iMX solo Debug log
iMX solo Debug log
1,831件の閲覧回数
aabhishekoct18
Hi  Team
Can you please let me know how i can, see debug logs during uBoot.
I want to know if this is  fixed  or we can configure?
1,765件の閲覧回数
diegoadrian
If you want to have the output log from u-boot. You just need to connect the USB for the serial communication into your computer and with a serial terminal open the COM port that your computer assigned. Just remember that the default supported baud rate is from 115200. Having that set that connection you could see the output log from u-boot during the booting process and during the UUU debugging process.
Hope that was the information that you were looking for.
Diego.
