100K \
    STOPTASKS,${DL_DIR},1G,100K \
    STOPTASKS,${SSTATE_DIR},1G,100K \
    ABORT,${TMPDIR},100M,1K \
    ABORT,${DL_DIR},100M,1K \
    ABORT,${SSTATE_DIR},100M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '4'
PARALLEL_MAKE = '-j 4'
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = ""
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh "
DISTRO_FEATURES_remove = "x11 wayland"
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer"
IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \
autoconf automake ccache chkconfig glib-networking glibmm \
packagegroup-core-buildessential pkgconfig  \
boost cmake zlib glib-2.0 packagegroup-fsl-tools-testapps  \
    ruby \
    cpufrequtils \
    nano \
    gdb \
    gstreamer \
    gst-meta-video \
    gst-fsl-plugin \
    gst-plugins-base-app \
    gst-plugins-base \
    gst-plugins-good \
    gst-plugins-good-rtsp \
    gst-plugins-good-udp \
    gst-plugins-good-rtpmanager \
    gst-plugins-good-rtp \
    gst-plugins-good-video4linux2 \
    openssh-sftp-server \
    packagegroup-fsl-gstreamer \
    packagegroup-fsl-tools-benchmark \
    imx-vpu \
    imx-test \
    qtbase-fonts \
    qtbase-plugins \
    qtbase-tools \
    qtbase-examples \
    qtdeclarative \
    qtdeclarative-plugins \
    qtdeclarative-tools \
    qtdeclarative-examples \
    qtdeclarative-qmlplugins \
    qtmultimedia \
    qtmultimedia-plugins \
    qtmultimedia-examples \
    qtmultimedia-qmlplugins \
    qtsvg \
    qtsvg-plugins \
    qtsensors \
    qtimageformats-plugins \
    qtsystems \
    qtsystems-tools \
    qtsystems-examples \
    qtsystems-qmlplugins \
    qtscript \
    qt3d \
    qt3d-examples \
    qt3d-qmlplugins \
    qt3d-tools \
    qtwebkit \
    qtwebkit-examples-examples \
    qtwebkit-qmlplugins \
    qtgraphicaleffects-qmlplugins \
    qtconnectivity-qmlplugins \
    qtlocation-plugins \
    qtlocation-qmlplugins \
    cinematicexperience \
    cairo pango fontconfig freetype pulseaudio dbus \
    alsa-lib alsa-tools alsa-state alsa-utils-alsaconf fsl-alsa-plugins \
    i2c-tools \
Besides of that we changed the qtmultimedia_git.bb recipe, and now it looks like this:
require qt5.inc
require qt5-git.inc
# There are no LGPLv3-only licensed files in this component.
LICENSE = "GFDL-1.3 & BSD & (LGPL-2.1 & Digia-Qt-LGPL-Exception-1.1 | LGPL-3.0)"
LIC_FILES_CHKSUM = " \
    file://LICENSE.LGPLv21;md5=cff17b12416c896e10ae2c17a64252e7 \
    file://LICENSE.LGPLv3;md5=c1939be5579666be947371bc8120425f \
    file://LGPL_EXCEPTION.txt;md5=0145c4d1b6f96a661c2c139dfb268fb6 \
    file://LICENSE.FDL;md5=6d9f2a9af4c8b8c3c769f6cc1b6aaf7e \
DEPENDS += "qtdeclarative"
PACKAGECONFIG ??= "${@bb.utils.contains('DISTRO_FEATURES', 'alsa', 'alsa', '', d)} \
    ${@bb.utils.contains('DISTRO_FEATURES', 'gstreamer', 'gstreamer', '', d)} \
                   ${@bb.utils.contains('DISTRO_FEATURES', 'pulseaudio', 'pulseaudio', '', d)}"
PACKAGECONFIG[alsa] = ",,alsa-lib"
PACKAGECONFIG[pulseaudio] = ",,pulseaudio"
PACKAGECONFIG[openal] = ",,openal-soft"
PACKAGECONFIG[gstreamer] = ",,gstreamer1.0 gstreamer1.0-plugins-base gstreamer1.0-plugins-bad"
PACKAGECONFIG[gstreamer010] = ",,gstreamer gst-plugins-base gst-plugins-bad"
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains('PACKAGECONFIG', 'alsa', '', 'CONFIG+=done_config_alsa', d)}"
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains('PACKAGECONFIG', 'pulseaudio', '', 'CONFIG+=done_config_pulseaudio', d)}"
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains('PACKAGECONFIG', 'openal', '', 'CONFIG+=done_config_openal', d)}"
# Handles GStreamer support
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains('PACKAGECONFIG', 'gstreamer', 'GST_VERSION=1.0', '', d)}"
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains('PACKAGECONFIG', 'gstreamer010', 'GST_VERSION=0.10', '', d)}"
# Disable GStreamer if completely disabled
EXTRA_QMAKEVARS_PRE += "${@bb.utils.contains_any('PACKAGECONFIG', 'gstreamer gstreamer010', '', 'CONFIG+=done_config_gstreamer', d)}"
SRC_URI += "\
    file://0001-Initial-porting-effort-to-GStreamer-1.0.patch \
#SRCREV = "cc0569a038f6116df559508518b6dacb15be8520"
SRCREV = "2170a3b0fcda613daf76a337fa45cb97e0714cdf"
标签 (2)
标记 (3)
2 回复数
1,710 次查看
gusarambula
Hello Daniel Oliveira,
There are some threads on the communities regarding issues with EGL in Qt. Have you tried with the Qt5 image from a BSP release? Which image are you baking (over which the local.conf packages are installing)?
