While using camera to take snaps we have observed Android crash with varying crash signature.
Attaching logcat for 2 such crash log. Is this a kown issue?
cheers,
mohit
Hi MOHIT
is it custom board or EVK, what camera used in the case.
Had you tried Demo Image – i.MX 8M Nano EVK
with i.MX8M Nano EVK.
Hi Igor,
It's a custom board and camera is OV5640.
I can't find demo image's on the link you provided. The page displays "Note: System is not available to access the information you requested."
cheers,
mohit
Hi Mohit
Demo is available for me
if this is custom board may be suggested to rebuild all image from scratch
and first try to test it in linux :
Hi Igor,
We have built the images from scratch and camera works and is proven under Linux.
The crash is reproducable with Android only.
cheers,
mohit
Please see another crash signature
--------- beginning of main
06-25 21:49:54.932 4201 4201 D CAM_LcyLocProvider: No location received yet.
06-25 21:49:54.953 4201 4265 D CAM_CommandExecutor: Executing command: PictureTakerCommand{command=com.android.camera.one.v2.photo.SimpleImageCaptureCommand@efe31e3} START
06-25 21:49:54.954 4201 4201 D StrictMode: StrictMode policy violation; ~duration=4 ms: android.os.strictmode.DiskReadViolation
06-25 21:49:54.954 4201 4201 D StrictMode: at android.os.StrictMode$AndroidBlockGuardPolicy.onReadFromDisk(StrictMode.java:1504)
06-25 21:49:54.954 4201 4201 D StrictMode: at java.io.UnixFileSystem.checkAccess(UnixFileSystem.java:251)
06-25 21:49:54.954 4201 4201 D StrictMode: at java.io.File.exists(File.java:815)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.app.ContextImpl.ensureExternalDirsExistOrFilter(ContextImpl.java:2539)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.app.ContextImpl.getExternalCacheDirs(ContextImpl.java:719)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.app.ContextImpl.getExternalCacheDir(ContextImpl.java:711)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.content.ContextWrapper.getExternalCacheDir(ContextWrapper.java:279)
06-25 21:49:54.954 4201 4201 D StrictMode: at com.android.camera.CaptureModule.takePictureNow(CaptureModule.java:544)
06-25 21:49:54.954 4201 4201 D StrictMode: at com.android.camera.CaptureModule.onShutterButtonClick(CaptureModule.java:502)
06-25 21:49:54.954 4201 4201 D StrictMode: at com.android.camera.ShutterButton.performClick(ShutterButton.java:190)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.view.View.performClickInternal(View.java:6574)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.view.View.access$3100(View.java:778)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.view.View$PerformClick.run(View.java:25885)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.os.Handler.handleCallback(Handler.java:873)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.os.Handler.dispatchMessage(Handler.java:99)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.os.Looper.loop(Looper.java:193)
06-25 21:49:54.954 4201 4201 D StrictMode: at android.app.ActivityThread.main(ActivityThread.java:6718)
06-25 21:49:54.954 4201 4201 D StrictMode: at java.lang.reflect.Method.invoke(Native Method)
06-25 21:49:54.954 4201 4201 D StrictMode: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
06-25 21:49:54.954 4201 4201 D StrictMode: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:917)
06-25 21:49:54.955 3106 4267 I FslCameraHAL: constructDefaultRequestSettings:0: type=2
06-25 21:49:54.968 4201 4201 V CAM_CameraActivity: onSessionQueued: camera_session://google.com/7f2b99a4-68f7-4528-aa56-47d34ce4b57d
06-25 21:49:54.970 4201 4201 V CAM_FilmstripView: suggesting item bounds: 752x480
06-25 21:49:54.971 4201 4201 V CAM_FilmstripView: getRecycledView, recycled=false
06-25 21:49:54.978 4201 4201 V CAM_FilmstripView: recycleView
06-25 21:49:54.983 4201 4201 I CAM_FilmstripView: [ViewItem:0] mData.renderThumbnail()
06-25 21:49:54.983 4201 4201 D CAM_FilmstripView: onFilmstripItemInserted()
06-25 21:49:55.000 3113 3113 I gralloc : gralloc_allocate, FORMAT_BLOB, 4194304x1
06-25 21:49:55.032 3106 4267 I FslCameraHAL: configure: w:1920, h:1080, sensor format:0x14, stream format:0x21, fps:30, num:2
06-25 21:49:55.054 3106 3164 I FslCameraHAL: freeBuffersLocked
06-25 21:49:55.054 3106 3164 I FslCameraHAL: freeBufferToIon buffer num:3
06-25 21:49:55.055 3106 3164 I FslCameraHAL: onDeviceConfigureLocked
06-25 21:49:55.056 3106 3164 I FslCameraHAL: Width * Height 1920 x 1080 format YUYV, fps: 30
06-25 21:49:55.056 3106 3106 I FslCameraHAL: configure: w:1280, h:720, sensor format:0x14, stream format:0x14, fps:30, num:3
06-25 21:49:55.056 3106 3164 I FslCameraHAL: allocateBuffersLocked
06-25 21:49:55.056 3106 3164 I FslCameraHAL: allocateBufferFromIon buffer num:2
06-25 21:49:55.062 3106 3164 I FslCameraHAL: phyalloc ptr:0x3807916032, phy:0x2297430016, ionSize:4182016
06-25 21:49:55.098 3106 3164 I FslCameraHAL: phyalloc ptr:0x3803734016, phy:0x2311061504, ionSize:4182016
06-25 21:49:55.805 4201 4201 W AudioTrack: AUDIO_OUTPUT_FLAG_FAST denied by server; frameCount 0 -> 20073
06-25 21:49:55.809 3104 4198 I audio_hw_primary: start_output_stream_primary... 0xeb751000, device 2, address , mode 0
06-25 21:49:55.809 3104 4198 I audio_hw_primary: select_output_device(), headphone 0 ,headset 0 ,speaker 2, earpiece 0,
06-25 21:49:55.814 3104 4198 W audio_hw_primary: card 0, port 0 device 0x2
06-25 21:49:55.814 3104 4198 W audio_hw_primary: rate 44100, channel 2 period_size 0xc0
06-25 21:49:55.872 3106 3164 E FslCameraHAL: handleFrameByOpencl:641, Software don't support resize
06-25 21:49:55.872 3106 3164 E FslCameraHAL: handleFrameByCPU:673, Software don't support resize
06-25 21:49:55.874 3106 3164 E FslCameraHAL: Invalid GPS coordinate
06-25 21:49:55.877 3106 3164 I FslCameraHAL: processJpegBuffer srcStream->mWidth:1920, srcStream->mHeight:1080, v4l2Width:1920, v4l2Height:1080
06-25 21:49:56.951 3106 3164 I FslCameraHAL: requestSize 2617835, thumb offset 0x157, main offset 0x73fb
06-25 21:49:56.951 3106 3164 I FslCameraHAL: TiffGrp elenum 8, fixedSzie 102, Size 146, fixedLenIdx 0x14, variedLenIdx 0x7a
06-25 21:49:56.951 3106 3164 I FslCameraHAL: GpsGroup elenum 5, fixedSzie 66, Size 121, fixedLenIdx 0xa6, variedLenIdx 0xe8
06-25 21:49:56.951 3106 3164 I FslCameraHAL: ExifGroup elenum 1, fixedSzie 18, Size 26, fixedLenIdx 0x11f, variedLenIdx 0x131
06-25 21:49:56.951 3106 3164 I FslCameraHAL: TiffGrp_1st elenum 2, fixedSzie 30, Size 30, fixedLenIdx 0x139, variedLenIdx 0x157
06-25 21:49:56.955 3106 3164 I FslCameraHAL: processJpegBuffer, dstbuf size 4194304, jpeg_size 2617835, max jpeg size 4194304
06-25 21:49:56.964 3106 3164 I FslCameraHAL: freeBuffersLocked
06-25 21:49:56.964 3106 3164 I FslCameraHAL: freeBufferToIon buffer num:2
06-25 21:49:56.965 3106 3164 I FslCameraHAL: onDeviceConfigureLocked
06-25 21:49:56.965 3106 3164 I FslCameraHAL: Width * Height 1280 x 720 format YUYV, fps: 30
06-25 21:49:56.966 3106 3164 I FslCameraHAL: allocateBuffersLocked
06-25 21:49:56.966 3106 3164 I FslCameraHAL: allocateBufferFromIon buffer num:3
06-25 21:49:56.974 3106 3164 I FslCameraHAL: phyalloc ptr:0x3892301824, phy:0x2291138560, ionSize:1847296
06-25 21:49:56.977 3106 3164 I FslCameraHAL: phyalloc ptr:0x3888611328, phy:0x2297430016, ionSize:1847296
06-25 21:49:56.980 3106 3164 I FslCameraHAL: phyalloc ptr:0x3886764032, phy:0x2299527168, ionSize:1847296
06-25 21:49:57.623 4201 4265 D CAM_ProcessingSvcMgr: Task added. Queue size now: 1
06-25 21:49:57.625 3259 3271 W ActivityManager: Unable to start service Intent { cmp=com.android.camera2/com.android.camera.processing.ProcessingService } U=0: not found
06-25 21:49:57.627 4201 4265 V CAM_ImageBackend: Received an opened image: 1/0
06-25 21:49:57.627 4201 4265 V CAM_ImageBackend: Setting an image reference count of 1 Total refs = 1
06-25 21:49:57.630 4201 4265 D CAM_CommandExecutor: Executing command: PictureTakerCommand{command=com.android.camera.one.v2.photo.SimpleImageCaptureCommand@efe31e3} END
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 12c00000-52c00000 rw-p 00000000 00:05 15810 /dev/ashmem/dalvik-main space (region space) (deleted)
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6f89f000-6fb78000 rw-p 00000000 b3:0c 261658 /data/dalvik-cache/arm64/system@framework@boot.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fb78000-6fb8e000 r--p 002d9000 b3:0c 261658 /data/dalvik-cache/arm64/system@framework@boot.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fb8e000-6fcc3000 rw-p 00000000 b3:0c 261664 /data/dalvik-cache/arm64/system@framework@boot-core-libart.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fcc3000-6fcd5000 r--p 00135000 b3:0c 261664 /data/dalvik-cache/arm64/system@framework@boot-core-libart.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fcd5000-6fd14000 rw-p 00000000 b3:0c 261670 /data/dalvik-cache/arm64/system@framework@boot-conscrypt.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fd14000-6fd17000 r--p 0003f000 b3:0c 261670 /data/dalvik-cache/arm64/system@framework@boot-conscrypt.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fd17000-6fd53000 rw-p 00000000 b3:0c 261675 /data/dalvik-cache/arm64/system@framework@boot-okhttp.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fd53000-6fd56000 r--p 0003c000 b3:0c 261675 /data/dalvik-cache/arm64/system@framework@boot-okhttp.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fd56000-6fdbc000 rw-p 00000000 b3:0c 261682 /data/dalvik-cache/arm64/system@framework@boot-bouncycastle.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fdbc000-6fdc3000 r--p 00066000 b3:0c 261682 /data/dalvik-cache/arm64/system@framework@boot-bouncycastle.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fdc3000-6fe24000 rw-p 00000000 b3:0c 261688 /data/dalvik-cache/arm64/system@framework@boot-apache-xml.art
06-25 21:49:57.650 4201 4212 F android.camera: file_utils.cc:113] 6fe24000-6fe2b000 r--p 00061000 b3:0c 261688 /data/dalvik-cache/arm64/system@framework@boot-apache-xml.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 6fe2b000-6fe6f000 rw-p 00000000 b3:0c 261693 /data/dalvik-cache/arm64/system@framework@boot-ext.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 6fe6f000-6fe7a000 r--p 00044000 b3:0c 261693 /data/dalvik-cache/arm64/system@framework@boot-ext.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 6fe7a000-7090c000 rw-p 00000000 b3:0c 261700 /data/dalvik-cache/arm64/system@framework@boot-framewor
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] k.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 7090c000-7096c000 r--p 00a92000 b3:0c 261700 /data/dalvik-cache/arm64/system@framework@boot-framework.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 7096c000-70a8b000 rw-p 00000000 b3:0c 261706 /data/dalvik-cache/arm64/system@framework@boot-te
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] lephony-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70a8b000-70a9d000 r--p 0011f000 b3:0c 261706 /data/dalvik-cache/arm64/system@framework@boot-telephony-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70a9d000-70aac000 rw-p 00000000 b3:0c 261712 /data/dalvik-cache/arm64/system@framework@
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] boot-voip-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70aac000-70aae000 r--p 0000f000 b3:0c 261712 /data/dalvik-cache/arm64/system@framework@boot-voip-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70aae000-70ac9000 rw-p 00000000 b3:0c 261718 /data/dalvik-cache/arm64/system@framework@boot-
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] ims-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ac9000-70acb000 r--p 0001b000 b3:0c 261718 /data/dalvik-cache/arm64/system@framework@boot-ims-common.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70acb000-70ace000 rw-p 00000000 b3:0c 261724 /data/dalvik-cache/arm64/system@framework@boot-a
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] ndroid.hidl.base-V1.0-java.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ace000-70ad4000 rw-p 00000000 b3:0c 261730 /data/dalvik-cache/arm64/system@framework@boot-android.hidl.manager-V1.0-java.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ad4000-70ad6000 r--p 00006000 b3:0c 261730 /data/dalvik-cache/arm64/sys
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] tem@framework@boot-android.hidl.manager-V1.0-java.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ad6000-70ad7000 rw-p 00000000 b3:0c 261736 /data/dalvik-cache/arm64/system@framework@boot-framework-oahl-backward-compatibility.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ad7000-70ad8000 r--p 00001000 b3:0c 261736 /data/dalvik-cache/ar
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] m64/system@framework@boot-framework-oahl-backward-compatibility.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ad8000-70adc000 rw-p 00000000 b3:0c 261742 /data/dalvik-cache/arm64/system@framework@boot-android.test.base.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70adc000-70ade000 r--p 00004000 b3:0c 261742 /data/dalvik-cache/arm64/system@framework
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] @boot-android.test.base.art
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70ade000-70bf1000 r--p 00000000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70bf1000-70f28000 r-xp 00113000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70f28000-70f29000 rw-p 00000000 00:00 0
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] [anon:.bss]
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 70f29000-713a7000 r--s 00000000 b3:05 45 /system/framework/boot.vdex
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 713a7000-713a8000 r--p 0044a000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:132] 713a8000-713a9000 rw-p 0044b000 b3:05 190
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] /system/framework/arm64/boot.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 713a9000-71421000 r--p 00000000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 71421000-7156f000 r-xp 00078000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 7156f000-71570000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 71570000-71868000 r--s 00000000 b3:05 127 /system/framework/boot-core-libart.vdex
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 71868000-71869000 r--p 001c6000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 71869000-7186a000 rw-p 001c7000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 7186a000-7187e000 r--p 00000000 b3:05 212 /system/framework/arm64/boot-conscrypt.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 7187e000-718b2000 r-xp 00014000 b3:05 212 /system/framework/arm64/boot-conscrypt.oat
06-25 21:49:57.651 4201 4212 F android.camera: file_utils.cc:113] 718b2000-718b3000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 718b3000-71914000 r--s 00000000 b3:05 125 /system/framework/boot-conscrypt.vdex
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71914000-71915000 r--p 00048000 b3:05 212 /system/framework/arm64/boot-conscrypt.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71915000-71916000 rw-p 00049000 b3:05 212 /system/framework/arm64/boot-conscrypt.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71916000-71930000 r--p 00000000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71930000-71972000 r-xp 0001a000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71972000-71973000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71973000-719d2000 r--s 00000000 b3:05 126 /system/framework/boot-okhttp.vdex
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 719d2000-719d3000 r--p 0005c000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 719d3000-719d4000 rw-p 0005d000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 719d4000-719ed000 r--p 00000000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 719ed000-71a2c000 r-xp 00019000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71a2c000-71a2d000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71a2d000-71b6f000 r--s 00000000 b3:05 155 /system/framework/boot-bouncycastle.vdex
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b6f000-71b70000 r--p 00058000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b70000-71b71000 rw-p 00059000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b71000-71b7e000 r--p 00000000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b7e000-71b98000 r-xp 0000d000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b98000-71b99000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71b99000-71cbb000 r--s 00000000 b3:05 229 /system/framework/boot-apache-xml.vdex
