I am using i.MX8M Mini processor (MIMX8MM4CVTKZAA) in one project having industrial surveillance application.
In datasheet, i am not able to find any information explicitly about which GPIO is interrupt capable and which is not. Can you please help me on this? I need details of GPIOs which are interrupt capable.
Thanks in advance,
Nikhil
Another query regarding the same project.
In datasheet, i am not able to identify behavior of ENET0_TD2 pin in RMII and RGMII mode. There may be some typo error i think (not sure about this). Refer attachment.
For your information, we want to use RMII mode.
As per my understanding, for RMII mode, this pin has two options; one for generating 50MHz clock and second for receiving 50MHz clock. And these two options are software configurable. Please confirm if i am right. If not, please help me to understand this.
Thanks in advance,
Nikhil
Hi Nikhil
all gpios are interrupt capable, details can be found in Chapter 7 Interrupts and DMA,
sect.8.3 General Purpose Input/Output (GPIO)
i.MX 8M Mini Applications Processor Reference Manual
Thanks @igorpadykov
