i.MX6QP-SABRE-SD with Dual Outputs
1,282 次查看
jacoblim
I'm trying to decide on the display hardware to purchase for the i.MX6QP-SABRE SD.
I have read that the board is compatible with the following: MCIMX-LVDS1, MCIMX28LCD and possibly MCIMXHDMICARD.
I am currently using the on-board HDMI as my primary output.
Has anyone tried HDMI + either LVDS, LCD, HDMICARD successfully on the i.MX6QP-SABRE-SD (I believe i.MX6Q-SABRE-SD should be similar)?
My ultimate goal would be to output 2 independent displays with the GPU.
EDIT: By the way, I am using Yocto.
Any help is appreciated.
1,085 次查看
jacoblim
Thanks Rita,
Have decided to purchase the LVDS panel for evaluation.
Jacob
5 回复数
1,085 次查看
Rita_Wang
The thread is created by my couleague https://community.nxp.com/docs/DOC-332671 on i.MX6Q, you can take it as an reference.
1,085 次查看
Rita_Wang
Which version BSP are you using? Our android BSP on i.MX6QP-SABRE SD support dual display.
Rita
1,085 次查看
jacoblim
Hi Rita,
I'm using Linux 4.1.15_2.0.1 Patch.
I understand from the Linux Release Notes that LVDS + HDMI is supported.
Just wondering what other configurations are possible and if anyone had tried them before purchasing the hardware.
Jacob
1,085 次查看
Rita_Wang
Other display is OK, if it is not the default display support, you need to porting the screen diver to your board.
1,086 次查看
jacoblim
Thanks Rita,
Jacob