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71cbb000-71cbc000 r--p 00027000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71cbc000-71cbd000 rw-p 00028000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71cbd000-71ccb000 r--p 00000000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71ccb000-71ce7000 r-xp 0000e000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71ce7000-71ce8000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71ce8000-71dd3000 r--s 00000000 b3:05 233 /system/framework/boot-ext.vdex
06-25 21:49:57.652 4201 4212 F android.camera: file_utils.cc:113] 71dd3000-71dd4000 r--p 0002a000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 71dd4000-71dd5000 rw-p 0002b000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 71dd5000-721a2000 r--p 00000000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 721a2000-72c48000 r-xp 003cd000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 72c48000-72c4a000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 72c4a000-73ffa000 r--s 00000000 b3:05 142 /system/framework/boot-framework.vdex
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 73ffa000-73ffb000 r--p 00e73000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 73ffb000-73ffc000 rw-p 00e74000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 73ffc000-7407e000 r--p 00000000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 7407e000-741e1000 r-xp 00082000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 741e1000-741e2000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 741e2000-744b6000 r--s 00000000 b3:05 145 /system/framework/boot-telephony-common.vdex
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744b6000-744b7000 r--p 001e5000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744b7000-744b8000 rw-p 001e6000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744b8000-744bb000 r--p 00000000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744bb000-744bd000 r-xp 00003000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744bd000-744be000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744be000-744e3000 r--s 00000000 b3:05 48 /system/framework/boot-voip-common.vdex
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744e3000-744e4000 r--p 00005000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744e4000-744e5000 rw-p 00006000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744e5000-744ed000 r--p 00000000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744ed000-744fd000 r-xp 00008000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744fd000-744fe000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 744fe000-7451f000 r--s 00000000 b3:05 59 /system/framework/boot-ims-common.vdex
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 7451f000-74520000 r--p 00018000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] 74520000-74521000 rw-p 00019000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 74521000-74524000 r--p 00000000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-java.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 74524000-74525000 r-xp 00003000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] .0-java.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 74525000-7452c000 r--s 00000000 b3:05 52 /system/framework/boot-android.hidl.base-V1.0-java.vdex
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 7452c000-7452d000 r--p 00004000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-ja
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] va.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 7452d000-7452e000 rw-p 00005000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-java.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 7452e000-74531000 r--p 00000000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:113] -V1.0-java.oat
06-25 21:49:57.653 4201 4212 F android.camera: file_utils.cc:132] 74531000-74533000 r-xp 00003000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager-V1.0-java.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74533000-7453e000 r--s 00000000 b3:05 135 /system/framework/boot-android.hidl.manager-V1
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] .0-java.vdex
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 7453e000-7453f000 r--p 00005000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager-V1.0-java.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 7453f000-74540000 rw-p 00006000 b3:05 176 /system/framework/arm64/boot-android.hidl.mana
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] ger-V1.0-java.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74540000-74543000 r--p 00000000 b3:05 201 /system/framework/arm64/boot-framework-oahl-backward-compatibility.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74543000-74544000 r-xp 00003000 b3:05 201 /system/framework/arm64/boot-framework-
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] oahl-backward-compatibility.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74544000-74545000 r--s 00000000 b3:05 144 /system/framework/boot-framework-oahl-backward-compatibility.vdex
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74545000-74546000 r--p 00004000 b3:05 201 /system/framework/arm64/boot-framework-oahl-
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] backward-compatibility.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74546000-74547000 rw-p 00005000 b3:05 201 /system/framework/arm64/boot-framework-oahl-backward-compatibility.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74547000-7454a000 r--p 00000000 b3:05 170 /system/framework/arm64/boot-android.te
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] st.base.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 7454a000-7454b000 r-xp 00003000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 7454b000-74553000 r--s 00000000 b3:05 130 /system/framework/boot-android.test.base.vdex
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:132] 74553000-7455
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 4000 r--p 00004000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 74554000-74555000 rw-p 00005000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 74555000-7469e000 rw-p 00000000 00:05 15807 /dev/ashmem/dalvik-zygote space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 7469e000-7469f000 rw-p 00000000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 7469f000-746b2000 rw-p 00001000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 746b2000-77556000 ---p 00014000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 77556000-78555000 rw-p 02eb8000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 78555000-98555000 rw-p 00000000 00:05 15812 /dev/ashmem/dalvik-free list large object space (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 98555000-9a555000 rw-p 00000000 00:05 26599 /dev/ashmem/dalvik-data-code-cache (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] 9a555000-9c555000 r-xp 00000000 00:05 26600 /dev/ashmem/dalvik-jit-code-cache (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] ebad6000-ebad7000 ---p 00000000 00:05 13471 /dev/ashmem/dalvik-Sentinel fault page (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] aff1a2552000-aff1a2557000 r-xp 00000000 b3:05 1470 /system/bin/app_process64
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] aff1a2571000-aff1a2572000 r--p 0000f000 b3:05 1470 /system/bin/app_process64
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] aff1a2572000-aff1a2574000 rw-p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a425a6000-e82a425a7000 ---p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a425a7000-e82a425a8000 ---p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a425a8000-e82a426ac000 rw-p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a426ac000-e82a446ac000 rw-s 00000000 00:05 28764 /dev/ashmem/AudioFlinger::Client(4201) (deleted)
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a446ac000-e82a446ad000 ---p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a446ad000-e82a447aa000 rw-p 00000000 00:00 0
06-25 21:49:57.654 4201 4212 F android.camera: file_utils.cc:113] e82a447aa000-e82a44baa000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a44baa000-e82a44bab000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a44bab000-e82a44bac000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a44bac000-e82a44ca8000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a44ca8000-e82a44e70000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a44e70000-e82a45038000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45038000-e82a45200000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45200000-e82a45400000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a4542a000-e82a455ec000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a455ec000-e82a457b4000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a457b4000-e82a45976000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45976000-e82a45b38000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45b38000-e82a45cfa000 rw-s 00000000 00:0c 7504 anon_inode:dmabuf
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45cfa000-e82a45cfb000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45cfb000-e82a45cfc000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45cfc000-e82a45e00000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a45e00000-e82a46000000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a460fa000-e82a460fb000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a460fb000-e82a460fc000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a460fc000-e82a46200000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46200000-e82a46a00000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46a47000-e82a46a48000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46a48000-e82a46a49000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46a49000-e82a46b4d000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46b4d000-e82a46cfa000 r--s 003af000 b3:05 922 /system/app/Gallery2/Gallery2.apk
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46cfa000-e82a46cfb000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46cfb000-e82a46cfc000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46cfc000-e82a46e00000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a46e00000-e82a47600000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a4768f000-e82a47697000 r-xp 00000000 b3:0a 251 /vendor/lib64/hw/gralloc_viv.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47697000-e82a476ae000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a476ae000-e82a476af000 r--p 0000f000 b3:0a 251 /vendor/lib64/hw/gralloc_viv.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a476af000-e82a476b0000 rw-p 00010000 b3:0a 251 /vendor/lib64/hw/gralloc_viv.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a476ee000-e82a477b1000 r-xp 00000000 b3:0a 180 /vendor/lib64/libGLSLC.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a477b1000-e82a477c4000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:132] e82a477c4000-e82a477ca000 r--p 000ca000 b3:0a 180 /vendor/lib64/libGLSLC.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:132] e82a477ca000-e82a477f2000 rw-p 000d0000 b3:0a 180 /vendor/lib64/libGLSLC.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:132] e82a47800000-e82a47a00000 rw-p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] [anon:libc_malloc]
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a15000-e82a47a55000 rw-s 00000000 00:05 19386 /dev/zero (deleted)
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a55000-e82a47a58000 r-xp 00000000 b3:0a 249 /vendor/lib64/hw/gralloc.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a58000-e82a47a74000 ---p 00000000 00:00 0
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a74000-e82a47a75000 r--p 0000f000 b3:0a 249 /vendor/lib64/hw/gralloc.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a75000-e82a47a76000 rw-p 00010000 b3:0a 249 /vendor/lib64/hw/gralloc.imx8.so
06-25 21:49:57.655 4201 4212 F android.camera: file_utils.cc:113] e82a47a98000-e82a47a9a000 r-xp 00000000 b3:0a 232 /vendor/lib64/libedid.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47a9a000-e82a47ab7000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ab7000-e82a47ab8000 r--p 0000f000 b3:0a 232 /vendor/lib64/libedid.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ab8000-e82a47ab9000 rw-p 00010000 b3:0a 232 /vendor/lib64/libedid.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ac0000-e82a47ae9000 r-xp 00000000 b3:0a 177 /vendor/lib64/libfsldisplay.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ae9000-e82a47afd000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47afd000-e82a47aff000 r--p 0002e000 b3:0a 177 /vendor/lib64/libfsldisplay.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47aff000-e82a47b00000 rw-p 00030000 b3:0a 177 /vendor/lib64/libfsldisplay.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47b02000-e82a47b03000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47b03000-e82a47c00000 rw-p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47c00000-e82a47e00000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47e0c000-e82a47e4c000 rw-s 00000000 00:05 26915 /dev/zero (deleted)
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47e4c000-e82a47e4e000 r-xp 00000000 b3:05 737 /system/lib64/vndk-sp-28/libion.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47e4e000-e82a47e6b000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47e6b000-e82a47e6c000 r--p 0000f000 b3:05 737 /system/lib64/vndk-sp-28/l
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] ibion.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47e6c000-e82a47e6d000 rw-p 00010000 b3:05 737 /system/lib64/vndk-sp-28/libion.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47e8e000-e82a47ea5000 r-xp 00000000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47ea5000-e82a47ebb000 ---p 00
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] 000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47ebb000-e82a47ebd000 r--p 0001e000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47ebd000-e82a47ebe000 rw-p 00020000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a47ef1000-e82a47ef2000
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ef2000-e82a47ef3000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ef3000-e82a47ff7000 rw-p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ff7000-e82a47ff8000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ff8000-e82a47ff9000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a47ff9000-e82a480f5000 rw-p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a480f5000-e82a480f6000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a480f6000-e82a480f7000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a480f7000-e82a481fb000 rw-p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a481fb000-e82a481fd000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a481fd000-e82a482f9000 rw-p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:132] e82a482f9000-e82a483f9000 rw-s 00000000 00:05 26895
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a483f9000-e82a484f9000 rw-s 00000000 00:05 27825 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a484f9000-e82a484fa000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a484fa000-e82a484fb000 ---p 00000000 00:00 0
06-25 21:49:57.656 4201 4212 F android.camera: file_utils.cc:113] e82a484fb000-e82a485ff000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a485ff000-e82a48601000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48601000-e82a486fd000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a486fd000-e82a486fe000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a486fe000-e82a486ff000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a486ff000-e82a48803000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48803000-e82a48903000 rw-s 00000000 00:05 19342 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48903000-e82a48a03000 rw-s 00000000 00:05 26862 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48a03000-e82a48a04000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48a04000-e82a48a05000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48a05000-e82a48b01000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48b01000-e82a48b02000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48b02000-e82a48b03000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48b03000-e82a48bff000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48bff000-e82a48c00000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48c00000-e82a48c01000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48c01000-e82a48d05000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48d05000-e82a48d06000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48d06000-e82a48d07000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48d07000-e82a48e03000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e03000-e82a48e08000 r-xp 00000000 b3:05 741 /system/lib64/vndk-sp-28/hw/android.
