We refer to the 'Over-The-Air (OTA) Update' method in the 'Android_User's_Guide.pdf' documentation. we builded a full update package. To update the system from board's storage. We use the logcat command to see the log of a successful OTA upgrade, but after restarting it gets stuck in 'Booting from bootloader_b... '.
We try to burn the board using the official source package 'automat-12.0.0_1.1.0_image_8qmek_car.tar.gz', Then compile the full update package using the new source code 'imx-automote-12.0.0_1.1.0'. The result is stuck in 'Booting from bootloader_b... '. The log is shown in the attachment.
Software Version: imx-automotive-12.0.0_1.1.0
Hardware: i.MX8QXP C0 demo board
OTA upgrade successful part log: 04-28 03:18:13.947 450 450 I update_engine: [INFO:update_attempter_android.cc(546)] Processing Done.
04-28 03:18:13.962 450 450 I update_engine: [INFO:update_attempter_android.cc(559)] Update successfully applied, waiting to reboot.
04-28 03:18:13.976 450 450 E update_engine: UnmapAllSnapshots should never be called.
04-28 03:18:13.994 450 450 I update_engine: [INFO:metrics_reporter_android.cc(159)] Current update attempt downloads 586 bytes data
04-28 03:18:14.012 450 450 I update_engine: [INFO:metrics_utils.cc(335)] Updated Marker = 1/1/1970 0:10:10 GMT
Reboot failed log:
U-Boot SPL 2021.04 (Apr 28 2022 - 03:08:10 +0200)
Normal Boot
Trying to boot from MMC1
Authentication key not yet programmed
OTA Upgrade Steps:
1. Building target files
$ cd ${MY_ANDROID}
$ source build/envsetup.sh
$ lunch mek_8q_car-userdebug
$ ./imx-make.sh bootloader kernel -j4
$ make target-files-package -j4
2. Building a full update package
$ cd ${MY_ANDROID}
$ make otapackage -j
3. Push payload.bin to board's storage:
adb root
adb push payload.bin /data/ota_package
4. Input the following command in board's console to update:
update_engine_client --payload=file:///data/ota_package/payload.bin --update --
headers="FILE_HASH=8V5MbcnDzH7I2XMDJlzQ0fdbjC20pCYiBYYSV+AZvX0=
FILE_SIZE=615476465
METADATA_HASH=kC9zt177Au7KqIYrrYOC2ZN9OADNWNz7uF33cytlT/U=
METADATA_SIZE=120262"
Solved! Go to Solution.
Hello @DRAVE ,
I hope you are doing well.
Thanks for the detailed logs.
->For building target files you have followed the correct steps but to build incremental OTA please follow the below-mentioned steps.
1. make target-files-package -j4
//this will generate the previously changed target file in "{MY_ANDROID}/out/target/
Copy the PREVIOUS-target_files.zip to ${MY_ANDROID}
2. Apply your changes in the source
3. make target-files-package -j4
Copy the NEW-target_files.zip to ${MY_ANDROID}
4. ./build/tools/releasetools/
->To apply the incremental OTA please follow the steps given in Section 7.1.3 of the Android User Guide attached here.
https://www.nxp.com/docs/en/
Thanks & Regards,
Sanket Parekh
Hello @DRAVE ,
Thanks for the detailed information and dmesg logs.
->make otapackage -j
This command is used for i.MX 8QuadMax
->For i.MX8QuadXPlus, Please use the command line
make OTA_TARGET=8qxp otapackage -j4.
Please use this command.
Thanks & Regards,
Sanket Parekh
Hi, @Sanket_Parekh
The OTA upgrade can be done using the command 'make OTA_TARGET=8qxp otapackage -j4'. Reboot successfully. Thank you !
Thanks & Regards,
DRAVE
Hello @DRAVE ,
I'm happy to help you.
So the issue is resolved now, can I close this case?
Thanks & Regards,
Sanket Parekh
HI, @Sanket_Parekh
There is a new OTA upgrade issue. We builded an incremental update package failed. We use the command "./build/tools/releasetools/ota_from_target_files -i ota_old.zip mek_8q_car-target_files-eng.andrew.zip incremental_ota_update.zip" to run it. But we get an 'ImportError: No module named google.protobuf' error. We renamed the first target files ota old.zip. Is there any other environment that needs to be configured?
