i.MX8QM - Xen Support - Can't get past bootloader, '** Unrecognized filesystem type **' err
pwcel
Ran 'run xenmmcboot' per the Xen virtualization instructions (IMXVIRTUG_ga.pdf) and despite reformatting the first partition to FAT, and using 'file' to confirm, 'fatload mmc 1:1' (the first command that is run) is never able to recognize the filesystem, reporting:
(See attached Image)
Any ideas why this might be?
pwcel
Reserving more space for header info resolved the issue.
pwcel