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] hidl.memory@1.0-impl.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e08000-e82a48e22000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e22000-e82a48e23000 r--p 0000f000 b3:05 741 /system/lib64/vndk-sp-28/hw/android.hidl.memory@1.0-impl.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e23000-e82a48e24000 rw-p 00010000 b3:05 741 /
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] system/lib64/vndk-sp-28/hw/android.hidl.memory@1.0-impl.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e41000-e82a48e61000 r-xp 00000000 b3:05 733 /system/lib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e61000-e82a48e7b000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:132] e82a48e7b000-e82a48e7e000 r--p 0002d000 b3:05 733 /system/l
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] ib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48e7e000-e82a48e7f000 rw-p 00030000 b3:05 733 /system/lib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48e89000-e82a48e8a000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48e8a000-e82a48e8b000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48e8b000-e82a48f87000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a48f87000-e82a49085000 r--p 00000000 00:14 10476 /dev/hwbinder
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a49085000-e82a49086000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a49086000-e82a49087000 ---p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a49087000-e82a49183000 rw-p 00000000 00:00 0
06-25 21:49:57.657 4201 4212 F android.camera: file_utils.cc:113] e82a49183000-e82a49184000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49184000-e82a49185000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49185000-e82a49289000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49289000-e82a49389000 rw-s 00000000 00:05 28681 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49389000-e82a4938a000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4938a000-e82a4938b000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4938b000-e82a49487000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49487000-e82a49488000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49488000-e82a49489000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49489000-e82a49585000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49585000-e82a49586000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49586000-e82a49587000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49587000-e82a4968b000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4968b000-e82a4968c000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4968c000-e82a4968d000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4968d000-e82a49791000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49791000-e82a49792000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49792000-e82a49793000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49793000-e82a49897000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49897000-e82a49898000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49898000-e82a49899000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49899000-e82a4999d000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4999d000-e82a4999e000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4999e000-e82a4999f000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4999f000-e82a49a9b000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a49a9b000-e82a4ba9b000 rw-s 00000000 00:05 27802 /dev/zero (deleted)
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4baa3000-e82a4baa4000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4baa4000-e82a4baa5000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4baa5000-e82a4bba1000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4bba1000-e82a4bd2f000 r--s 00567000 b3:05 896 /system/app/Camera2/Camera2.apk
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4bd2f000-e82a4bd30000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4bd30000-e82a4bd31000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4bd31000-e82a4be2d000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:132] e82a4be2d000-e82a4be3c000 r--p 00000000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.dex
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:132] e82a4be3c000-e82a4be3d000 r-xp 0000f000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] 2@Camera2.apk@classes.dex
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:132] e82a4be3d000-e82a4c0b9000 r--s 00000000 b3:0c 261930 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.vdex
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:132] e82a4c0b9000-e82a4c0ba000 r--p 00010000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camer
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] a2@Camera2.apk@classes.dex
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4c0ba000-e82a4c0bb000 rw-p 00011000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.dex
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4c0e1000-e82a4c0e2000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4c0e2000-e82a4c0e3000 ---p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4c0e3000-e82a4c1df000 rw-p 00000000 00:00 0
06-25 21:49:57.658 4201 4212 F android.camera: file_utils.cc:113] e82a4c1df000-e82a4c1e0000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4c1e0000-e82a4c1e1000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4c1e1000-e82a4c2dd000 rw-p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4c2dd000-e82a4c3db000 r--p 00000000 00:14 8905 /dev/binder
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4c3db000-e82a4db78000 r--s 00000000 b3:05 2717 /system/fonts/NotoSerifCJK-Regular.ttc
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4db78000-e82a4ed48000 r--s 00000000 b3:05 2728 /system/fonts/NotoSansCJK-Regular.ttc
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a4ed48000-e82a57a00000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57a00000-e82a57c00000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57c2c000-e82a57ca4000 r--p 00000000 00:05 26620 /dev/ashmem/dalvik-classes.dex extracted in memory from /system/framework/org.apache.http.l
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] egacy.boot.jar (deleted)
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57ca4000-e82a57ca5000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57ca5000-e82a57ca6000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57ca6000-e82a57daa000 rw-p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57daa000-e82a57ed7000 r-xp 00000000 b3:0a 175 /vendor/lib64/egl/libGLESv2_VIVANTE.
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57ed7000-e82a57ef2000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57ef2000-e82a57efa000 r--p 00138000 b3:0a 175 /vendor/lib64/egl/libGLESv2_VIVANTE.so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57efa000-e82a57f1f000 rw-p 00140000 b3:0a 175 /vendor/lib64/egl/libG
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] LESv2_VIVANTE.so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57f1f000-e82a57f3a000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57f3b000-e82a57f5b000 rw-p 00000000 00:05 26917 /dev/ashmem/dalvik-LinearAlloc (deleted)
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:132] e82a57f5b000-e82a58486000 r-xp 00000000 b3:0a 233
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] /vendor/lib64/libVSC.so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58486000-e82a58497000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58497000-e82a584ab000 r--p 0052c000 b3:0a 233 /vendor/lib64/libVSC.so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a584ab000-e82a584ee000 rw-p 00540000 b3:0a 233 /vendor/lib64/libVSC.so
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a584fc000-e82a5851c000 rw-p 00000000 00:05 26916 /dev/ashmem/dalvik-LinearAlloc (deleted)
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5851c000-e82a5851d000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5851d000-e82a5851e000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5851e000-e82a58622000 rw-p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58622000-e82a58623000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58623000-e82a58624000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58624000-e82a58728000 rw-p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58728000-e82a58729000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58729000-e82a5872a000 ---p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5872a000-e82a5882e000 rw-p 00000000 00:00 0
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5882e000-e82a58f9d000 r--s 00000000 b3:05 2572 /system/fonts/NotoColorEmoji.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a58f9d000-e82a5904b000 r--s 00000000 b3:05 2644 /system/fonts/NotoSansSymbols-Regular-Subsetted.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5904b000-e82a590a7000 r--s 00000000 b3:05 2546 /system/fonts/NotoSansTibetan-Bold.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a590a7000-e82a5910a000 r--s 00000000 b3:05 2573 /system/fonts/NotoSansTibetan-Regular.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5910a000-e82a59186000 r--s 00000000 b3:05 2558 /system/fonts/NotoSansEgyptianHieroglyphs-Regular.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a59186000-e82a59201000 r--s 00000000 b3:05 2678 /system/fonts/NotoSansCuneiform-Regular.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a59201000-e82a59252000 r--s 00000000 b3:05 2541 /system/fonts/RobotoCondensed-BoldItalic.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a59252000-e82a5929d000 r--s 00000000 b3:05 2566 /system/fonts/RobotoCondensed-Bold.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5929d000-e82a592ee000 r--s 00000000 b3:05 2514 /system/fonts/RobotoCondensed-MediumItalic.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a592ee000-e82a59339000 r--s 00000000 b3:05 2545 /system/fonts/RobotoCondensed-Medium.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a59339000-e82a5938a000 r--s 00000000 b3:05 2714 /system/fonts/RobotoCondensed-Italic.ttf
06-25 21:49:57.659 4201 4212 F android.camera: file_utils.cc:113] e82a5938a000-e82a593d4000 r--s 00000000 b3:05 2636 /system/fonts/RobotoCondensed-Regular.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a593d4000-e82a593d6000 r-xp 00000000 b3:05 377 /system/lib64/libwebviewchromium_loader.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a593d6000-e82a593f3000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a593f3000-e82a593f4000 r--p 0000f000 b3:05 377 /system/lib64/libwebviewchromium_loader.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a593f4000-e82a593f5000 rw-p 00010000 b3:05 377 /system/lib64/libwebviewchromium_loader.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5940b000-e82a5942b000 rw-p 00000000 00:05 26914 /dev/ashmem/dalvik-CompilerMetadata (deleted)
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5942b000-e82a5947d000 r--s 00000000 b3:05 2616 /system/fonts/RobotoCondensed-LightItalic.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5947d000-e82a594c7000 r--s 00000000 b3:05 2619 /system/fonts/RobotoCondensed-Light.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a594c7000-e82a59519000 r--s 00000000 b3:05 2733 /system/fonts/Roboto-BoldItalic.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59519000-e82a59564000 r--s 00000000 b3:05 2513 /system/fonts/Roboto-Bold.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59564000-e82a595b5000 r--s 00000000 b3:05 2542 /system/fonts/Roboto-BlackItalic.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a595b5000-e82a59600000 r--s 00000000 b3:05 2652 /system/fonts/Roboto-Black.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59600000-e82a59651000 r--s 00000000 b3:05 2596 /system/fonts/Roboto-MediumItalic.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59651000-e82a59671000 r-xp 00000000 b3:05 801 /system/lib64/libcompiler_rt.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59671000-e82a59690000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59690000-e82a59691000 r--p 0002f000 b3:05 801 /system/lib64/libcompiler_rt.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59691000-e82a59692000 rw-p 00030000 b3:05 801 /system/lib64/libcompiler_rt.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59692000-e82a596ff000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59701000-e82a59721000 r-xp 00000000 b3:0a 173 /vendor/lib64/egl/libEGL_VIVANTE.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59721000-e82a5973c000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5973c000-e82a5973e000 r--p 0002e000 b3:0a 173 /vendor/lib64/egl/libEGL_VIVANTE.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5973e000-e82a5973f000 rw-p 00030000 b3:0a 173 /vendor/lib64/egl/libEGL_VIVANTE.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5973f000-e82a59740000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59740000-e82a5983a000 r-xp 00000000 b3:0a 182 /vendor/lib64/libGAL.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a5983a000-e82a59854000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59854000-e82a59857000 r--p 000fd000 b3:0a 182 /vendor/lib64/libGAL.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59857000-e82a59880000 rw-p 00100000 b3:0a 182 /vendor/lib64/libGAL.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59884000-e82a59896000 r-xp 00000000 b3:0a 191 /vendor/lib64/libdrm_android.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59896000-e82a598b3000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598b3000-e82a598b4000 r--p 0001f000 b3:0a 191 /vendor/lib64/libdrm_android.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598b4000-e82a598b5000 rw-p 00020000 b3:0a 191 /vendor/lib64/libdrm_android.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598b8000-e82a598d8000 rw-p 00000000 00:05 26913 /dev/ashmem/dalvik-CompilerMetadata (deleted)
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598d8000-e82a598da000 r-xp 00000000 b3:0a 164 /vendor/lib64/libdrm_vivante.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598da000-e82a598f7000 ---p 00000000 00:00 0
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598f7000-e82a598f8000 r--p 0000f000 b3:0a 164 /vendor/lib64/libdrm_vivante.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598f8000-e82a598f9000 rw-p 00010000 b3:0a 164 /vendor/lib64/libdrm_vivante.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a598fe000-e82a59949000 r--s 00000000 b3:05 2697 /system/fonts/Roboto-Medium.ttf