Building target files:
$ cd ${MY_ANDROID}
Building an incremental update package command:
Failed log (As shown in attachment):
andrew@ubuntu18_a1:/home/workspace/imx-automotive-12.0.0_1.1.0/android_build$ ./build/tools/releasetools/ota_from_target_files -i ota_old.zip mek_8q_car-target_files-eng.andrew.zip incremental_ota_update.zip
Warning: releasetools script should be invoked as hermetic Python executable -- build and run `ota_from_target_files` directly.
Traceback (most recent call last):
File "./build/tools/releasetools/ota_from_target_files", line 241, in <module>
import ota_utils
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/ota_utils.py", line 21, in <module>
import ota_metadata_pb2
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/ota_metadata_pb2.py", line 7, in <module>
from google.protobuf import descriptor as _descriptor
Thanks & Regards,
DRAVE
HI, @Sanket_Parekh
We tried to install protobuf with the command "pip install protobuf".After running a new problem appears as shown below. What kind of problem could that be.
command:
Failed log:
2023-04-23 03:10:26 - common.py - WARNING : Failed to read SYSTEM/etc/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read VENDOR/etc/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read ODM/etc/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read ODM/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read VENDOR_DLKM/etc/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read VENDOR_DLKM/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read ODM_DLKM/etc/build.prop
2023-04-23 03:10:26 - common.py - WARNING : Failed to read ODM_DLKM/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read SYSTEM/etc/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read VENDOR/etc/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read ODM/etc/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read ODM/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read VENDOR_DLKM/etc/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read VENDOR_DLKM/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read ODM_DLKM/etc/build.prop
2023-04-23 03:10:27 - common.py - WARNING : Failed to read ODM_DLKM/build.prop
debugfs 1.45.4 (23-Sep-2019)
/apex: File not found by ext2_lookup
2023-04-23 03:13:13 - ota_from_target_files - ERROR :
ERROR:
File "./build/tools/releasetools/ota_from_target_files", line 1496, in <module>
main(sys.argv[1:])
File "./build/tools/releasetools/ota_from_target_files", line 1470, in main
source_file=OPTIONS.incremental_source)
File "./build/tools/releasetools/ota_from_target_files", line 1198, in GenerateAbOtaPackage
FinalizeMetadata(metadata, staging_file, output_file, needed_property_files)
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/ota_utils.py", line 99, in FinalizeMetadata
prelim_signing = ComputeAllPropertyFiles(input_file, needed_property_files)
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/ota_utils.py", line 84, in ComputeAllPropertyFiles
SignOutput(input_file, prelim_signing)
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/ota_utils.py", line 571, in SignOutput
whole_file=True)
File "/home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/releasetools/common.py", line 2295, in SignFile
proc.returncode, stdoutdata))
ExternalError: Failed to run signapk.jar: return code 1:
Error: Unable to access jarfile /home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/framework/signapk.jar
Thanks & Regards,
DRAVE
Hi, @Sanket_Parekh
We copy the file command 'cp out/soong/host/linux-x86/* build/make/tools/ -rf '. Resolved file 'signapk.jar' not found. Then use the command './build/tools/releasetools/ota_from_target_files -i ota_old.zip mek_8q_car-target_files-eng.andrew.zip incremental_ota_update.zip' compile to generate file 'incremental_ota_update.zip'. The incremental_ota_update.zip file can be generated. But the OTA upgrade failed !
