i.MX7 cortex-M4 MCU description
已解决
跳至解决方案
2,961 次查看
ssinfod
I see that the i.MX7 chip has a Cortex-A7 CPU and Cortex-M4 MCU.
Can somebody tell me if the Cortex-M4 is equivalent to the Kinetis K series ?
Is it the exact same core ?
If I know the Kinetis MCU, will I have a short learning curve with the i.MX7 MCU part ?
Otherwise, is it a generic ARM cortex-M4 ?
Where can I get the description of the Cortex-M4 core inside the i.MX?
ssinfod
标签 (3)
1 解答
2,321 次查看
Carlos_Musich
Yes, it is exact same core.
Kinetis MCUs use generic ARM cortex-M4, so I dont understand your question.
See chapter 4.2 ARM Cortex M4 Platform (CM4) in IMX7D Reference Manual
Carlos
在原帖中查看解决方案
1 回复
2,322 次查看
Carlos_Musich
Carlos