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59949000-e82a59995000 r-xp 00000000 b3:0a 172 /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
06-25 21:49:57.660 4201 4212 F android.camera: file_utils.cc:113] e82a59995000-e82a599a4000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599a4000-e82a599a7000 r--p 0004d000 b3:0a 172 /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599a7000-e82a599a8000 rw-p 00050000 b3:0a 172 /vendor/lib64/egl/libGLESv1_CM_VIVANTE.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599c2000-e82a599d3000 r-xp 00000000 b3:05 756 /system/lib64/vndk-sp-28/libcutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599d3000-e82a599f0000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599f0000-e82a599f2000 r--p 0001e000 b3:05 756 /system/lib64/vndk-sp-28/libcutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a599f2000-e82a599f3000 rw-p 00020000 b3:05 756 /system/lib64/vndk-sp-28/libcutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a08000-e82a59a1f000 r-xp 00000000 b3:05 739 /system/lib64/vndk-sp-28/android.hardware.graphics.mapper@2.0.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a1f000-e82a59a34000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a34000-e82a59a36000 r--p 0001e000 b3:05 739 /system/lib64/vndk-sp-28/android.hardware.graphics.mapper@2.0.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a36000-e82a59a37000 rw-p 00020000 b3:05 739 /system/lib64/vndk-sp-28/android.hardware.graphics.mapper@2.0.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a40000-e82a59a67000 r-xp 00000000 b3:05 735 /system/lib64/vndk-sp-28/libhwbinder.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a67000-e82a59a7d000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a7d000-e82a59a7f000 r--p 0002e000 b3:05 735 /system/lib64/vndk-sp-28/libhwbinder.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a7f000-e82a59a80000 rw-p 00030000 b3:05 735 /system/lib64/vndk-sp-28/libhwbinder.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59a8c000-e82a59aa7000 r-xp 00000000 b3:05 749 /system/lib64/vndk-sp-28/libutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59aa7000-e82a59abb000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59abb000-e82a59abc000 r--p 0001f000 b3:05 749 /system/lib64/vndk-sp-28/libutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59abc000-e82a59abd000 rw-p 00020000 b3:05 749 /system/lib64/vndk-sp-28/libutils.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59ac5000-e82a59ac7000 r-xp 00000000 b3:05 751 /system/lib64/vndk-sp-28/libhardware.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59ac7000-e82a59ae4000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59ae4000-e82a59ae5000 r--p 0000f000 b3:05 751 /system/lib64/vndk-sp-28/libhardware.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59ae5000-e82a59ae6000 rw-p 00010000 b3:05 751 /system/lib64/vndk-sp-28/libhardware.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59afd000-e82a59b1d000 rw-p 00000000 00:05 19396 /dev/ashmem/dalvik-CompilerMetadata (deleted)
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59b1d000-e82a59b23000 r-xp 00000000 b3:0a 266 /vendor/lib64/hw/android.hardware.graphics.mapper@2.0-impl.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59b23000-e82a59b3c000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:132] e82a59b3c000-e82a59b3d000 r--p 0000f000 b3:0a 266 /vendor/lib64/hw/android.hardware.graphics.mapper@2.0-impl.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:132] e82a59b3d000-e82a59b3e000 rw-p 00010000 b3:0a 266 /vendor/lib64/hw/android.hardware.graphics.mappe
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] r@2.0-impl.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:132] e82a59b55000-e82a59bb6000 r-xp 00000000 b3:05 750 /system/lib64/vndk-sp-28/libhidltransport.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:132] e82a59bb6000-e82a59bd3000 ---p 00000000 00:00 0
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:132] e82a59bd3000-e82a59bdb000 r--p 00068000 b3:05 750 /system/lib64/vn
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] dk-sp-28/libhidltransport.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59bdb000-e82a59bdc000 rw-p 00070000 b3:05 750 /system/lib64/vndk-sp-28/libhidltransport.so
06-25 21:49:57.661 4201 4212 F android.camera: file_utils.cc:113] e82a59bf8000-e82a59c18000 rw-p 00000000 00:05 27863 /dev/ashmem/dalvik-CompilerMetadata (deleted)
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a59c18000-e82a5b800000 r--s 010d1000 b3:05 217 /system/framework/framework-res.apk
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a5b800000-e82a5ba00000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a5ba03000-e82a5ba43000 rw-s 00000000 00:05 27842 /dev/zero (deleted)
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a5ba43000-e82a5bb10000 r-xp 00000000 b3:05 757 /system/lib64/vndk-sp-28/libc++.so
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a5bb10000-e82a5bb2c000 ---p 00000000 00:00 0
06-25 21:49:57.662 4201 4212 F android.camera: file_utils.cc:113] e82a5bb2c000-e82a5bb36000 r--p 000d6000 b3:05 757 /system/lib64/vndk-sp-28/libc++.so
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bf90000-e82a5bf94000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bf94000-e82a5bf95000 ---p 00000000 00:00 0
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bf95000-e82a5bf98000 rw-p 00000000 00:00 0
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bf98000-e82a5bf99000 ---p 00000000 00:00 0
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bf99000-e82a5bfba000 r-xp 00000000 b3:05 744 /system/lib64/vndk-sp-28/libhidlbase.so
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bfba000-e82a5bfd7000 ---p 00000000 00:00 0
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bfd7000-e82a5bfd9000 r--p 0002e000 b3:05 744 /system/lib64/vndk-sp-28/libhidlbase.so
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bfd9000-e82a5bfda000 rw-p 00030000 b3:05 744 /system/lib64/vndk-sp-28/libhidlbase.so
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bfde000-e82a5bfdf000 ---p 00000000 00:00 0
06-25 21:49:57.663 4201 4212 F android.camera: file_utils.cc:113] e82a5bfdf000-e82a5bfe3000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e254000-e82a5e25b000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e25f000-e82a5e260000 ---p 00000000 00:00 0
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e260000-e82a5e264000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e264000-e82a5e284000 rw-p 00000000 00:05 28687 /dev/ashmem/dalvik-CompilerMetadata (deleted)
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e284000-e82a5e28c000 r-xp 00000000 b3:05 411 /system/lib64/libopenjdkjvm.so
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e28c000-e82a5e2a3000 ---p 00000000 00:00 0
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e2a3000-e82a5e2a4000 r--p 0000f000 b3:05 411 /system/lib64/libopenjdkjvm.so
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e2a4000-e82a5e2a5000 rw-p 00010000 b3:05 411 /system/lib64/libopenjdkjvm.so
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e2a5000-e82a5e2c5000 r--s 00000000 00:14 8795 /dev/__properties__/u:object_r:hwservicemanager_prop:s0
06-25 21:49:57.665 4201 4212 F android.camera: file_utils.cc:113] e82a5e2c5000-e82a5e30e000 r-xp 00000000 b3:05 287 /system/lib64/libssl.so
06-25 21:49:57.666 4201 4212 F android.camera: file_utils.cc:113] e82a5e30e000-e82a5e322000 ---p 00000000 00:00 0
06-25 21:49:57.666 4201 4212 F android.camera: file_utils.cc:113] e82a5e322000-e82a5e325000 r--p 0004d000 b3:05 287 /system/lib64/libssl.so
06-25 21:49:57.666 4201 4212 F android.camera: file_utils.cc:113] e82a5e325000-e82a5e326000 rw-p 00050000 b3:05 287 /system/lib64/libssl.so
06-25 21:49:57.666 4201 4212 F android.camera: file_utils.cc:113] e82a5e328000-e82a5e329000 ---p 00000000 00:00 0
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:132] e82a5fcbf000-e82a5fcc3000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] gular.ttf
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] e82a5fcdf000-e82a5fce1000 r-xp 00000000 b3:05 290 /system/lib64/libOpenMAXAL.so
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] e82a5fce1000-e82a5fcfe000 ---p 00000000 00:00 0
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] e82a5fcfe000-e82a5fcff000 r--p 0000f000 b3:05 290 /system/lib64/libOpenMAXAL.so
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] e82a5fcff000-e82a5fd00000 rw-p 00010000 b3:05 290 /system/lib64/libOpenMAXAL.so
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:132] e82a5fd02000-e82a5fd03000 ---p 00000000 00:00 0
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:132] e82a5fd03000-e82a5fd06000 rw-p 00000000 00:00 0
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:132] e82a5fd06000-e82a5fd07000 ---p 00000000 00:00 0
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:132] e82a5fd07000-e82a5fd17000 rw-s 00000000 00:05 19344 /dev/ashmem/RemoteDataSource (delete
06-25 21:49:57.668 4201 4212 F android.camera: file_utils.cc:113] d)
06-25 21:49:57.669 4201 4212 F android.camera: file_utils.cc:113] e82a5fff1000-e82a5fff2000 ---p 00000000 00:00 0
06-25 21:49:57.669 4201 4212 F android.camera: file_utils.cc:113] e82a5fff2000-e82a5fff6000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.669 4201 4212 F android.camera: file_utils.cc:113] e82a5fff6000-e82a5fff7000 ---p 00000000 00:00 0
06-25 21:49:57.669 4201 4212 F android.camera: file_utils.cc:113] e82a5fff7000-e82a5fffa000 rw-p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a5fffa000-e82a5fffb000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a5fffb000-e82a5fffc000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a5fffc000-e82a60000000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60000000-e82a60001000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60001000-e82a60004000 rw-p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60004000-e82a60005000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:132] e82a60005000-e82a6003a000 r-xp 00000000 b3:05 816 /system/lib64/android.hardware.neuralnetworks@1.0.so
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:132] e82a6003a000-e82a60058000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:132] e82a60058000-e82a6005e000 r--p 0003a000 b3:05 816 /system/
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] lib64/android.hardware.neuralnetworks@1.0.so
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a6005e000-e82a6005f000 rw-p 00040000 b3:05 816 /system/lib64/android.hardware.neuralnetworks@1.0.so
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a6005f000-e82a60061000 rw-p 00000000 00:05 28763 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60061000-e82a60063000 rw-p 00000000 00:05 27852 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60063000-e82a60064000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60064000-e82a60068000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60068000-e82a60069000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60069000-e82a6006c000 rw-p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a6006c000-e82a6006d000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a6006d000-e82a6006e000 ---p 00000000 00:00 0
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a6006e000-e82a60072000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.670 4201 4212 F android.camera: file_utils.cc:113] e82a60072000-e82a60073000 ---p 00000000 00:00 0
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6012a000-e82a6013a000 ---p 00000000 00:00 0
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6013a000-e82a6013c000 r--p 0001e000 b3:05 280 /system/lib64/libmediandk.so
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6013c000-e82a6013d000 rw-p 00020000 b3:05 280 /system/lib64/libmediandk.so
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6013e000-e82a6014e000 rw-s 00000000 00:05 28683 /dev/ashmem/RemoteDataSource (deleted)
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6014e000-e82a6014f000 ---p 00000000 00:00 0
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a6014f000-e82a60153000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a60153000-e82a60175000 r--s 00000000 b3:05 2557 /system/fonts/NotoSerifMyanmar-Bold.otf
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a60175000-e82a601de000 r-xp 00000000 b3:05 434 /system/lib64/libmedia_jni.so
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a601de000-e82a601f5000 ---p 00000000 00:00 0
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a601f5000-e82a601fc000 r--p 00069000 b3:05 434 /system/lib64/libmedia_jni.so
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a601fc000-e82a601fd000 rw-p 00070000 b3:05 434 /system/lib64/libmedia_jni.so
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a601fd000-e82a601ff000 rw-p 00000000 00:05 19387 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a601ff000-e82a60201000 rw-p 00000000 00:05 28705 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a60201000-e82a60202000 ---p 00000000 00:00 0
06-25 21:49:57.671 4201 4212 F android.camera: file_utils.cc:113] e82a60202000-e82a60206000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60206000-e82a60207000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60207000-e82a6020a000 rw-p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6020a000-e82a6020c000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6020c000-e82a6020f000 rw-p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6020f000-e82a60210000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60210000-e82a6021f000 r-xp 00000000 b3:05 714 /system/lib64/libmidi.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6021f000-e82a6023d000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6023d000-e82a6023f000 r--p 0000e000 b3:05 714 /system/lib64/libmidi.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6023f000-e82a60240000 rw-p 00010000 b3:05 714 /system/lib64/libmidi.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60241000-e82a6026a000 r-xp 00000000 b3:05 468 /system/lib64/libmtp.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6026a000-e82a6027c000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6027c000-e82a6027f000 r--p 0002d000 b3:05 468 /system/lib64/libmtp.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6027f000-e82a60280000 rw-p 00030000 b3:05 468 /system/lib64/libmtp.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60281000-e82a60282000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60282000-e82a60286000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60286000-e82a60287000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60287000-e82a6028a000 rw-p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6028a000-e82a6028b000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6028b000-e82a6028c000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6028c000-e82a60290000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60290000-e82a602d4000 r-xp 00000000 b3:05 814 /system/lib64/android.hardware.drm@1.1.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a602d4000-e82a602f2000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a602f2000-e82a602f8000 r--p 0004a000 b3:05 814 /system/lib64/android.hardware.drm@1.1.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a602f8000-e82a602f9000 rw-p 00050000 b3:05 814 /system/lib64/android.hardware.drm@1.1.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a602fa000-e82a60319000 r--s 00000000 b3:05 2680 /system/fonts/NotoSansYi-Regular.ttf