Compile log:
2023-04-23 06:55:16 - common.py - WARNING : Failed to read SYSTEM/etc/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read VENDOR/etc/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read ODM/etc/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read ODM/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read VENDOR_DLKM/etc/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read VENDOR_DLKM/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read ODM_DLKM/etc/build.prop
2023-04-23 06:55:16 - common.py - WARNING : Failed to read ODM_DLKM/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read SYSTEM/etc/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read VENDOR/etc/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read ODM/etc/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read ODM/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read VENDOR_DLKM/etc/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read VENDOR_DLKM/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read ODM_DLKM/etc/build.prop
2023-04-23 06:55:18 - common.py - WARNING : Failed to read ODM_DLKM/build.prop
OTA upgrade command:
update_engine_client --payload=file:///data/ota_package/payload.bin --update --headers="FILE_HASH=NUYR0yIbMDdxH/2hpF+IkzygCXIKl12JQqzUAENwMDQ=
FILE_SIZE=1002629
METADATA_HASH=08AOdMfD23nwKaHLkKVXb4srY06EncGdMA4a8hQQaQw=
METADATA_SIZE=146175"
OTA upgrade failure log ( As shown in attachment
01-31 01:27:56.387 432 432 I update_engine: [INFO:delta_performer.cc(217)] Discarding 73272 unused downloaded bytes
01-31 01:27:56.419 432 432 I update_engine: [INFO:multi_range_http_fetcher.cc(177)] Received transfer terminated.
01-31 01:27:56.428 432 432 I update_engine: [INFO:multi_range_http_fetcher.cc(129)] TransferEnded w/ code 200
01-31 01:27:56.436 432 432 I update_engine: [INFO:multi_range_http_fetcher.cc(131)] Terminating.
01-31 01:27:56.446 432 432 I update_engine: [INFO:action_processor.cc(116)] ActionProcessor: finished DownloadAction with code ErrorCode::kDownloadStateInitializationError
01-31 01:27:56.454 432 432 I update_engine: [INFO:action_processor.cc(121)] ActionProcessor: Aborting processing due to failure.
01-31 01:27:56.462 432 432 I update_engine: [INFO:update_attempter_android.cc(546)] Processing Done.
01-31 01:27:56.473 432 432 I update_engine: [INFO:delta_performer.cc(1389)] Resetting recorded hash for prepared partitions.
01-31 01:27:56.483 432 432 I update_engine: [INFO:update_attempter_android.cc(570)] Resetting update progress.
01-31 01:27:56.492 432 432 E update_engine: UnmapAllSnapshots should never be called.
01-31 01:27:56.510 432 432 I update_engine: [INFO:metrics_reporter_android.cc(159)] Current update attempt downloads 0 bytes data
Thanks & Regards,
DRAVE
Hello @DRAVE ,
Thanks & Regards,
Sanket Parekh
Hi, @Sanket_Parekh
I'm sorry for hitting the wrong 'Solved' button, but the problem still exists. OTA upgrades still failed !
We have compiled 'incremental_ota_update.zip' as per step 7.13 of document' Android_User's_Guide.pdf '.
We build incremental OTA follow the below-mentioned steps:
cd ${MY_ANDROID}
cp ./out/target/product/mek_8q/obj/PAC KAGING/target_files_intermediates/mek_8q_car-target_files-eng.andrew.zip ./mek_8q_car-no-fec-sound.andrew.zip
----->Modify the source code to enable fec1 and sound
cp ./out/target/product/mek_8q/obj/PAC KAGING/target_files_intermediates/mek_8q_car-target_files-eng.andrew.zip ./mek_8q_car-full.andrew.zip
./build/tools/releasetools/ota_from_target_files -i mek_8q_car-no-fec-sound.andrew.zip mek_8q_car-full.andrew.zip incremental_ota_update.zip
Compile to generate 'incremental_ota_update.zip'
But we can complete the compilation only if we solve two problems. The two questions are as follows:
① ImportError: No module named google.protobuf
② Error: Unable to access jarfile /home/workspace/imx-automotive-12.0.0_1.1.0/android_build/build/make/tools/framework/signapk.jar
OTA upgrade instructions are as follows:update_engine_client --payload=file:///data/ota_package/payload.bin --update --headers="FILE_HASH=92f5jhI06QUmqyWCehXj6LG98kiBoJ7SIIdjzuRv3mQ=
FILE_SIZE=148325
METADATA_HASH=wFjPZRkq578QTUW+Tmejimu7+f/Ln67tn6HQZ7tVa0o=
METADATA_SIZE=146690"
Upgrade failure log (As shown in attachment):
mek_8q:/ # [ 2096.702081] fec: <423> error: get_squashfs_size: failed to parse superblock: Invalid argument
mek_8q:/ # logcat --pid 444
01-31 04:35:03.910 444 444 I update_engine: [INFO:update_attempter_android.cc(546)] Processing Done.