1,710 次查看
raz3l
I guess should explain what I have already did.
So, I follow the normal steps, but on this time I tried to be careful, so I dig on yocto mailing list and I search by the last entry referring to a Qt build in jethro branch. I found this (https://lists.yoctoproject.org/pipermail/meta-freescale/2016-February/017332.html). So, what I did was:
1) follow the first steps as referred in FSL Community BSP git page (https://github.com/Freescale/fsl-community-bsp-platform)
a) install repo utility
b) download the BSP source files
2) build a simple image (core-image-minimal)
3) added meta-qt5 updated bblayers.conf and rebuilt core-image-minimal
a) bblayers.conf looks like this
LCONF_VERSION = "6"
BBPATH = "${TOPDIR}"
BSPDIR := "${@os.path.abspath(os.path.dirname(d.getVar('FILE', True)) + '/../..')}"
BBFILES ?= ""
BBLAYERS = " \
  ${BSPDIR}/sources/poky/meta \
  ${BSPDIR}/sources/poky/meta-yocto \
  ${BSPDIR}/sources/meta-openembedded/meta-oe \
  ${BSPDIR}/sources/meta-openembedded/meta-multimedia \
  ${BSPDIR}/sources/meta-fsl-arm \
  ${BSPDIR}/sources/meta-fsl-arm-extra \
  ${BSPDIR}/sources/meta-fsl-demos \
  ${BSPDIR}/sources/meta-qt5 \
  ${BSPDIR}/sources/meta-openembedded/meta-ruby \
4) built fsl-image-multimedia-full
Until everything went well, without any major errors and I have a stable image. After this in when I start getting lost, and doing things a little randomly.
5) Added to my local.conf the following packages
DISTRO ?= 'poky'
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh"
USER_CLASSES ?= "buildstats image-mklibs"
    STOPTASKS,/tmp,100M,100K \
    ABORT,${SSTATE_DIR},100M,1K \
    ABORT,/tmp,10M,1K"
CONF_VERSION = "1"
ACCEPT_FSL_EULA = "1"
DISTRO_FEATURES_append = " systemd dbus pulseaudio udev opengl"
DISTRO_FEATURES_remove = "wayland nfc 3g ppp bluetooth x11"
IMAGE_INSTALL_append = " qtbase qtbase-fonts qtbase-plugins qtmultimedia qtmultimedia-plugins qtxmlpatterns cinematicexperience imx-vpu speex  gstreamer1.0-rtsp-server gstreamer1.0-plugins-good \
imx-gpu-viv gstreamer1.0-plugins-base gstreamer1.0-plugins-bad"
#PREFERRED_VERSION_alsa-plugins = "1.0.29"
PACKAGECONFIG_append_pn-qtdeclarative = " qtxmlpatterns"
#PACKAGECONFIG_append_pn-qtbase =  "  gles2 accessibility"
PACKAGECONFIG_append_pn-qtbase =  " dbus evdev tools gles2 glib linuxfb accessibility sql-sqlite udev pulseaudio"
#PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer alsa"
#PACKAGECONFIG_append_pn-pulseaudio = " systemd dbus"
PACKAGECONFIG_remove_pn-gstreamer1.0-plugins-good = " gdk-pixbuf"
6) Rebuild fsl-image-multimedia-full and I start getting a lot errors and I try to solve them by removing some of the appends added in step 5 (qtbase-examples qtdeclarative-examples qt3d-tools alsa-utils-alsaconf qtquickcontrols-qmlplugins ).
But after I still got errors but somehow I got a build done without errors. But when I start the qml application I got this error defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer"