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60319000-e82a6031a000 r-xp 00000000 b3:05 788 /system/lib64/libasyncio.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6031a000-e82a60338000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60338000-e82a60339000 r--p 0000f000 b3:05 788 /system/lib64/libasyncio.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60339000-e82a6033a000 rw-p 00010000 b3:05 788 /system/lib64/libasyncio.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6033a000-e82a6033b000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6033b000-e82a6033e000 rw-p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6033e000-e82a6033f000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6033f000-e82a60358000 r--s 00000000 b3:05 2694 /system/fonts/NotoSansLepcha-Regular.ttf
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a60358000-e82a6037f000 r-xp 00000000 b3:05 373 /system/lib64/libexif.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6037f000-e82a6039b000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a6039b000-e82a603ae000 r--p 0002d000 b3:05 373 /system/lib64/libexif.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603ae000-e82a603af000 rw-p 00040000 b3:05 373 /system/lib64/libexif.so
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603b0000-e82a603b2000 rw-p 00000000 00:05 19365 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603b2000-e82a603b3000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603b3000-e82a603b7000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603b7000-e82a603b8000 ---p 00000000 00:00 0
06-25 21:49:57.672 4201 4212 F android.camera: file_utils.cc:113] e82a603b8000-e82a603bb000 rw-p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603bb000-e82a603bc000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603bc000-e82a603bd000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603bd000-e82a603c1000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603c1000-e82a603df000 r-xp 00000000 b3:05 832 /system/lib64/libcamera2ndk.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603df000-e82a603fd000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603fd000-e82a603ff000 r--p 0001e000 b3:05 832 /system/lib64/libcamera2ndk.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a603ff000-e82a60400000 rw-p 00020000 b3:05 832 /system/lib64/libcamera2ndk.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a60401000-e82a60402000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a60402000-e82a60405000 rw-p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a60405000-e82a60406000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a60406000-e82a60428000 r--s 00000000 b3:05 2633 /system/fonts/NotoSerifMyanmar-Regular.otf
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a60428000-e82a6048e000 r-xp 00000000 b3:05 835 /system/lib64/android.hardware.drm@1.0.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a6048e000-e82a604a5000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604a5000-e82a604ad000 r--p 00068000 b3:05 835 /system/lib64/android.hardware.drm@1.0.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604ad000-e82a604ae000 rw-p 00070000 b3:05 835 /system/lib64/android.hardware.drm@1.0.so
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604ae000-e82a604b0000 rw-p 00000000 00:05 28694 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604b0000-e82a604b2000 rw-p 00000000 00:05 19391 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604b2000-e82a604b3000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604b3000-e82a604b7000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604b7000-e82a604b8000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604b8000-e82a604bc000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:113] e82a604bc000-e82a604bd000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:132] e82a604bd000-e82a604c0000 rw-p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:132] e82a604c0000-e82a604c1000 ---p 00000000 00:00 0
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:132] e82a604c1000-e82a604e5000 r--s 00000000 b3:05 2512 /system/fonts/NotoSansKhmer-VF.ttf
06-25 21:49:57.673 4201 4212 F android.camera: file_utils.cc:132] e82a604e5000-e82a60511000 r-xp 00000000 b3:05 390
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a63ff7000-e82a63ffa000 rw-p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a63ffa000-e82a63ffb000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a63ffb000-e82a63ffc000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a63ffc000-e82a64000000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64000000-e82a64400000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64400000-e82a64402000 rw-p 00000000 00:05 26841 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64402000-e82a64404000 rw-p 00000000 00:05 28680 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64404000-e82a64456000 r--s 00000000 b3:05 2543 /system/fonts/Roboto-LightItalic.ttf
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64456000-e82a6445a000 r-xp 00000000 b3:05 284 /system/lib64/libtombstoned_client.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a6445a000-e82a64475000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64475000-e82a64476000 r--p 0000f000 b3:05 284 /system/lib64/libtombstoned_client.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64476000-e82a64477000 rw-p 00010000 b3:05 284 /system/lib64/libtombstoned_client.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64478000-e82a64493000 r--s 00000000 b3:05 2689 /system/fonts/NotoSansMyanmar-Regular.ttf
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64493000-e82a64495000 r-xp 00000000 b3:05 305 /system/lib64/libmetricslogger.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64495000-e82a644b2000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644b2000-e82a644b3000 r--p 0000f000 b3:05 305 /system/lib64/libmetricslogger.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644b3000-e82a644b4000 rw-p 00010000 b3:05 305 /system/lib64/libmetricslogger.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644b4000-e82a644b6000 rw-p 00000000 00:05 19322 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644b6000-e82a644b7000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644b7000-e82a644ba000 rw-p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644ba000-e82a644bb000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644bb000-e82a644d0000 r--s 00000000 b3:05 2639 /system/fonts/NotoSansSinhalaUI-Bold.otf
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a644d0000-e82a6453e000 r-xp 00000000 b3:05 237 /system/lib64/android.hardware.media.omx@1.0.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a6453e000-e82a6455b000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a6455b000-e82a64564000 r--p 00077000 b3:05 237 /system/lib64/android.hardware.media.omx@1.0.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64564000-e82a64565000 rw-p 00080000 b3:05 237 /system/lib64/android.hardware.media.omx@1.0.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64566000-e82a64567000 ---p 00000000 00:00 0
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64567000-e82a6456b000 rw-p 00000000 00:00 0 [anon:thread signal stack]
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a6456b000-e82a64590000 r--s 00000000 b3:05 2535 /system/fonts/NotoSerifTelugu-Bold.ttf
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64590000-e82a64593000 r-xp 00000000 b3:05 712 /system/lib64/libETC1.so
06-25 21:49:57.676 4201 4212 F android.camera: file_utils.cc:113] e82a64593000-e82a645af000 ---p 00000000 00:00 0
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a646f7000-e82a646f8000 rw-p 000a0000 b3:05 337 /system/lib64/libft2.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a646f9000-e82a64715000 r--s 00000000 b3:05 2552 /system/fonts/NotoSansTeluguUI-Bold.ttf
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64715000-e82a64719000 r-xp 00000000 b3:05 303 /system/lib64/libnativewindow.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64719000-e82a64734000 ---p 00000000 00:00 0
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64734000-e82a64735000 r--p 0000f000 b3:05 303 /system/lib64/libnativewindow.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64735000-e82a64736000 rw-p 00010000 b3:05 303 /system/lib64/libnativewindow.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64736000-e82a64738000 rw-p 00000000 00:05 19319 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64738000-e82a64754000 r--s 00000000 b3:05 2649 /system/fonts/NotoSansTeluguUI-Regular.ttf
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64754000-e82a64756000 r-xp 00000000 b3:05 291 /system/lib64/libhardware_legacy.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64756000-e82a64773000 ---p 00000000 00:00 0
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64773000-e82a64774000 r--p 0000f000 b3:05 291 /system/lib64/libhardware_legacy.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64774000-e82a64775000 rw-p 00010000 b3:05 291 /system/lib64/libhardware_legacy.so
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64775000-e82a64777000 rw-p 00000000 00:05 19317 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.677 4201 4212 F android.camera: file_utils.cc:113] e82a64777000-e82a64792000 r--s 00000000 b3:05 2556 /system/fonts/NotoSansTelugu-Bold.ttf
06-25 21:49:57.678 4201 4212 F android.camera: file_utils.cc:113] e82a64792000-e82a647cf000 r-xp 00000000 b3:05 295 /system/lib64/libprotobuf-cpp-lite.so
06-25 21:49:57.678 4201 4212 F android.camera: file_utils.cc:113] e82a647cf000-e82a647e0000 ---p 00000000 00:00 0
06-25 21:49:57.678 4201 4212 F android.camera: file_utils.cc:113] e82a647e0000-e82a647e2000 r--p 0003e000 b3:05 295 /system/lib64/libprotobuf-cpp-lite.so
06-25 21:49:57.678 4201 4212 F android.camera: file_utils.cc:113] e82a647e2000-e82a647e3000 rw-p 00040000 b3:05 295 /system/lib64/libprotobuf-cpp-lite.so
06-25 21:49:57.678 4201 4212 F android.camera: file_utils.cc:113] e82a647e4000-e82a647e6000 rw-p 00000000 00:05 28675 /dev/ashmem/dalvik-indirect ref table (deleted)
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a652ca000-e82a652cf000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a652d0000-e82a652d4000 r--s 00000000 b3:05 2731 /system/fonts/NotoSansPahawhHmong-Regular.otf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a652d4000-e82a65315000 r--s 00000000 b3:05 2737 /system/fonts/NotoSerif-BoldItalic.ttf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65315000-e82a6531e000 r-xp 00000000 b3:05 404 /system/lib64/libnetdutils.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6531e000-e82a65334000 ---p 00000000 00:00 0
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65334000-e82a65335000 r--p 0000f000 b3:05 404 /system/lib64/libnetdutils.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65335000-e82a65336000 rw-p 00010000 b3:05 404 /system/lib64/libnetdutils.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65336000-e82a65342000 r--s 00000000 b3:05 2555 /system/fonts/NotoSansTaiTham-Regular.ttf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65342000-e82a6535f000 r--s 00000000 b3:05 2532 /system/fonts/NotoSerifBengali-Bold.ttf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6535f000-e82a65363000 r-xp 00000000 b3:05 275 /system/lib64/libdebuggerd_client.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65363000-e82a6537e000 ---p 00000000 00:00 0
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6537e000-e82a6537f000 r--p 0000f000 b3:05 275 /system/lib64/libdebuggerd_client.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6537f000-e82a65380000 rw-p 00010000 b3:05 275 /system/lib64/libdebuggerd_client.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65381000-e82a6539e000 r--s 00000000 b3:05 2673 /system/fonts/NotoSerifBengali-Regular.ttf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6539e000-e82a653a0000 r-xp 00000000 b3:05 513 /system/lib64/libmemtrack.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653a0000-e82a653bd000 ---p 00000000 00:00 0
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653bd000-e82a653be000 r--p 0000f000 b3:05 513 /system/lib64/libmemtrack.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653be000-e82a653bf000 rw-p 00010000 b3:05 513 /system/lib64/libmemtrack.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653bf000-e82a653d6000 r--s 00000000 b3:05 2623 /system/fonts/NotoSerifKannada-Bold.ttf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653d6000-e82a653d8000 r-xp 00000000 b3:05 796 /system/lib64/libdl.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653d8000-e82a653f5000 ---p 00000000 00:00 0
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653f5000-e82a653f6000 r--p 0000f000 b3:05 796 /system/lib64/libdl.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653f6000-e82a653f7000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653f7000-e82a653fa000 r--s 00000000 b3:05 2611 /system/fonts/NotoSansPalmyrene-Regular.otf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a653fa000-e82a65400000 r--s 00000000 b3:05 2699 /system/fonts/NotoSansMiao-Regular.otf