01-31 04:35:03.921 444 444 I update_engine: [INFO:delta_performer.cc(1389)] Resetting recorded hash for prepared partitions.
01-31 04:35:03.930 444 444 I update_engine: [INFO:update_attempter_android.cc(570)] Resetting update progress.
01-31 04:35:03.941 444 444 E update_engine: UnmapAllSnapshots should never be called.
01-31 04:35:03.952 444 444 I update_engine: [INFO:metrics_reporter_android.cc(159)] Current update attempt downloads 0 bytes data
I suspect there may be something wrong with the BSP environment.
Thanks & Regards,
DRAVE
Hello @DRAVE ,
Q)I suspect there may be something wrong with the BSP environment.
->Please check the Python version at runtime you are using it may be possible the older version doesn't include protobuf in its standard library, please try with the latest one.
->Please check whether all the necessary packages are installed for an Android build. See "Establishing a Build Environment" on the Android website
source.android.com/docs/setup/
->One can also make sure by following the below installation to build a BSP environment.
sudo apt-get install uuid uuid-dev zlib1g-dev liblz-dev liblzo2-2 liblzo2-dev lzop git curl u-boot-tools mtd-utils android-sdk-libsparse-utils android-sdk-ext4-utils device-tree-compiler gdisk m4 zlib1g-dev bison flex make libssl-dev gcc-multilib libghc-gnutls-dev swig liblz4-tool liblz4-tool libdw-dev dwarves bc cpio tar lz4 rsync ninja-build clang
Please make sure to follow Section 3 Building the Android Platform for i.MX
It will help you!
Thanks & Regards,
Sanket Parekh
cd ${MY_ANDROID}
FILE_SIZE=148325
Hi, @Sanket_Parekh
cd ${MY_ANDROID}
FILE_SIZE=148325
01-31 04:35:03.890 444 444 I update_engine: [INFO:action_processor.cc(116)] ActionProcessor: finished DownloadAction with code ErrorCode::kDownloadStateInitializationError
01-31 04:35:03.899 444 444 I update_engine: [INFO:action_processor.cc(121)] ActionProcessor: Aborting processing due to failure.
I'm sorry, I clicked the wrong button, but the problem is still there. I suspect there may be something wrong with the BSP environment
Thanks & Regards,
DRAVE
@DRAVE @Sanket_Parekh @shivanipatel @chyun705
Is this issue solved?
If Yes how it is solved ? Please mention proper steps with description and let me know which images you flashed into board.
I am also following the same steps as mentioned below but incremental OTA fails.
Incremental OTA generation steps:
cd ${MY_ANDROID}
lunch evk_8mp-userdebug
cp ./out/target/product/evk_8mp/obj/PAC KAGING/target_files_intermediates/evk_8mp-target_files-eng.build2.zip ./P1_evk_8mp-target_files-eng.build2.zip
----->Modify the source code -> background color
cp ./out/target/product/evk_8mp/obj/PAC KAGING/target_files_intermediates/evk_8mp-target_files-eng.build2.zip ./N1_evk_8mp-target_files-eng.build2.zip
./build/tools/releasetools/ota_from_target_files -i P1_evk_8mp-target_files-eng.build2.zip N1_evk_8mp-target_files-eng.build2.zip incremental_ota_update.zip
Update via update_engine method :
push the payload.bin to data/ota_package/
update_engine_client --payload=file:///data/ota_package/payload.bin --update --headers="FILE_HASH=6cp1fwYPZosMNP1H3PRIRJ5GwL9onvNIPiGhQLv26KI=
FILE_SIZE=141092
METADATA_HASH=9zCfvwWkefjQkoZk0Y14lYsjqo6pmG27ycv9epD+xpw=
METADATA_SIZE=138980"
Attached are error logs for reference.
Let me know if is there any additional information required.
Lavanya
