I would like to create a linux distribution via buildroot and use an sd card to boot the board SOM Q7 from seco.
The challenge is that I do not know which xconfig should I use?
Mohamed-Ali Fahmy
Thank you for your interest in NXP Semiconductor products,
Currently buildroot linux distributions are not maintained by NXP, I guess I could refer you to the buildroot documentation.
But I'd rather encourage you to create a linux distribution for your SOM with yocto as you could base on our BSP releases and port your board.