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65400000-e82a6542a000 r-xp 00000000 b3:05 282 /system/lib64/libstagefright_foundation.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6542a000-e82a6543d000 ---p 00000000 00:00 0
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6543d000-e82a6543f000 r--p 0002e000 b3:05 282 /system/lib64/libstagefright_foundation.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a6543f000-e82a65440000 rw-p 00030000 b3:05 282 /system/lib64/libstagefright_foundation.so
06-25 21:49:57.680 4201 4212 F android.camera: file_utils.cc:113] e82a65440000-e82a65454000 r--s 00000000 b3:05 2628 /system/fonts/NotoSansOriyaUI-Bold.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65454000-e82a65458000 r-xp 00000000 b3:05 863 /system/lib64/libusbhost.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65458000-e82a65473000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65473000-e82a65474000 r--p 0000f000 b3:05 863 /system/lib64/libusbhost.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65474000-e82a65475000 rw-p 00010000 b3:05 863 /system/lib64/libusbhost.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65475000-e82a65482000 r--s 00000000 b3:05 2520 /system/fonts/NotoSansSyriacEastern-Regular.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65482000-e82a65498000 r-xp 00000000 b3:05 496 /system/lib64/liblog.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65498000-e82a654b1000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654b1000-e82a654b2000 r--p 0001f000 b3:05 496 /system/lib64/liblog.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654b2000-e82a654b3000 rw-p 00020000 b3:05 496 /system/lib64/liblog.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654b3000-e82a654b6000 r--s 00000000 b3:05 2661 /system/fonts/NotoSansOldPermic-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654b6000-e82a654bb000 r--s 00000000 b3:05 2537 /system/fonts/NotoSansMeroitic-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654bb000-e82a654d4000 r--s 00000000 b3:05 2561 /system/fonts/NotoSansBengali-Bold.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654d4000-e82a654d8000 r-xp 00000000 b3:05 423 /system/lib64/libspeexresampler.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654d8000-e82a654f3000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654f3000-e82a654f4000 r--p 0000f000 b3:05 423 /system/lib64/libspeexresampler.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654f4000-e82a654f5000 rw-p 00010000 b3:05 423 /system/lib64/libspeexresampler.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654f5000-e82a654f7000 r--s 00000000 b3:05 2567 /system/fonts/NotoSansOldNorthArabian-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a654f7000-e82a65506000 r--s 00000000 b3:05 2705 /system/fonts/NotoSansCherokee-Regular.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65506000-e82a65512000 r-xp 00000000 b3:05 480 /system/lib64/libsoundtrigger.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65512000-e82a6552e000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6552e000-e82a65532000 r--p 0000c000 b3:05 480 /system/lib64/libsoundtrigger.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65532000-e82a65533000 rw-p 00010000 b3:05 480 /system/lib64/libsoundtrigger.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65533000-e82a65538000 r--s 00000000 b3:05 2629 /system/fonts/NotoSansManichaean-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65538000-e82a65545000 r--s 00000000 b3:05 2721 /system/fonts/NotoSansAdlam-Regular.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65545000-e82a655a3000 r-xp 00000000 b3:05 483 /system/lib64/libharfbuzz_ng.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a655a3000-e82a655b3000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a655b3000-e82a655b5000 r--p 0005e000 b3:05 483 /system/lib64/libharfbuzz_ng.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a655b5000-e82a655b6000 rw-p 00060000 b3:05 483 /system/lib64/libharfbuzz_ng.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a655b6000-e82a655f3000 r--s 00000000 b3:05 2676 /system/fonts/NotoSerif-Italic.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a655f3000-e82a6565b000 r-xp 00000000 b3:05 410 /system/lib64/libaudioclient.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6565b000-e82a6566d000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6566d000-e82a6567c000 r--p 00071000 b3:05 410 /system/lib64/libaudioclient.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6567c000-e82a6567d000 rw-p 00080000 b3:05 410 /system/lib64/libaudioclient.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6567d000-e82a65689000 r--s 00000000 b3:05 2732 /system/fonts/NotoSansSyriacEstrangela-Regular.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65689000-e82a6568f000 r-xp 00000000 b3:05 822 /system/lib64/libnativehelper.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a6568f000-e82a656a8000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656a8000-e82a656a9000 r--p 0000f000 b3:05 822 /system/lib64/libnativehelper.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656a9000-e82a656aa000 rw-p 00010000 b3:05 822 /system/lib64/libnativehelper.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656aa000-e82a656ac000 r--s 00000000 b3:05 2725 /system/fonts/NotoSansNabataean-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656ac000-e82a656c8000 r--s 00000000 b3:05 2704 /system/fonts/NotoSansGujaratiUI-Bold.ttf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656c8000-e82a656dd000 r-xp 00000000 b3:05 470 /system/lib64/android.hardware.graphics.allocator@2.0.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656dd000-e82a656f5000 ---p 00000000 00:00 0
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656f5000-e82a656f7000 r--p 0001e000 b3:05 470 /system/lib64/android.hardware.graphics.allocator@2.0.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656f7000-e82a656f8000 rw-p 00020000 b3:05 470 /system/lib64/android.hardware.graphics.allocator@2.0.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a656f9000-e82a65702000 r--s 00000000 b3:05 2650 /system/fonts/NotoSansLinearA-Regular.otf
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65702000-e82a65722000 r-xp 00000000 b3:05 265 /system/lib64/android.hidl.memory@1.0.so
06-25 21:49:57.681 4201 4212 F android.camera: file_utils.cc:113] e82a65722000-e82a6573c000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6573c000-e82a6573f000 r--p 0002d000 b3:05 265 /system/lib64/android.hidl.memory@1.0.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6573f000-e82a65740000 rw-p 00030000 b3:05 265 /system/lib64/android.hidl.memory@1.0.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65741000-e82a65743000 r--s 00000000 b3:05 2712 /system/fonts/NotoSansMultani-Regular.otf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65743000-e82a6574a000 r--s 00000000 b3:05 2578 /system/fonts/NotoSansPhagsPa-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6574a000-e82a6574c000 r-xp 00000000 b3:05 708 /system/lib64/libhardware.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6574c000-e82a65769000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a65769000-e82a6576a000 r--p 0000f000 b3:05 708 /system/lib64/libhardware.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a6576a000-e82a6576b000 rw-p 00010000 b3:05 708 /system/lib64/libhardware.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a6576c000-e82a65783000 r--s 00000000 b3:05 2534
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] /system/fonts/NotoSerifKannada-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a65783000-e82a65785000 r-xp 00000000 b3:05 842 /system/lib64/libstagefright_http_support.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a65785000-e82a657a2000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a657a2000-e82a657a3000 r--p 0000f000 b3:05 842 /system/lib64/li
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] bstagefright_http_support.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657a3000-e82a657a4000 rw-p 00010000 b3:05 842 /system/lib64/libstagefright_http_support.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657a4000-e82a657a6000 r--s 00000000 b3:05 2696 /system/fonts/NotoSansMro-Regular.otf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657a6000-e82a657af000 r--s 00000000 b3:05 2522 /system/fonts/NotoSansSymbols-Regular-Subsetted2.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657af000-e82a657cc000 r--s 00000000 b3:05 2548 /system/fonts/NotoSansGujaratiUI-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657cc000-e82a657e8000 r-xp 00000000 b3:05 345 /system/lib64/libbufferhubqueue.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657e8000-e82a657fb000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657fb000-e82a657fc000 r--p 0001f000 b3:05 345 /system/lib64/libbufferhubqueue.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657fc000-e82a657fd000 rw-p 00020000 b3:05 345 /system/lib64/libbufferhubqueue.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a657fe000-e82a65801000 r--s 00000000 b3:05 2709 /system/fonts/NotoSansTaiLe-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65801000-e82a65823000 r-xp 00000000 b3:05 854 /system/lib64/android.hardware.configstore@1.0.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65823000-e82a6583c000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6583c000-e82a6583f000 r--p 0002d000 b3:05 854 /system/lib64/android.hardware.configstore@1.0.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6583f000-e82a65840000 rw-p 00030000 b3:05 854 /system/lib64/android.hardware.configstore@1.0.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65840000-e82a65842000 r--s 00000000 b3:05 2667 /system/fonts/NotoSansHatran-Regular.otf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65842000-e82a65846000 r--s 00000000 b3:05 2723 /system/fonts/NotoSansTifinagh-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65846000-e82a6584a000 r--s 00000000 b3:05 2554 /system/fonts/NotoSansTaiViet-Regular.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6584a000-e82a65881000 r-xp 00000000 b3:05 455 /system/lib64/libm.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65881000-e82a65899000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a65899000-e82a6589a000 r--p 0003f000 b3:05 455 /system/lib64/libm.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a6589a000-e82a6589b000 rw-p 00040000 b3:05 455 /system/lib64/libm.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:132] e82a6589b000-e82a6589d000 r--s 00000000 b3:05 2519
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] /system/fonts/NotoSansBassaVah-Regular.otf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a6589d000-e82a658e9000 r--s 00000000 b3:05 2655 /system/fonts/Roboto-Thin.ttf
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a658e9000-e82a65db5000 r-xp 00000000 b3:05 257 /system/lib64/libpdfium.so
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65db5000-e82a65dc9000 ---p 00000000 00:00 0
06-25 21:49:57.682 4201 4212 F android.camera: file_utils.cc:113] e82a65dc9000-e82a65de0000 r--p 004d9000 b3:05 257 /system/lib64/libpdfium.so
06-25 21:49:57.683 4201 4212 F android.camera: file_utils.cc:113] e82a65de0000-e82a65de4000 rw-p 004f0000 b3:05 257 /system/lib64/libpdfium.so
06-25 21:49:57.683 4201 4212 F android.camera: file_utils.cc:113] e82a65de4000-e82a65deb000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.683 4201 4212 F android.camera: file_utils.cc:113] e82a65dec000-e82a65e01000 r--s 00000000 b3:05 2580 /system/fonts/NotoSansOriya-Bold.ttf
06-25 21:49:57.683 4201 4212 F android.camera: file_utils.cc:113] e82a65e01000-e82a65e16000 r-xp 00000000 b3:05 517 /system/lib64/libstatslog.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660b6000-e82a660ca000 r--s 00000000 b3:05 2617 /system/fonts/NotoSansOriyaUI-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660ca000-e82a660e0000 r-xp 00000000 b3:05 252 /system/lib64/android.hidl.token@1.0.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660e0000-e82a660f7000 ---p 00000000 00:00 0
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660f7000-e82a660f9000 r--p 0001e000 b3:05 252 /system/lib64/android.hidl.token@1.0.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660f9000-e82a660fa000 rw-p 00020000 b3:05 252 /system/lib64/android.hidl.token@1.0.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660fa000-e82a660fc000 r--s 00000000 b3:05 2581 /system/fonts/NotoSansTagalog-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a660fc000-e82a66100000 r--s 00000000 b3:05 2613 /system/fonts/NotoSansSylotiNagri-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a66100000-e82a66103000 r--s 00000000 b3:05 2585 /system/fonts/NotoSansSundanese-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a66103000-e82a66191000 r-xp 00000000 b3:05 824 /system/lib64/libgui.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a66191000-e82a661a5000 ---p 00000000 00:00 0
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:132] e82a661a5000-e82a661b8000 r--p 0008d000 b3:05 824 /system/lib64/libgui.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:132] e82a661b8000-e82a661b9000 rw-p 000a0000 b3:05 824 /system/lib64/libgui.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:132] e82a661ba000-e82a661bc000 r--s 00000000 b3:05 2563
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] /system/fonts/NotoSansShavian-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661bc000-e82a661c1000 r--s 00000000 b3:05 2525 /system/fonts/NotoSansSaurashtra-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661c1000-e82a661c4000 r--s 00000000 b3:05 2710 /system/fonts/NotoSansSamaritan-Regular.ttf
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661c4000-e82a661d5000 r-xp 00000000 b3:05 717 /system/lib64/libaudioutils.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661d5000-e82a661f3000 ---p 00000000 00:00 0
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661f3000-e82a661f4000 r--p 0001f000 b3:05 717 /system/lib64/libaudioutils.so
06-25 21:49:57.685 4201 4212 F android.camera: file_utils.cc:113] e82a661f4000-e82a661f5000 rw-p 00020000 b3:05 717 /system/lib64/libaudioutils.so
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a661f6000-e82a661f9000 r--s 00000000 b3:05 2625 /system/fonts/NotoSansRunic-Regular.ttf
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a661f9000-e82a661fb000 r--s 00000000 b3:05 2672 /system/fonts/NotoSansRejang-Regular.ttf
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a661fb000-e82a66200000 r--s 00000000 b3:05 2575 /system/fonts/NotoSansNKo-Regular.ttf
