Hi @pisces
You can sign the RTOS as you did with uboot, just make sure that the address in the IVT is valid and that the contents are correct. You can refer to the appendix in the AN4581 as attached, note that you need to delete the DCD first, and then restore the DCD.
Harvey
any updates?
thanks.
Hello Harvey021
Our small RTOS run on core A.
On an open (not fused) board, our small RTOS software can run well by using mfg tool to download.
But on closed board, it can not run. I know I need to sign the RTOS, but not like the uboot, there is no documents found to guide how we should sign a none uboot software.
Thanks.
