iMX6D/Q uSDHC read/write methods
1,252 次查看
cagatayozdemir
Hi all,
In iMx6Q uSDHC module, there are three options to read from / write to SD Card:
1-> Internal DMA, Over AHB Bus
2-> External DMA, Over IP Bus
3-> PIO, reading a register
What are the advantages/disadvantages or considerations about these methods? In my opinion:
a-) Reading a file via PIO is the slowest one and also makes CPU busy. This is not an efficient way. Then in which circumstances should we think to use this way?
b-) Internal DMA is special to uSDHC. It provides us not to occupy external DMA, so it seems an efficient way to use resources of the chip. However I am not sure about comparison of internal/external DMA speeds.
What are your experiences/thoughts?
Cagatay
标签 (2)
标记 (5)
872 次查看
cagatayozdemir
Thanks you Yuri. I think I need some more help to be totally clarified..
What determines DMA speed? Can we estimate a number or it depends on the conditions at that moment? To compare with PIO speed, is it the only way to take benchmarks?
As far as I understand from your comment, SDMA optimizes system performance therefore it allocates resources for slowest channels too and that may decrease the throughput for SD read. Is this related to the fact that external DMA  uses IP bus but internal DMA uses AHB bus?
Thanks a lot,
Cagatay
872 次查看
Yuri
  DMA perofrmance depends on many factors, such as DMA module internal frequency, bus frequency,
internal arbitartion between SOC modules (for heavy loaded systems). We do not have special tool
to estimate it, because of system compexity.
As for performance and implementation of SDMA approach, please look at the following :
“Measure SDMA Memory To Memory Copy Performance on i.MX6Q”
https://community.freescale.com/docs/DOC-103127
Yuri.
872 次查看
Yuri
  Please look at my comments below.
1.
  You mentioned : “reading a file via PIO is the slowest one” - this is not obvious,
since CPU frequency of 1 GHz allows to achieve very high performance for data
read in polling technique. But - You are right - this “also makes CPU busy” and
do not allow to use advantages of multi-tasking. Therefore polling approach is not
suitable for Linux.
2.
  External DMA is used with the SDMA. The SDMA controller helps to optimize system
performance by offloading the CPU in dynamic data routing with relatively slow channels,
such as UART, SSI, SPI. The SDMA is not the best solution to achieve maximal throughput.
   It makes sense to use the internal
DMA for maximal performance.
Yuri