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a66200000-e82a6621e000 r--s 00000000 b3:05 2597 /system/fonts/NotoSansDevanagariUI-Bold.ttf
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a6621e000-e82a66243000 r-xp 00000000 b3:05 467 /system/lib64/libEGL.so
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:113] e82a66243000-e82a66262000 ---p 00000000 00:00 0
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:132] e82a66262000-e82a66266000 r--p 0002c000 b3:05 467 /system/lib64/libEGL.so
06-25 21:49:57.686 4201 4212 F android.camera: file_utils.cc:132] e82a66266000-e82a66267000 rw-p 00030000 b3:05 467 /system/lib64/libEGL.so
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] boot-voip-common.art
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] @boot-android.test.base.art
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 70ade000-70bf1000 r--p 00000000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 70bf1000-70f28000 r-xp 00113000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 70f28000-70f29000 rw-p 00000000 00:00 0
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] [anon:.bss]
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 70f29000-713a7000 r--s 00000000 b3:05 45 /system/framework/boot.vdex
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 713a7000-713a8000 r--p 0044a000 b3:05 190 /system/framework/arm64/boot.oat
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:132] 713a8000-713a9000 rw-p 0044b000 b3:05 190
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] /system/framework/arm64/boot.oat
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] 713a9000-71421000 r--p 00000000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.695 4201 4263 F android.camera: file_utils.cc:113] 71421000-7156f000 r-xp 00078000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a6687e000-e82a66882000 r--s 00000000 b3:05 2662 /system/fonts/NotoSansMeeteiMayek-Regular.ttf
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a66882000-e82a66886000 r-xp 00000000 b3:05 405 /system/lib64/libaudiomanager.so
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a66886000-e82a668a1000 ---p 00000000 00:00 0
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a668a1000-e82a668a2000 r--p 0000f000 b3:05 405 /system/lib64/libaudiomanager.so
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 7156f000-71570000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a668a2000-e82a668a3000 rw-p 00010000 b3:05 405 /system/lib64/libaudiomanager.so
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a668a3000-e82a668ab000 r--s 00000000 b3:05 2574 /system/fonts/NotoSerifLao-Bold.ttf
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a668ab000-e82a668f9000 r--s 00000000 b3:05 1318 /system/usr/hyphen-data/hyph-hu.hyb
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a668f9000-e82a6691c000 r-xp 00000000 b3:05 810 /system/lib64/liblzma.so
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a6691c000-e82a66938000 ---p 00000000 00:00 0
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a66938000-e82a66939000 r--p 0002f000 b3:05 810 /system/lib64/liblzma.so
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 71570000-71868000 r--s 00000000 b3:05 127 /system/framework/boot-core-libart.vdex
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 71868000-71869000 r--p 001c6000 b3:05 180 /system/framework/arm64/boot-core-libart.oat
06-25 21:49:57.696 4201 4212 F android.camera: file_utils.cc:113] e82a66939000-e82a6693a000 rw-p 00030000 b3:05 810 /system/lib64/liblzma.so
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 718b3000-71914000 r--s 00000000 b3:05 125 /system/framework/boot-conscrypt.vdex
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 71916000-71930000 r--p 00000000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.696 4201 4263 F android.camera: file_utils.cc:113] 71930000-71972000 r-xp 0001a000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71972000-71973000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71973000-719d2000 r--s 00000000 b3:05 126 /system/framework/boot-okhttp.vdex
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 719d2000-719d3000 r--p 0005c000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 719d3000-719d4000 rw-p 0005d000 b3:05 196 /system/framework/arm64/boot-okhttp.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 719d4000-719ed000 r--p 00000000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 719ed000-71a2c000 r-xp 00019000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71a2c000-71a2d000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71a2d000-71b6f000 r--s 00000000 b3:05 155 /system/framework/boot-bouncycastle.vdex
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b6f000-71b70000 r--p 00058000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b70000-71b71000 rw-p 00059000 b3:05 189 /system/framework/arm64/boot-bouncycastle.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b71000-71b7e000 r--p 00000000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b7e000-71b98000 r-xp 0000d000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b98000-71b99000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71b99000-71cbb000 r--s 00000000 b3:05 229 /system/framework/boot-apache-xml.vdex
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71cbb000-71cbc000 r--p 00027000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71cbc000-71cbd000 rw-p 00028000 b3:05 159 /system/framework/arm64/boot-apache-xml.oat
06-25 21:49:57.697 4201 4212 F android.camera: file_utils.cc:113] e82a6694c000-e82a66959000 r--s 00000000 b3:05 2576 /system/fonts/NotoSerifMalayalam-Bold.ttf
06-25 21:49:57.697 4201 4212 F android.camera: file_utils.cc:113] e82a66959000-e82a66961000 r-xp 00000000 b3:05 351 /system/lib64/libcamera_metadata.so
06-25 21:49:57.697 4201 4212 F android.camera: file_utils.cc:113] e82a66961000-e82a66976000 ---p 00000000 00:00 0
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71cbd000-71ccb000 r--p 00000000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71ccb000-71ce7000 r-xp 0000e000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71ce7000-71ce8000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71ce8000-71dd3000 r--s 00000000 b3:05 233 /system/framework/boot-ext.vdex
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71dd3000-71dd4000 r--p 0002a000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71dd4000-71dd5000 rw-p 0002b000 b3:05 210 /system/framework/arm64/boot-ext.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 71dd5000-721a2000 r--p 00000000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.697 4201 4263 F android.camera: file_utils.cc:113] 721a2000-72c48000 r-xp 003cd000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a66976000-e82a66977000 r--p 0000f000 b3:05 351 /system/lib64/libcamera_metadata.so
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 72c48000-72c4a000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a66977000-e82a66979000 rw-p 00010000 b3:05 351 /system/lib64/libcamera_metadata.so
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a66979000-e82a66983000 r--s 00000000 b3:05 2608 /system/fonts/NotoSansKhmerUI-Regular.ttf
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 72c4a000-73ffa000 r--s 00000000 b3:05 142 /system/framework/boot-framework.vdex
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 73ffa000-73ffb000 r--p 00e73000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 73ffb000-73ffc000 rw-p 00e74000 b3:05 185 /system/framework/arm64/boot-framework.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 73ffc000-7407e000 r--p 00000000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 7407e000-741e1000 r-xp 00082000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 741e1000-741e2000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 741e2000-744b6000 r--s 00000000 b3:05 145 /system/framework/boot-telephony-common.vdex
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744b6000-744b7000 r--p 001e5000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a66983000-e82a66990000 r--s 00000000 b3:05 2718 /system/fonts/NotoSerifMalayalam-Regular.ttf
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744b7000-744b8000 rw-p 001e6000 b3:05 171 /system/framework/arm64/boot-telephony-common.oat
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a66990000-e82a669a5000 r-xp 00000000 b3:05 505 /system/lib64/libmedia_helper.so
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a669a5000-e82a669bb000 ---p 00000000 00:00 0
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744b8000-744bb000 r--p 00000000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744bb000-744bd000 r-xp 00003000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a669bb000-e82a669be000 r--p 0001d000 b3:05 505 /system/lib64/libmedia_helper.so
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744bd000-744be000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744be000-744e3000 r--s 00000000 b3:05 48 /system/framework/boot-voip-common.vdex
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744e3000-744e4000 r--p 00005000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744e4000-744e5000 rw-p 00006000 b3:05 162 /system/framework/arm64/boot-voip-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744e5000-744ed000 r--p 00000000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744ed000-744fd000 r-xp 00008000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744fd000-744fe000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a669be000-e82a669bf000 rw-p 00020000 b3:05 505 /system/lib64/libmedia_helper.so
06-25 21:49:57.698 4201 4212 F android.camera: file_utils.cc:113] e82a669c0000-e82a669ce000 r--s 00000000 b3:05 2622 /system/fonts/NotoSansMalayalam-Bold.ttf
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 744fe000-7451f000 r--s 00000000 b3:05 59 /system/framework/boot-ims-common.vdex
06-25 21:49:57.698 4201 4263 F android.camera: file_utils.cc:113] 7451f000-74520000 r--p 00018000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a669ce000-e82a669f2000 r--s 00000000 b3:05 2614 /system/fonts/NotoSansEthiopic-Bold.ttf
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] 74520000-74521000 rw-p 00019000 b3:05 165 /system/framework/arm64/boot-ims-common.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74521000-74524000 r--p 00000000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74524000-74525000 r-xp 00003000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] .0-java.oat
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a669f2000-e82a66a15000 r-xp 00000000 b3:05 261 /system/lib64/libui.so
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a15000-e82a66a30000 ---p 00000000 00:00 0
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74525000-7452c000 r--s 00000000 b3:05 52 /system/framework/boot-android.hidl.base-V1.0-java.vdex
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 7452c000-7452d000 r--p 00004000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-ja
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] va.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 7452d000-7452e000 rw-p 00005000 b3:05 195 /system/framework/arm64/boot-android.hidl.base-V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 7452e000-74531000 r--p 00000000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] -V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74531000-74533000 r-xp 00003000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager-V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74533000-7453e000 r--s 00000000 b3:05 135 /system/framework/boot-android.hidl.manager-V1
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] .0-java.vdex
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 7453e000-7453f000 r--p 00005000 b3:05 176 /system/framework/arm64/boot-android.hidl.manager-V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 7453f000-74540000 rw-p 00006000 b3:05 176 /system/framework/arm64/boot-android.hidl.mana
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] ger-V1.0-java.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74540000-74543000 r--p 00000000 b3:05 201 /system/framework/arm64/boot-framework-oahl-backward-compatibility.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74543000-74544000 r-xp 00003000 b3:05 201 /system/framework/arm64/boot-framework-
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a30000-e82a66a32000 r--p 0002e000 b3:05 261 /system/lib64/libui.so
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a32000-e82a66a33000 rw-p 00030000 b3:05 261 /system/lib64/libui.so
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] oahl-backward-compatibility.oat
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a34000-e82a66a3c000 r--s 00000000 b3:05 2706 /system/fonts/NotoSerifLao-Regular.ttf
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74544000-74545000 r--s 00000000 b3:05 144 /system/framework/boot-framework-oahl-backward-compatibility.vdex
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74545000-74546000 r--p 00004000 b3:05 201 /system/framework/arm64/boot-framework-oahl-
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a3c000-e82a66a5f000 r--s 00000000 b3:05 2570 /system/fonts/NotoSansEthiopic-Regular.ttf
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66a5f000-e82a66c44000 r-xp 00000000 b3:05 285 /system/lib64/libandroid_runtime.so
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:113] backward-compatibility.oat
06-25 21:49:57.699 4201 4212 F android.camera: file_utils.cc:113] e82a66c44000-e82a66c5a000 ---p 00000000 00:00 0
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74546000-74547000 rw-p 00005000 b3:05 201 /system/framework/arm64/boot-framework-oahl-backward-compatibility.oat
06-25 21:49:57.699 4201 4263 F android.camera: file_utils.cc:132] 74547000-7454a000 r--p 00000000 b3:05 170 /system/framework/arm64/boot-android.te
06-25 21:49:57.700 4201 4212 F android.camera: file_utils.cc:113] e82a66c5a000-e82a66c79000 r--p 001f1000 b3:05 285 /system/lib64/libandroid_runtime.so
06-25 21:49:57.700 4201 4212 F android.camera: file_utils.cc:113] e82a66c79000-e82a66c7a000 rw-p 00210000 b3:05 285 /system/lib64/libandroid_runtime.so
06-25 21:49:57.700 4201 4263 F android.camera: file_utils.cc:113] st.base.oat
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:132] 7454a000-7454b000 r-xp 00003000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:132] 7454b000-74553000 r--s 00000000 b3:05 130 /system/framework/boot-android.test.base.vdex
