how to configure I2C SCL to 400KHZ
cotway
I changed bitrate (100000 to 400000),but SCL can't up to 400khz.now I don't know where need to configure.
Dhruvit
Hi @cotway,
I hope you are doing well.
One should change the value of clock frequency into the respective device tree on the i2c node at a particular address.
I've shared one example for reference, please take a look at it.
i2c@70038000 { /* HS-I2C on i.MX51 */
       compatible = "fsl,imx51-i2c", "fsl,imx21-i2c";
       reg = <0x70038000 0x4000>;
       interrupts = <64>;
       clock-frequency = <400000>;
Thanks & Regards,
Dhruvit Vasavada
Dhruvit
Hi @cotway,
       interrupts = <64>;
Thanks & Regards,
Dhruvit Vasavada
