Hi, I run the following commands to check if i.MX8 MM VPU supports RGB format. And the answer seems no.
gst-inspect-1.0 vpuenc_h264
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw
format: { (string)NV12, (string)I420, (string)YUY2, (string)UYVY, (string)RGBA, (string)RGBx, (string)RGB16, (string)RGB15, (string)BGRA, (string)BGRx, (string)BGR16 }
width: [ 64, 1920, 8 ]
height: [ 64, 1088, 8 ]
framerate: [ 0/1, 2147483647/1 ]
And imxvideoconvert_g2d also can't convert RGB to the formats that VPU supports.
gst-inspect-1.0 imxvideoconvert_g2d
Pad Templates:
Capabilities:
video/x-raw
format: { (string)RGB16, (string)RGBx, (string)RGBA, (string)BGRA, (string)BGRx, (string)BGR16, (string)ARGB, (string)ABGR, (string)xRGB, (string)xBGR, (string)I420, (string)NV12, (string)UYVY, (string)YUY2, (string)YVYU, (string)YV12, (string)NV16, (string)NV21 }
video/x-raw(memory:SystemMemory, meta:GstVideoOverlayComposition)
So is there any hardware acceleration supported to encode RGB video stream to H264 mp4.
Thanks!
try to use the command like this:
"videoparse format=xx width=xx height=xx framerate=xx ! vpuenc_h264! h264parse !"
Dose videoparse support hardware acceleration? We need to parse 1080P 60FPS video stream. videoparse may be not available.
videoparse should use software and vpu only supports yuv