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:132] 74553000-7455
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66c7a000-e82a66c7e000 rw-p 00000000 00:00 0 [anon:.bss]
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 4000 r--p 00004000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66c7e000-e82a66c87000 r--s 00000000 b3:05 2724 /system/fonts/NotoSansKhmerUI-Bold.ttf
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66c87000-e82a66ca5000 r--s 00000000 b3:05 2651 /system/fonts/NotoNaskhArabicUI-Bold.ttf
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 74554000-74555000 rw-p 00005000 b3:05 170 /system/framework/arm64/boot-android.test.base.oat
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 74555000-7469e000 rw-p 00000000 00:05 15807 /dev/ashmem/dalvik-zygote space (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66ca5000-e82a66cd8000 r-xp 00000000 b3:05 344 /system/lib64/libpng.so
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 7469e000-7469f000 rw-p 00000000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66cd8000-e82a66cf4000 ---p 00000000 00:00 0
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66cf4000-e82a66cf5000 r--p 0003f000 b3:05 344 /system/lib64/libpng.so
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66cf5000-e82a66cf6000 rw-p 00040000 b3:05 344 /system/lib64/libpng.so
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 7469f000-746b2000 rw-p 00001000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 746b2000-77556000 ---p 00014000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66cf6000-e82a66cf8000 r--s 00000000 b3:05 2515 /system/fonts/NotoSansOldItalic-Regular.ttf
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66cf8000-e82a66d02000 r--s 00000000 b3:05 2550 /system/fonts/NotoSerifKhmer-Regular.otf
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d02000-e82a66d05000 r-xp 00000000 b3:05 297 /system/lib64/libpackagelistparser.so
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d05000-e82a66d21000 ---p 00000000 00:00 0
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 77556000-78555000 rw-p 02eb8000 00:05 16117 /dev/ashmem/dalvik-non moving space (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d21000-e82a66d22000 r--p 0000f000 b3:05 297 /system/lib64/libpackagelistparser.so
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d22000-e82a66d23000 rw-p 00010000 b3:05 297 /system/lib64/libpackagelistparser.so
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d23000-e82a66d25000 r--s 00000000 b3:05 2610 /system/fonts/NotoSansOlChiki-Regular.ttf
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d25000-e82a66d33000 r--s 00000000 b3:05 2547 /system/fonts/NotoSansMalayalam-Regular.ttf
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d33000-e82a66d3c000 r--s 00000000 b3:05 2533 /system/fonts/NotoSansTamilUI-Bold.ttf
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 78555000-98555000 rw-p 00000000 00:05 15812 /dev/ashmem/dalvik-free list large object space (deleted)
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 98555000-9a555000 rw-p 00000000 00:05 26599 /dev/ashmem/dalvik-data-code-cache (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d3c000-e82a66d5a000 r--s 00000000 b3:05 2645 /system/fonts/NotoNaskhArabicUI-Regular.ttf
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] 9a555000-9c555000 r-xp 00000000 00:05 26600 /dev/ashmem/dalvik-jit-code-cache (deleted)
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d5a000-e82a66d5f000 r-xp 00000000 b3:05 414 /system/lib64/libstagefright_codecbase.so
06-25 21:49:57.701 4201 4212 F android.camera: file_utils.cc:113] e82a66d5f000-e82a66d79000 ---p 00000000 00:00 0
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] ebad6000-ebad7000 ---p 00000000 00:05 13471 /dev/ashmem/dalvik-Sentinel fault page (deleted)
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] aff1a2552000-aff1a2557000 r-xp 00000000 b3:05 1470 /system/bin/app_process64
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] aff1a2571000-aff1a2572000 r--p 0000f000 b3:05 1470 /system/bin/app_process64
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] aff1a2572000-aff1a2574000 rw-p 00000000 00:00 0
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] e82a425a6000-e82a425a7000 ---p 00000000 00:00 0
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] e82a425a7000-e82a425a8000 ---p 00000000 00:00 0
06-25 21:49:57.701 4201 4263 F android.camera: file_utils.cc:113] e82a425a8000-e82a426ac000 rw-p 00000000 00:00 0
06-25 21:49:57.704 4201 4212 F android.camera: file_utils.cc:113] e82a670b5000-e82a670b6000 rw-p 00020000 b3:05 272 /system/lib64/libbacktrace.so
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:113] e82a47b02000-e82a47b03000 ---p 00000000 00:00 0
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:113] e82a47b03000-e82a47c00000 rw-p 00000000 00:00 0
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:113] e82a47c00000-e82a47e00000 rw-p 00000000 00:00 0 [anon:libc_malloc]
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:113] e82a47e0c000-e82a47e4c000 rw-s 00000000 00:05 26915 /dev/zero (deleted)
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:132] e82a47e4c000-e82a47e4e000 r-xp 00000000 b3:05 737 /system/lib64/vndk-sp-28/libion.so
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:132] e82a47e4e000-e82a47e6b000 ---p 00000000 00:00 0
06-25 21:49:57.710 4201 4263 F android.camera: file_utils.cc:132] e82a47e6b000-e82a47e6c000 r--p 0000f000 b3:05 737 /system/lib64/vndk-sp-28/l
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] ibion.so
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47e6c000-e82a47e6d000 rw-p 00010000 b3:05 737 /system/lib64/vndk-sp-28/libion.so
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47e8e000-e82a47ea5000 r-xp 00000000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47ea5000-e82a47ebb000 ---p 00
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] 000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47ebb000-e82a47ebd000 r--p 0001e000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47ebd000-e82a47ebe000 rw-p 00020000 b3:0a 204 /vendor/lib64/nxp.hardware.display@1.0.so
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a47ef1000-e82a47ef2000
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a47ef2000-e82a47ef3000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a47ef3000-e82a47ff7000 rw-p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a47ff7000-e82a47ff8000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a47ff8000-e82a47ff9000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a47ff9000-e82a480f5000 rw-p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a480f5000-e82a480f6000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a480f6000-e82a480f7000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a480f7000-e82a481fb000 rw-p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a481fb000-e82a481fd000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a481fd000-e82a482f9000 rw-p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:132] e82a482f9000-e82a483f9000 rw-s 00000000 00:05 26895
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a483f9000-e82a484f9000 rw-s 00000000 00:05 27825 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a484f9000-e82a484fa000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a484fa000-e82a484fb000 ---p 00000000 00:00 0
06-25 21:49:57.711 4201 4263 F android.camera: file_utils.cc:113] e82a484fb000-e82a485ff000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a485ff000-e82a48601000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48601000-e82a486fd000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a486fd000-e82a486fe000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a486fe000-e82a486ff000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a486ff000-e82a48803000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48803000-e82a48903000 rw-s 00000000 00:05 19342 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48903000-e82a48a03000 rw-s 00000000 00:05 26862 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48a03000-e82a48a04000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48a04000-e82a48a05000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48a05000-e82a48b01000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48b01000-e82a48b02000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48b02000-e82a48b03000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48b03000-e82a48bff000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48bff000-e82a48c00000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48c00000-e82a48c01000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] e82a48c01000-e82a48d05000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48d05000-e82a48d06000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48d06000-e82a48d07000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48d07000-e82a48e03000 rw-p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e03000-e82a48e08000 r-xp 00000000 b3:05 741 /system/lib64/vndk-sp-28/hw/android.
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] hidl.memory@1.0-impl.so
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e08000-e82a48e22000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e22000-e82a48e23000 r--p 0000f000 b3:05 741 /system/lib64/vndk-sp-28/hw/android.hidl.memory@1.0-impl.so
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e23000-e82a48e24000 rw-p 00010000 b3:05 741 /
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:113] system/lib64/vndk-sp-28/hw/android.hidl.memory@1.0-impl.so
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e41000-e82a48e61000 r-xp 00000000 b3:05 733 /system/lib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e61000-e82a48e7b000 ---p 00000000 00:00 0
06-25 21:49:57.712 4201 4263 F android.camera: file_utils.cc:132] e82a48e7b000-e82a48e7e000 r--p 0002d000 b3:05 733 /system/l
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] ib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a48e7e000-e82a48e7f000 rw-p 00030000 b3:05 733 /system/lib64/vndk-sp-28/android.hidl.memory@1.0.so
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a48e89000-e82a48e8a000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a48e8a000-e82a48e8b000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a48e8b000-e82a48f87000 rw-p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a48f87000-e82a49085000 r--p 00000000 00:14 10476 /dev/hwbinder
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49085000-e82a49086000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49086000-e82a49087000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49087000-e82a49183000 rw-p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49183000-e82a49184000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49184000-e82a49185000 ---p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49185000-e82a49289000 rw-p 00000000 00:00 0
06-25 21:49:57.713 4201 4263 F android.camera: file_utils.cc:113] e82a49289000-e82a49389000 rw-s 00000000 00:05 28681 /dev/ashmem/MemoryHeapBase (deleted)
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49389000-e82a4938a000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4938a000-e82a4938b000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4938b000-e82a49487000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49487000-e82a49488000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49488000-e82a49489000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49489000-e82a49585000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49585000-e82a49586000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49586000-e82a49587000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49587000-e82a4968b000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4968b000-e82a4968c000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4968c000-e82a4968d000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4968d000-e82a49791000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49791000-e82a49792000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49792000-e82a49793000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49793000-e82a49897000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49897000-e82a49898000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49898000-e82a49899000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49899000-e82a4999d000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4999d000-e82a4999e000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4999e000-e82a4999f000 ---p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4999f000-e82a49a9b000 rw-p 00000000 00:00 0
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a49a9b000-e82a4ba9b000 rw-s 00000000 00:05 27802 /dev/zero (deleted)
06-25 21:49:57.714 4201 4263 F android.camera: file_utils.cc:113] e82a4baa3000-e82a4baa4000 ---p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4baa4000-e82a4baa5000 ---p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4baa5000-e82a4bba1000 rw-p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4bba1000-e82a4bd2f000 r--s 00567000 b3:05 896 /system/app/Camera2/Camera2.apk
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4bd2f000-e82a4bd30000 ---p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4bd30000-e82a4bd31000 ---p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4bd31000-e82a4be2d000 rw-p 00000000 00:00 0
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:132] e82a4be2d000-e82a4be3c000 r--p 00000000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.dex
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:132] e82a4be3c000-e82a4be3d000 r-xp 0000f000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] 2@Camera2.apk@classes.dex
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:132] e82a4be3d000-e82a4c0b9000 r--s 00000000 b3:0c 261930 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.vdex
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:132] e82a4c0b9000-e82a4c0ba000 r--p 00010000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camer
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] a2@Camera2.apk@classes.dex
06-25 21:49:57.715 4201 4263 F android.camera: file_utils.cc:113] e82a4c0ba000-e82a4c0bb000 rw-p 00011000 b3:0c 261819 /data/dalvik-cache/arm64/system@app@Camera2@Camera2.apk@classes.dex
